Recommended Lift Kit
Discussion in 'Suspension' started by MR.WaynesWorld, Dec 7, 2021.
  1. Dec 7, 2021 at 3:42 PM
    MR.WaynesWorld
    MR.WaynesWorld [OP] Well-Known Member
    Wayne
    North East Pa
    2021 Black Tacoma Limited
    **** 2021 Mods **** Sokietech No Drill Hood Struts (Replaced) Color Matched Mirror Caps Color Match Door Handles SUPAREE LED Side Mirror Turn Signal Lights AVS Dark Smoked Hood Bugflector (Removed) Meso Black Interior Door Handles AVS Window Vents AUTOGINE Super Bright 6000K White LED Vanity Mirror Lights 3D Rear Tacoma Letters Matte Black OEM Blacked Out Emblems OEM Black Trim around Fog Lights Full BedRug AMP Research Bed Extender LoMax Tonneau Cover (Replaced) RBP 77-Spike Wheels 18X9 (Replaced) Nitto Terra Grappler G2 tires 285/60 (Replaced) Blacked out Toyota emblem on steering wheel Night Shade Front Grill (Replaced) Dark Tint Front TSS Emblem (Replaced MBRP Dual Exhaust KTJO Door Pod lighting Window Tint, 5% in the back 30% up front MESO Chrome Delete center console MESO Chrome Delete Vent Rings **** 2022 Mods **** Cali Raised Steel Front Skid Plate (Replaced) Ice Blue Map and Dome LED bulbs Rek-Gen XL Mud Flaps - Black on Black All interior trim painted Matte Black with Flat Clear Coat Aqua Blue Foot Lights - Front and Rear MESO Switch Panel Custom Layout MESO 3 Switch Overhead console panel MESO Chrome Delete Climate Control Rings UpTop Bravo Roof Rack Extreme LED 38 inch LED Light Bar in Roof Rack Diode Dynamics LED Strip Grill Lights Meso Ultimate Tail Lights (Replaced) Rock Lights - 8 Cyclone V2's (Replaced) UpTop Roof Rack Grab Handles UpTop Scene Pods with Baja Design Rock Lights Diode Dynamics Elite Series Fog Lights CaliRaised Stealth Bumper 30 inch Infinite Offroad LED Light Bar X2 Zeak 10,000 Winch KTJO Driver's Side Grab Handle LambTek Winch Switch Boomers "faux" TRD Pro Shift Knob Tacoma Lifestyle Smoke Third Brake Light Blacked out Instrument Panel Lens Diff Drop Dobinson's Suspension, Front Coil Overs, UCA's, Rear Shocks and Leaf Packs DB Customz Grill, Color Match with RGBW LED Letter Lighting **** 2023 Mods **** PowerTrays Tray with Busemann Fuse Relay Pioneer DMH-WC6600NEX Maestro RR2 SiriusXM SXV300 Tuner BoxWare Anti Glare HU Screen Protector Varity of cables and adapters Focal ACX 690 Front Speakers (Replaced) Focal ACX 165 Rear Speakers (Replaced) Diode Dynamics Stage Series Rock Lights - 3 in each wheel well Diode Dynamics Flush Mount Brackets Revolver X4s Tonneau Cover UpTop Roof Rack Grab Handles V2 Raceline Compass 17X9 wheels Toyo Tires Open Country A/T III 275/70R17 Tacoma Beast Infinity Tail Lights Taco Clout Wide Angle Convex Mirrors - Heated + Turn Signals + BSM KTJO Powered Folding Mirrors **** 2024 Mods **** Lighting Trendz Glow LED lights in Grill Lettering Cali Raised Cat Shields The Sub Box Shop Sub Amp box Rockford Fosgate 10 inch 4 ohm Dual VC Sub Kicker 3.5 inch speakers in dash (Replaced) Auto Harness House harness adapters for speaker wires Alpine PXE-C80-88 8 Channel Amp. Polk Audio DB 6502 Front Doors Polk Audio DB 6502 Tweeters in Dash Polk Audio DB 652 Rear Doors Hidden LED's in Bed Charvonia Design Bed Rail Tie Down Anchors Charvonia Design Bed Tie Down Anchors Charvonia Design Bed Floor Tie Down Anchors Charvonia Design Billet Battery Tie Down Redline Hood Struts TRD Pro Hood KITT Scanner LED in Hood Scoop Cali Raised Aluminum Skid Plate
  2. Dec 7, 2021 at 7:30 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Note that the linked kit does not lift the rear. I also do not see any information about the coil spring rate and length. I would want that information before buying it.
  3. Dec 8, 2021 at 5:08 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Thanks, I'll question them before buying...
  4. Dec 8, 2021 at 5:24 AM
    gillies66
    gillies66 Just Passing Through
    2020 DCSB OR
    Nice kit. Add a Deaver AAL in the rear, and your good to go.
  5. Dec 8, 2021 at 10:01 AM
    CMillTacoma
    CMillTacoma Well-Known Member
    Craig
    Colorado
    2025 TRD OR Hybrid
    The 6112 kit has 600pd coils, I'm looking at the same kit and Wheelers offroad has it assembled for like $40 less. I ran these on my 16' Tundra and they were great on that so hoping they're as good for a Taco.
    71tattooguy likes this.
  6. Dec 8, 2021 at 10:06 AM
    Ncousins1
    Ncousins1 Well-Known Member
    Niko
    Gainesville, FL
    2023 Solar Octane TRD Pro Tacoma
    i run the 6112's and 5125's in the rear (5125's travel for 2-3.5in lifts). love the bilstein setup
  7. Dec 8, 2021 at 1:00 PM
    WhiskeyHole
    WhiskeyHole Well-Known Member
    Columbus, Oh
    2013 PyriteMica
    Mostly stock
  8. Dec 9, 2021 at 3:54 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Recommended site to purchase the Deaver AAL?
  9. Dec 9, 2021 at 5:53 AM
    gillies66
    2020 DCSB OR
    Headstrong Offroad. I’ve had a good experience with them. So have many others on TW.
    Two Cents: I prefer the simplicity of the Deaver single AAL versus the three leaf, “progressive,” options. The Deaver installs without modification to the OE leaf pack and retains the OE overload leaf. You’ll get 1.5” lift. I’ve found the ride to be fine and the Deavers have held up well to over a year of solid wheeling, hauling and towing.
    https://www.headstrongoffroad.com/store/p96/Deaver_1.5-2_inch_Add-a-leaf_with_Center_Pins_(PAIR)_-_TACOAAL.html
    Forshee47 likes this.
  10. Dec 9, 2021 at 6:08 AM
    Forshee47
    Forshee47 Well-Known Member
    Trent
    North Carolina
    2015 Off-road DCSB 4x4
    I was also going to recommend headstrong off-road. You send them a message or email with the goals you want with your suspension and they will point you in the right direction. Very knowledgeable and reasonable prices. They also have kits you can build to get exactly what you want. I got full 5100’s with ome coils already assembled and the icon progressive aal for around 800. This was also 3 years ago before prices went crazy on everything
    gillies66[QUOTED] likes this.
  11. Dec 9, 2021 at 6:22 AM
    texas angler
    texas angler Well-Known Member
    Texas Hill Country
    20 OR
    Lifting for looks or off roading? Give Accutune a chance to help you too.
  12. Dec 9, 2021 at 7:01 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Basically, looks and for the winter to support the plow I just had installed. With the plow on and up oversized tires, 285/60 R18, are rubbing a little. So, I figured I would lift the truck 2 inches in the front and whatever I can do in the back. Don't do any off-roading.
    Just getting the pieces together now for an install in the spring. Right now, it's too damn cold out there to work on the truck, even in the garage. This morning it was 20 degrees.
  13. Dec 9, 2021 at 7:08 AM
    dherring256
    dherring256 Well-Known Member
    Daniel
    04 Taco, 18 Thundra
    I would contact the folks at Headstrong Offroad and tell them what you think you need - they will point you in the right direction. Don't be like me and buy a bunch of unnecessary stuff, just to return it and buy something different.
  14. Dec 9, 2021 at 7:10 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    just sent them a PM on what I'm looking for..
    Thanks all for the direction.
  15. Dec 9, 2021 at 11:37 AM
    Forshee47
    Trent
    North Carolina
    Even with the lift I would look into a set of Super Springs coil helpers. Easy to install when you need extra support for your plow and you can remove when you’re not using the plow so it rides better. Can install and remove them in just a few minutes. I use their sumo springs in the rear when I’m towing and they make a huge difference.
    gillies66 likes this.
  16. Dec 9, 2021 at 12:45 PM
    gillies66
    2020 DCSB OR
    Big fan of Sumos for additional support.
  17. Dec 9, 2021 at 1:07 PM
    MR.WaynesWorld
    Wayne
    North East Pa
    I’ll look into them. Thanks !!!!
  18. Dec 10, 2021 at 3:49 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Well I purchased the Deaver AAL from Headstrong Off Road yesterday. So that will be on it's way to me.
    Have another question, for the front struts should I go with 600, 650 or 700 pound rated springs?
  19. Dec 10, 2021 at 3:56 AM
    gillies66
    2020 DCSB OR
    Not fully sure of your intentions with the truck, but I went with 650# to handle the loads I expected and have experienced no loss of ride quality. They’ve held up great. Others can speak to 700#.
    If you’re installing yourself, here are the best vids I found to help:
    https://youtu.be/Yp3mc4eH3Ic
    https://youtu.be/I-hO1cWg93I
    MTB58 likes this.
  20. Dec 10, 2021 at 4:31 AM
    MR.WaynesWorld
    Wayne
    North East Pa
    Thanks @gillies66 ..
    99.999% of the time the truck will be a daily driver. Want to lift it to stop the rubbing on my tires when I have my plow hooked up to it. So when that is on I have around 300/375 extra pounds up front.
    I still need to measure the front with and without the plow on it.
    Just want to make sure I get the right springs.
