Recommended maintenance ?'s '08 DC TRD Sport, 180K mi
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prone2xl, Mar 6, 2020.
  1. Mar 6, 2020 at 2:49 PM
    prone2xl
    prone2xl [OP] Well-Known Member
    Mississippi
    2008 Silver TRD Sport DC
    Hey guys looking for some advice on recommended maintenance. I took my 08 into the dealer a few months back to be checked for frame rust and Thankfully no rust was found; however, they gave me a RECOMMENDED Maintenance list items and i'm planning to start chipping away at them as I declined during the Christmas time frame. Hoping you can let me know which things I should prioritize first, etc.
    Here are the recommendations and quoted price I received:
    - V6 tuneup $189
    - Drive Belt $169
    - Throttle Induction Cleaning $189
    - Coolant Flush $219
    * I also remember him mentioning spark plugs over the phone but it isn't listed on the print out.
    Anyways, thanks so much in advance and I appreciate all the advice on the forum as always!
  2. Mar 6, 2020 at 4:14 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Do you know any service history on the truck?
    I would recommend
    1. Spark Plugs
    2. Full Coolant Drain and Refill (hesitant of a Flush with out know past coolant system service)
    3. Trans Fluid Drain and Fill. (Again, Flush not recommended.)
    4. Differentials and Transfer Case Fluids.
    5. Drive Belt
    6. Grease Drive Shaft and Drive line components.
  3. Mar 6, 2020 at 4:21 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I’ll add brake fluid flush if it’s really dark and ps flush.
    TnShooter[QUOTED] likes this.
  4. Mar 6, 2020 at 7:10 PM
    Hooligans
    Hooligans Well-Known Member
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Still thinking about it.
    prone2xl..are you doing these things yourself? If so, you will save alot of money over those estimates. As in, V6 tuneup (spark plugs $25?), Coolant flush and fill (coolant $25?), Drive belt (belt $35?)... Just saying that those dollar amounts are largely labor costs. Still a good idea to do it or get it done, either way..
  5. Mar 6, 2020 at 8:00 PM
    prone2xl
    Mississippi
    Well I'm the original owner, but I'll be honest I'm not 100% on everything I've done for the 12 year history. What's the difference in a coolant flush and drain/refill ?
  6. Mar 6, 2020 at 8:01 PM
    prone2xl
    Mississippi
    Hey @Hooligans I admittedly don't have the mechanical knowledge or I would. Wish I had one of u guys nearby to possibly learn and tackle a group maintenance day together.
  7. Mar 6, 2020 at 8:21 PM
    TnShooter
    Deogee
    STOCK
    A flush “flushes” the whole system under pressure.
    Not a huge deal, but if you “flush” debris into your Heater Core it’s not good.
    That is a really big job and not easy (at least for me) to do.
    The chances of it actually stopping the heater core up are slim.
    But the chance rise if the system hasn’t been maintained regularly.
    I don’t like chances. Not on big jobs or things that could cost me more money.
    I chose to drain and fill.
    A full Drain and Fill will consist of draining the radiator and block.
    See here for location for block drains.
    https://www.tacomaworld.com/threads/coolant-drain-and-fill.219755/page-2#post-5807897
    If you do decide to do it yourself, the radiator peacock valve can be hard to open.
    I used a 22mm socket to help me. Thanks @Bishop84 for this great piece of helpful advice.
    As for Transmission Flush
    I’ll let @gearcruncher elaborate on that.
  8. Mar 6, 2020 at 8:23 PM
    prone2xl
    Mississippi
    Very good information thank u for that! Would it be best for me to ask them to drain and fill instead I guess? That would avoid the potential problem right ? Are u in TN ? I'm in Mississippi
  9. Mar 6, 2020 at 8:28 PM
    Hooligans
    Fairbanks, Alaska
    2015 4x4 2.7/5spd.
    Thanks for the response. I understand completely. Let the pros do it if it's not your thing.
  10. Mar 6, 2020 at 8:33 PM
    TnShooter
    Deogee
    STOCK
    Yes, I’m in Tn.
    As for what you have them do? It is up to you.
    I always try to tell people what might happen, even if the chances are small.
    The only reason I brought it up in your case was that I didn’t know the service history.
    If you had started the system had been Drained, Filled or Flushed regularly (40-50) I wouldn’t have mentioned the heater core.
    I myself went the full 100k before I did my D/R.
    I would not advise anyone to go that long.
    It is probably best to do it every 50k.
    The manual says 100k then every 50k there after, IIRC.
