Recommended oil weight for rear differential
Discussion in '1st Gen. Tacomas (1995-2004)' started by Backinblack03, Jun 24, 2013.
  1. Sep 16, 2013 at 5:13 PM
    #41
    Norton
    Norton Senior Member
    Monument, CO
    2013 Access Cab 4x4 V6 6MT, TRD OR & Tow Packages
    Magnuson S/C, OME Suspension Lift (885 Coils, Dakar Leafs, NitroCharger Sports); TRD Quickshifter w/TRD 6-Spd Knob; TRD Exhaust; aFe POWER Magnum FLOW Pro DRY S Air Filter; NSB-AGM27F Battery w/Coupe's TRD Battery Hold Down; Goodridge SS Brake Lines; Cooper Discoverer A/T3s on FJ SE Anthracite Rims; N-Fab 6-Step Nerf Bars; MetalMiller TRD Skid; jsi's Locker Anytime & ramonortiz55's Always on Power Outlet Relay Mods; crashnburn80's Ultimate Headlight & Fog Light Upgrades (RallyLights Harnesses, Osram 85/80W H4 & Flösser 90W H11 Bulbs); ND4's Fog Light Anytime Mod; Interior & Reverse LEDs; AudioControl LC2i LOC, JL Audio XD200/2v2 Amp, Focal PS165V1 Spkrs, Sound Ordnance B-8PTD Sub, Hushmat & Noico Sound Insulation; Ltd Auto-Dim/Compass/Temp/Backup Camera/Homelink mirror on ImMrYo's Mirror Lift Bracket; 4Runner 4X4 & FJ Fog Light Switches; Husky Floor Liners; UltraGauge EM; Redline Tuning QuickLIFT Elite; Mobtown Offroad Locking Bed Storage Doors; Toyota Bed Mat; Toyota Bed Extender; Pop & Lock Power Tailgate Lock; ARE Z-Series Cap, SolarGard Tint; BEL Pro500; CravenSpeed Stubby Antenna; Amsoil Lubricants; Adam's Detailing Supplies
    You're welcome!
    FWIW, Owner's Manuals and Warranty & Maintenance Guides are available for download from the Toyota Owners' Web Site.
  2. Sep 16, 2013 at 5:48 PM
    #42
    TacoMan1911
    TacoMan1911 Well-Known Member
    LA
    2015 TSS DCSB Black DENALI EATER
    I have an 08 reg cab base and I changed mine with mobil 1 75w 90. Took 4 full quarts until full. Anybody know what the specs call for as far as quantity or past experience?
  3. Sep 16, 2013 at 6:06 PM
    #43
    Norton
    Monument, CO
    4 quarts sounds like a lot of oil for a differential, but you'll probably get more relevant responses to your question in the 2nd Gen. Tacomas forum.
  4. Sep 16, 2013 at 6:10 PM
    #44
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    Idk what the specs are but im for certain it isnt 4qts. Was the truck anywhere near level when you pumped it in.
    Edit: seems as though that is about correct, 3.4qts. By the time you leave a little in each court you would be right on.
  5. Sep 16, 2013 at 6:13 PM
    #45
    TacoMan1911
    LA
    It is a second gen., and the truck was perfectly level in my garage. The book says 3.5, but at that much the diff was no where full. At exactly 4, the oil started to slowly come out of the fill hole. How much does your truck take?
  6. Sep 16, 2013 at 6:22 PM
    #46
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Yea i know, i corrected. If your pumping it in you leave quite a bit in each qt which i add to the next qt and then at the end i have what should be in your case .5qt left over. Mine has the locker and only takes like 2.5qt.
  7. Sep 17, 2013 at 6:37 AM
    #47
    jlove1974
    jlove1974 Active Member
    Charlotte NC
    03 Tacoma 4WD 5SPD
    redline racing oils
    Not sure about a Gen 2 Taco, but my non-LSD 3.90 geared Gen 1 rear end held right around 3.75 qts. Of course, I pumped it from a gallon container and there was some left in the pump. Fiddling with all those quart containers doesn't work well with transmissions/transfer cases so I only buy gear oil in gallon jugs now.
  8. Sep 18, 2013 at 2:06 PM
    #48
    Backinblack03
    Backinblack03 [OP] Well-Known Member
    Brian
    VT
    2003 Xtra cab 4x4 2.7/5spd
    ABS? What ABS?
    Typically old-school, you can fill the case until it starts to run out the fill hole... Works on boat lower units all day long... Not sure if over-filling will cause any damage on the truck though...
  9. Sep 18, 2013 at 4:13 PM
    #49
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Thats how i do it, i just keep a talley to see how close i actially got to the number. If your truck was really unlevel and you crammed a bunch in there you would problay blow the axle seals out is all if it didnt burp through the breather.
