Recommended Oil
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BAA4700, Feb 24, 2015.
  1. Feb 24, 2015 at 4:23 PM
    BAA4700
    BAA4700 [OP] Active Member
    Rob
    Marana, AZ
    '13 PreRunner V6 4.0L
    Bull-Bar, Nerf Bars, 17" Helo 825 Chrome Wheels, Pro Comp 2.25" Front Leveling Kit, Daystar 2" Rear Lift, ... ask and I'll tell ;P
    I purchased my 2013 Tacoma PreRunner V6 Doublecab back in November(3 months ago) and so far I love it. The best truck I have ever driven/owned. It is now about time to change the oil and I noticed in the manual it recommends 0W30 or 5W30. I could see using those if I still lived in Minnesota(go Wild), but as I live in a suburb of Phoenix and it rarely gets below 50 here(high of 68 today) I was wondering what viscosity is the best for a desert climate. I have typically used Valvoline Premium Conventional in every vehicle I have owned, and usually change it every 3k-5k miles. Different vehicles, but my Father runs 10W40 in his 01 Tahoe & 62 corvair but would use 20W50 if he could find it out here...
    Thoughts???
  2. Feb 24, 2015 at 4:32 PM
    reece13
    reece13 Well-Known Member
    North Carolina
    2010 TRD sport, 6spd, 4wd
    Toytec Coilovers, Total Chaos uca's, Wheelers aal+Bilstein 5160's. 285/70/17's, Method Double Standards. Magnaflow exhaust, GrilleCraft grille, Allpro bumper,diff breather relocate, yellow wire mod, oil catch can, weathertechs.
    I'd still run 5-30 Mobil 1. I lived in AZ for a while (chandler) and ran this in my old Tacoma. Never skipped a beat.
  3. Feb 24, 2015 at 4:44 PM
    SxSW
    SxSW Well-Known Member
    Joe
    NM
    14 Base
    Use the oil viscosity in the manual.
    Internal engine temps are far above air temps.
    Many modern racing engines use -20 oils because they run tighter bearing clearances and it helps reduce friction and drag.
  4. Feb 24, 2015 at 4:49 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    I run 5w-30.
    Mobil1 mainly. Switched to Pennzoil Platinum this time around. PenPlat seems to have made truck's tick less noisy (subjective).
  5. Feb 24, 2015 at 5:03 PM
    aaronc7
    aaronc7 Well-Known Member
    Aaron
    Navarre, FL
    2013 DCSB 4x4 TRD Sport
    Normal street driven vehicle, no reason to go with anything significantly thinner or thicker than what the manual calls for. High quality 5w30 and be done with it, IMO.
  6. Feb 24, 2015 at 5:08 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    Mobil 1 seems to be the choice for TW
    Trying it for the first time this weekend. I'm expecting 10+ mpg increase, flames out the exhaust and women taking their tops off as I drive by.
  7. Feb 24, 2015 at 5:19 PM
    kullin
    kullin Well-Known Member
    Scott
    Denison Tx..
    2015 Toyota double cab
    None Yet :)
    They may not have told you but you get free oil changes till 25,000 miles.. Check it out!! :)
  8. Feb 24, 2015 at 5:25 PM
    aaronc7
    Aaron
    Navarre, FL
    ^^ oh I am well aware of that. Toyota dealer calls me once a week or so. I keep telling them I am not interested (more convenient for me to just change my own oil at home)..but they won't give up, lol.
  9. Feb 24, 2015 at 5:32 PM
    reece13
    North Carolina
    It will give 15 extra HP too.
  10. Feb 25, 2015 at 6:59 AM
    BAA4700
    Rob
    Marana, AZ
    i would if i could lol I bought it used with 39,500 miles on it, but i plan to run 'er til the wheels fall off :eek: haha. like i said earlier, the best truck I've ever driven/owned. :D
    As far as the brand goes though, is there any one brand that y'all recommend for your Tacomas? Like I said, I've always used Valvoline PCO, but idk much about oil lol
  11. Feb 25, 2015 at 7:04 AM
    CRU
    CRU Well-Known Member
    Seminole Cnty, FL
    07 SSM TuRD Sport DCLB
    20" Enkei WT4 wrapped in Bridgestone Dueler A/T Revo 3 265/50, Steel braided brake lines, Pioneer AVH-X5500BHS deck w/JBL GTO cones, OEM Smoked headlights, OEM LED tails, Clazzio seat covers, aFe Pro-Dry S air filter, Fumoto oil valve, Grillcraft MX grille w/Land Cruiser "TOYOTA" emblem, Redline QuickLIFT hood struts, Leather TRD shift knob, 13" shorty antenna
    It does in Gran Turismo 5, so why wouldn't it in real life? Did an oil change on a used car I bought and the HP went from 365 to 380.
  12. Feb 25, 2015 at 8:26 AM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
    Welcome & congrats on buying a great truck.
    Check out the oil change thread in the Technical section. Very good info. It's an easy oil & filter change if you decide to do it yourself.
    As far as oil brand, you certainly can stay with Valvoline products as long as it will meet the OEM requirements. The owners manual has that info as well. Stay with the viscosity recommendations in the manual and you'll be golden.
    Lots of people use synthetic oil because it doesn't break down as quickly as conventional oils.
    Good luck.
  13. Feb 25, 2015 at 8:36 AM
    edm3rd
    edm3rd Well-Known Member
    Duke
    Memphis TN
    09 PreRunner AC 6sp
    hard tonneau,scangauge
    Beware if this is your first Tacoma oil change - if previous user/tech did NOT oil the filter gasket, it will probably take a filter band/wrench to get it off. Normally, if lubed, it comes off easily by hand.
  14. Feb 25, 2015 at 9:10 AM
    Mizzouborn
    Mizzouborn Well-Known Member
    Tampa, FL
    06 Tacoma PreRunner
    Thorley Headers Dual Exhaust Flowmaster 40s Bilstein Shocks/Struts K&N Air Filter
    5W-30 AMSOIL Signature Series for the past 158K miles...no issues.
  15. Feb 25, 2015 at 12:15 PM
    kullin
    Scott
    Denison Tx..
    None Yet :)
    I change my own oil also but I let them do there other free stuff also so it will be on warranty record so there wont be any issues..
  16. Mar 21, 2015 at 12:50 PM
    BAA4700
    Rob
    Marana, AZ
    The only thing i didn't have for the oil change (1st time I've ever seen this) was a 5/16" hose to drain the oil from the filter drip pan. I have one now, but i ended up holding a soup can under it to catch the oil so it wouldn't overflow...that would have been one helluva mess :goingcrazy: lol
  17. Mar 21, 2015 at 12:59 PM
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I run Pennzoil Platinum. It's the last "true" synthetic available on the market. It is not made from cracking base oil. Pennzoil Platinum is made from natural gas I highly recommend it.
    Just IMHO I'd avoid all the Amasol marketing hype. They have little to no independent data backing up any of there claims. It's a snake oil type company that relies on it's magical properties and out the garage door sales to get by. I'm not knocking their products because I don't want to get into that but I always avoid companies that operate like that to try and get a premium price.
  18. Mar 21, 2015 at 2:49 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Not to cut hairs, but it's Amsoil.
    I won't comment on their marketing, but will say that in my area you must buy from an individual distributor - usually a husband/wife operation that just happens to be miles away or a repair shop selling Amsoil products at ridiculous prices.
    Comparing Amsoil to Mobil-1, Red Line; Royal Purple is also another discussion I'll shy away from. They will all lubricate your engine quite well I'm sure.
    I prefer time-tested, widely available oils to be found on the shelf at places likes Walmart. Many to choose from at a much more reasonable price.
  19. Mar 21, 2015 at 3:14 PM
    Clearwater Bill
    Billy
    Largo Florida
    +1.
    Boutique oils are like any other boutique item. Over priced.
    Folks can snicker at Walmart all they want. They have some of the quality products like Mobil 1 and Pennzoil platinum, as well as Shell Rotella. All of which are excellent choices.
    To the OP. The 0-30 will give a bit more start up protection, which is the hardest time in the engine's life. It functions exactly the same as the 5-30 once it's a bit warm.
  20. Mar 21, 2015 at 3:39 PM
    Monkeybutt2000
    Monkeybutt2000 Well-Known Member
    Jesus Christ man I just launched Bud Light out my nose! And yes oil is a very subjective discussion. Example,my Step-Dad purchased a new 93' Dakota,and ran regular old Penzoil in it it's whole life. He's the kind've guy who would start the truck no matter what temperature,put in gear and go. I bought that truck with 195k,and drove it to 215k,using the same oil. Truck ran like new and would've drove it anywhere. Point is use a quality oil and change it on a regular basis. I like Walmarts Super Tech synthetic brand.
