Recommended Part Brands
Discussion in 'Technical Chat' started by stefanlg55, May 26, 2020.
  1. May 26, 2020 at 5:14 PM
    stefanlg55
    stefanlg55 [OP] Toyota Master Technician
    2008 Tacoma TRD OffRoad
    I decided to make a list that will show the brands that Toyota uses so you can save some money while still purchasing oem quality. Some parts may not be the brand that Toyota uses but in my opinion is very good quality and comparable to factory.
    Green OEM
    Blue Non OEM
    Door Lock Actuator: AISIN (However they do not usually go bad the shaft on the motor needs to be cleaned where the brushes make contact)
    Drive belt: CONTINENTAL. (BANDO is oem however consumer quality is not very good)
    Belt Tensioner: INA
    Idler Pulley: NONE. All after market brands typically use subpar bearings. Better off with factory, after market /w great warranty or replacing the actual bearing with nsk, koyo, or timken.
    Brake Pad: BECK/ARNLEY daily driver section on rockauto. (Advics is oem however Beck/Arnley will ship you either Sumitomo, Advics or Sangsin, all good quality and cheaper then buying advics on rockauto)
    Brake Shoes: BECK/ARNLEY. (nbk but have not been able to locate a suppler for consumer purchase)
    Rotors: WAGNER, DURAGO. (Advics is oem but price is usually close to double)
    Drums: BECK/ARNLEY, WAGNER
    Wheel bearing: NSK
    Wheel Cylinder: ADVICS
    Radiator: DENSO
    Thermostat: AISIN
    Water pump: AISIN
    4wd Actuator: AISIN
    CV Axle: CARDONE
    Universal Joint: DANA
    Center support bearing: DANA. ( Rock Auto does not sell the 4wd version but drivetrainamerica does)
    Alternator: DENSO
    Starter: DENSO
    Neutral Safety Switch: ROSTRA
    A/f or oxygen sensors: DENSO
    Air / cabin filters: DENSO
    Fuel pump: DELPHI
    A/C Compressor: Denso. ( DELPHI is oem however the consumer clutch connector subpar and I have seen issues with it. Denso uses the oem style)
    Condenser: DENSO
    Expansion valve: DENSO
    Ignition Coil: DENSO
    Spark plugs: DENSO (However NGK is technically also, so I would get whatever deal is better)
    Power Steering lines: SUNSONG
    Rack & Pinion: CARDONE
    Shocks: BILSTEIN (there 5100 series are better for almost same price)
    Clutch: AISIN (EXEDY is very good quality and a little cheaper)
    This is only a list of some common parts I come across that require replacement, If you have one your looking at just make a post and I can chime in or try and find the OEM brand for you.
    doublethebass likes this.
  2. May 27, 2020 at 5:04 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I wonder why I couldn’t find a Denso condenser for my 2015 4.0. No parts place says there made.
  3. May 27, 2020 at 4:14 PM
    stefanlg55
    I checked it that out they should be the same part numbers, it may be that after market catalogs have not updated there info, or if i remember correctly with some parts after market is not allowed to sell them for so many years after it is released on a new model, kind of like an anti competitor thing.
    spitdog likes this.
  4. May 27, 2020 at 4:16 PM
    ZekeR7
    ZekeR7 Well-Known Member
    2018 TRD Off-Road 4x4 Quicksand
    Does this also pertain/is accurate with 3rd gen?
  5. May 27, 2020 at 4:39 PM
    stefanlg55
    For the most part they should be. I know this is correct for the 2nd gens, but on some of the 3rd gens depending on the model they did use different brands, such as the shocks are either bilstein, hitachi, or fox if im correct.
    ZekeR7 likes this.
  6. May 27, 2020 at 5:49 PM
    spitdog
    Thanks for that!:wave:
