Recommended replacement catalytic converter?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BarefootBandit, Jul 29, 2013.
  1. Jul 29, 2013 at 7:18 PM
    BarefootBandit
    BarefootBandit [OP] Well-Known Member
    TC UCA OME 884 5100 TSB+AAL 4.10 V6 6spd 285/75/16
    My cat is shot and I have to replace it by August. I don't want to take the truck to a stealership. A good friend of mine is a mechanic and I figure I'd buy the cat online and bring it to him to weld in.
    Can anybody recommend me a cheap catalytic converter?
  2. Jul 29, 2013 at 10:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I don't think there is a such thing as a cheap one...
  3. Jul 30, 2013 at 2:59 AM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Unless there is something wrong with the vehicle's engine, catalytic converters do not wear out. If the engine is burning oil or something like that they can get plugged or if they have been physically damaged, but they don't just go bad.
    I had a dealer try and sell me one several years ago on a ford truck I have. He wanted 600 dollars so I went to a muffler shop and let them do it for 100 dollars. They told me up front they do not wear out but will go bad if there is engine troubles. After taking mine off and inspecting it there was nothing wrong with it so I was out the 100 for a lesson.
    Try a muffler shop for an inexpensive one if you really need one.
  4. Jul 30, 2013 at 8:48 AM
    mbrogz3000
    mbrogz3000 Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
  5. Jul 30, 2013 at 6:37 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    Agree 100%. The biggest killer is probably a rich fuel mixture which causes overheating and melting of the catalytic converter internals and blockage.
  6. Jul 30, 2013 at 11:38 PM
    Nfurtado77
    Nfurtado77 Well-Known Member
    Just straight pipe it a budy of mine had a clogged cat on his cavalier and they just sliced it open then tore everything out and welded it back together haha.
  7. Jul 31, 2013 at 12:05 AM
    Greytacoma1
    Greytacoma1 Senior Member
    dave
    Sacramento ca
    Tacoma dc lb
    Satoshi grill, Plasti derp, Ready lift kit, Wheelers 2 inch aal, Hella 700, Wheather tech floor mats, Blueinstinct armrest cover, sockmonkey bed decal, BHLM, debadge, 35% tint front windows, OEM roof rack, OEM step bar, TRD skid plate, tacomaworld.com decal, stock antenna trimed, gorilla extended lug nuts,diff breather mod, cab mount chop, AVS window visor, spidertrax 1.25 wheel spacers, toytec sway bar relocate, extra d ring mod
    I don't think he''ll past smog like that.
  8. Jul 31, 2013 at 12:33 AM
    Nfurtado77
    Yea where I live we don't have smog ahah
  9. Jul 31, 2013 at 6:28 PM
    jtv
    jtv Well-Known Member
    Well...Just Back From Hell
    2012 V6PreRunner TRDSport
    King all 4 corners, TRD cat back, OEM 17" TRD rims, Fold-A-Cover
    I took my out and soak it in dis soap and water overnight 5 months ago. cel has not been back yet( over 8000 miles so far). Check out you tube under catalytic converter.
