Recommended replacement LCA bushings for 3rd Gen 4WD (Factory Arms)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GawainXR, May 14, 2025.
  1. May 14, 2025 at 12:21 PM
    GawainXR
    GawainXR [OP] Well-Known Member
    William
    2020 TRD Off-Road
    DashCam
    What LCA Bushings are recommended for factory lower control arms on a 3rd gen 4WD ?
    I'm having to replace almost all of my exposed suspension rubber on my Tacoma, likely due to whatever was in the detergent of the touchless car wash I was going to. I figured I should pre-emptively replace these at the same time I have the marlin's LCA brace installed.
  2. May 14, 2025 at 12:29 PM
    GawainXR
    William
    2020 TRD Off-Road
    DashCam
    Currently looking at these:
    Whiteline Front Lower Control Arm Inner Bushing Kit(16-23 Tacoma)
  3. May 14, 2025 at 12:48 PM
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    I would replace them with OEM parts (...not a fan of poly-bushings).
    Cheers
    Spuds509 likes this.
  4. May 14, 2025 at 1:14 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I’d just buy new OEM arms.
  5. May 15, 2025 at 5:32 AM
    Inyo_man
    U.S.A.
    That is what shops will tell you as well...
    However, replacing the bushings and ball joints is a relatively easy job. It can be done with a bottle jack and a vice if you don't have a press.
    Cheers
  6. May 15, 2025 at 6:26 AM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Replaced mine with the whiteline ones about 2 years ago I think and also installed the marlin brace. No issues yet.
    Just be prepared to cut out the cam bolts and replace them....I had to.
