Recommended tire pressure
Discussion in 'Wheels & Tires' started by bambooshoots, Sep 27, 2008.
  1. Sep 27, 2008 at 2:40 PM
    bambooshoots
    bambooshoots [OP] Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I just got some Bridgestone Dueler AT Revos for my DC Taco.
    LT265/75-16
    What would you guys run them at? Max pressure on the sidewall says 50psi; I've got them at 40psi right now. However my P rated Rugged Trails were set at 40psi also for gas milage. I don't remember the max PSI on the sidewall of the Rugged Trails but it was fairly close to what the numbers are on the LT Revos. I was under the impression that LT rated tires were to be run at higher pressures.
    Any tips?
  2. Sep 27, 2008 at 3:30 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
  3. Sep 28, 2008 at 7:19 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Thats how I do mine then I write the pressure on a pad I have in the console. Note that if you haul you will have to increase the psi. The pressure is based on weight, the front of my truck is 3 psi higher than the rear.
  4. Sep 28, 2008 at 7:44 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    X2!
  5. Sep 28, 2008 at 1:48 PM
    09silvertaco
    09silvertaco Well-Known Member
    Massachusetts
    2010 AC TRD Sport V6 6SPD
    i'm running my revos at 36 psi...the tire place recommended 40 psi as well, but i didn't want the ride of a load E tire. btw, max cold psi on these is 44 psi i believe...thats standard load. light truck loads are prob a bit higher, maybe in the realm of 55-60 psi.
  6. Sep 28, 2008 at 1:50 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    when i had my duelers on my 06 access cab, i usually ran my fronts at 32/33, and my rears at 30/31......rode pretty good,and mileage was still decent.
  7. Sep 29, 2008 at 10:27 AM
    bambooshoots
    Kevin
    College Station, TX
    Was that with the LT rated tires or the P rated?
    Also, the front passenger tire is leaking air somehow. The only harsh thing I've done was drive that tire into a deep pothole at slow speed in the parking lot (didn't see it; was checking out the chicky snax on campus).
    Could that have made the tire leak air? If so, how?
    I'm deciding whether or not to go to Discount Tire to get a a few Free Replacement Certificates for $28 each and come back in a few weeks to replace it or if I should just be honest outright and tell them I drove into a deep pothole and see what they can do.
    Pisses me off as the tires are only a week and a half old.
  8. Sep 29, 2008 at 10:34 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    the tires i had were the p-rated. you should probably run a bit more air in the lt tires as long as its comfortable to you and the tire wears even.
    as for the tire leaking, its possible that the pot hole could have done it, it could have pushed the bead off the rim a bit.....not likely, but it can happen,, but it could also be the valve stem(they can go bad once in a while), and if you have checked and there is nothing stuck in the tire, take the truck back and make the tire place check it.
  9. Sep 29, 2008 at 10:56 AM
    uuc328
    uuc328 Well-Known Member
    So. Arlington, Texas
    '07 FJC fender crack edition
    mine came filled with N2 and are all at 34 psi.
    seems a little low to me but i dont know where to get more nitrogen.
    appreciate the link
  10. Sep 29, 2008 at 12:18 PM
    HerNameIsLucy
    HerNameIsLucy I miss Lucy. :-(
    Equador. Don't know why.
    RIP Lucy.
    She's gone but not forgotten.
    Question along the same line, the tag on the drivers door jam has pressures for 15 inch tires, my prerunner has 16 inchers on it, and they're not what the factory put on it. Tires say "max 44PSI" but I think that's a tad high for the somewhat light 1st gen tacos. Been guessing so far, putting 38 in the front and 36 in the rear. Seems to be OK, guess time will tell for wear.
