Recommended tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BSFord, Oct 23, 2018.
  1. Oct 23, 2018 at 9:49 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I follow the placard during warm weather and add a pound or 2 in the cold with stock sized Wildpeaks.
  2. Oct 23, 2018 at 9:50 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    yes but what does the placard say for PSI? for the front and rear tires?
    shakerhood[QUOTED] likes this.
  3. Oct 23, 2018 at 9:52 AM
    shakerhood
    Southern Ohio
    30 is what it calls for on the placard
  4. Oct 23, 2018 at 9:56 AM
    BillsSR5
    bill
    2014 SR5
    so the door placard says 29psi as per what the OP stated and he thinks its too low, you say u follow the placard and are running 30psi? for the same size tires on the same truck
  5. Oct 23, 2018 at 9:58 AM
    BSFord
    BSFord [OP] Well-Known Member
    2018 TRD Sport 4x4
    Clazzio PVC Seat Covers Dashcam install TRD Pro Grill MESO Total Tail Stage 1 Tailgate Lock vled total interior light upgrade TRD Pro Shift knob N2 Designs Autostart w/ smart phone module
    Awesome! You have me convinced I definitely dont want to lose traction on slippery roads!
    BillsSR5[QUOTED] likes this.
  6. Oct 23, 2018 at 10:00 AM
    BSFord
    2018 TRD Sport 4x4
    So they do vary by trim, your OR says 30 psi?
    shakerhood likes this.
  7. Oct 23, 2018 at 10:00 AM
    shakerhood
    Southern Ohio
    No, OP has a Sport with different size
  8. Oct 23, 2018 at 10:00 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Different truck models, different tire sizes, different tire load ratings...
    shakerhood and BSFord[OP] like this.
  9. Oct 23, 2018 at 10:02 AM
    BillsSR5
    bill
    2014 SR5
    basically u can mess around with the tire pressures to suit your needs, I ran 35psi before lowering it to 32psi the handling,ride comfort a wear for me was perfect. some people will run 33-34psi fronts and 32psi rears for getting better mpgs its what u feel comfortable running, but I agree the door jam recommendations seem too low for me.
    BSFord[QUOTED][OP] and tonered like this.
  10. Oct 23, 2018 at 10:05 AM
    shakerhood
    Southern Ohio
    The engineers at Toyota come up with the recommended pressures for a reason, same guys that come up with the oil change intervals and other maintenance requirements, no reason not to trust them.
    JiminMaine likes this.
  11. Oct 23, 2018 at 10:09 AM
    BSFord
    2018 TRD Sport 4x4
    29 though??? What are they thinking over there at toyota haha
  12. Oct 23, 2018 at 10:11 AM
    BillsSR5
    bill
    2014 SR5
    yes the key word is RECOMMENDED,
    tonered likes this.
  13. Oct 23, 2018 at 10:11 AM
    shakerhood
    Southern Ohio
    I recall my previous Tacoma's taking different pressures front and rear, at least this one is the same.
    BSFord[QUOTED][OP] likes this.
  14. Oct 23, 2018 at 10:11 AM
    splitbolt
    NW Arkansas
    PSI is a means to an end...
    The stock tire placard requires whatever PSI is required to attain a 2,149 lb load rating from a P-metric or ISO/ETRTO-metric tire.
    The SR, SR5,and Sport use a P-metric; the Offroad uses a ISO/ETRO metric
    SR/SR5-P245/75/16 109SL @ 32psi=2,172 lb
    Offroad-265/70/16 112SL @ 30psi=2,149 lb
    Sport-P265/65/17 110SL @ 29psi=2,149 lb
    If you go to an LT the load requirement is reduced by a factor of 1.1...2,149/1.1=1,954 lbs.
    tonered and shakerhood like this.
  15. Oct 23, 2018 at 10:14 AM
    #35
    BillsSR5
    bill
    2014 SR5
    they take into account that the tire will heat up and in turn it raises the tires PSI higher, when I run my tires at 32psi COLD and take a drive they will heat up and the pressure rises to 34-35psi when HOT
    tonered likes this.
  16. Oct 23, 2018 at 10:16 AM
    #36
    shakerhood
    Southern Ohio
    That is correct, you are always supposed to adjust your pressure when cold.
    xxTacocaTxx likes this.
  17. Oct 23, 2018 at 10:18 AM
    #37
    BSFord
    2018 TRD Sport 4x4
    I don't know what this last bit means. Are you saying that for every 1.1 psi the load rating is actually reduced? Seems opposite of what I was thinking?
  18. Oct 23, 2018 at 10:19 AM
    #38
    BillsSR5
    bill
    2014 SR5
    mine says 30 front 30 rear
    tonered and shakerhood[QUOTED] like this.
  19. Oct 23, 2018 at 10:20 AM
    #39
    BSFord
    2018 TRD Sport 4x4
    29 front 29 rear on mine
    tonered likes this.
  20. Oct 23, 2018 at 10:20 AM
    #40
    BillsSR5
    bill
    2014 SR5
    yes that's why I came up with 32psi cold because they heat up to 34-35psi and that works for me
    tonered likes this.
