Recommended tire pressure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BSFord, Oct 23, 2018.
  1. Sep 30, 2024 at 5:33 AM
    #81
    bmg88201
    bmg88201 Well-Known Member
    Brian
    Quitman, AR
    2022 Tacoma Limited
    My door jam says 29lbs, I run mine at 33lbs. That’s just what I choose to do. Also, I think getting a good accurate tire pressure gauge is the key. Those old pencil shaped gauges are junk and a waste of time.
  2. Sep 30, 2024 at 5:40 AM
    #82
    Inyo_man
    Inyo_man Don't piss down my back and tell me it's raining.
    U.S.A.
    2023 Tacoma TRD, off-road, access cab
    As others have stated, run "the chalk test".
    Tire pressures will need to be different then the recommended pressure on the jam sticker if you have E load tires and carry the rig laden.
    Cheers
  3. Sep 30, 2024 at 5:49 AM
    #83
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Far better off using a pressure calculator properly. Chalk test won’t have you putting in enough air to account for dynamic loads while driving.
  4. Sep 30, 2024 at 10:15 AM
    #84
    Inyo_man
    U.S.A.
    Gee, I suppose I've been doing it wrong for over 40 years. My last set of Coopers lasted almost 60k miles (approximately 50/50 highway and off highway driving).
    Thanks for the tip! I'll look into it.
    Cheers
