Reconnecting lca to spindle
Discussion in 'Suspension' started by nobody4343, Feb 10, 2012.
  1. Feb 10, 2012 at 10:38 PM
    nobody4343
    nobody4343 [OP] Well-Known Member
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    hid headlights, black spyder jdm headlight housings, black jdm led spyder taillights, full led bulb swap, hid foglights, 3 inch pro comp lift, black out emblems, two 4 inch hid lights mounted behind the satoshi, wade vent visors, black westin nerf bars, black stubby antenna, k and n cold air intake, flowmaster delta 50 dual exhaust custom black tips, color matched satoshi grill with custom emblem
    I'm installing my lift got the strut tightened to the lca and tightened to the mount I took the 2 bolts that connect the lower ball joint and lca to the spindle now I can't get the bolts to thread back in I've tried jacking the lca up just picks up the whole truck I'm doing this by myself I know another person would probably make everything easier anybody got any advice or ideas
  2. Feb 10, 2012 at 10:47 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Pull down on the uca?
  3. Feb 10, 2012 at 10:49 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Trying it still seems like it won't go and hard to pull down th uca and put te bolt back in only me doing this
  4. Feb 10, 2012 at 10:52 PM
    Andrew H
    Dirty Tucson
    2017SSMDCSBTRDS
    Yeah two people is best.
  5. Feb 10, 2012 at 10:54 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    It sucks just moved out to Oceanside ca and dnt no anybody
  6. Feb 10, 2012 at 10:54 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    I used a cheater bar to pry down the uca when I did mine and my friend's lifts. Now that I think of it some, If I were to do it again I would loosen the uca bolt, then after putting the truck on its own weight and bouncing it a few times, then tighten the bolt back up. This will help lower the uca and make the ride a little better, cause the bushings won't be in so much tension.
  7. Feb 10, 2012 at 10:57 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Do you have a pry bar?
  8. Feb 10, 2012 at 11:03 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Not here at my house but I can get one
  9. Feb 10, 2012 at 11:06 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Try loosening the uca bolt first, it will help in more ways then one.
  10. Feb 10, 2012 at 11:07 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    Sean beat me to it. Definitely recommend the pry bar though.
  11. Feb 10, 2012 at 11:09 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    The actual uca bolts or just the upper ball joint
  12. Feb 10, 2012 at 11:11 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Bolt going to the frame, it will allow the uca to move freely.
  13. Feb 10, 2012 at 11:13 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Ok I'm calling it a night gnna hit it first thing in the morning now just reaserching trying to find a better easier way to do the other side then the rear add a leads should just go in no problem fingers crossed keep the ideas and advice coming
  14. Feb 10, 2012 at 11:17 PM
    S.B.
    Sean
    San Diego
    15 Taco
    when you put the leafs back together with the AAL try using 1/4" drive extension, by putting in it the hole for the centering pins and clamping the leafs together. I think I stole that form 4wd on here.
  15. Feb 10, 2012 at 11:20 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    Ya I was planning on doing that I saw that in Chris's aal write up just need to get they he front end first
    :frusty:
  16. Feb 10, 2012 at 11:26 PM
    Deltabox
    Deltabox himmie's Other Half
    Nathan
    AZ-WI
    04 4runner 4wd
    I'm not sure why its being the way you are describing. Keep prying and or jacking up or letting down the lca until you get it in position. Maybe unbolt the strut do gain some extra movement. I've done this several times now and am not sure why your having a problem. Maybe some pictures to show the angles your dealing with?
  17. Feb 10, 2012 at 11:30 PM
    nobody4343
    Jonathan
    Carlsbad, NM
    06 Trd offroad sr5
    It took me forever to get the strut in place by myself I really dnt want to pull that thing off again by myself
  18. Feb 10, 2012 at 11:35 PM
    Deltabox
    Nathan
    AZ-WI
    04 4runner 4wd
    You man not have a choice...
    Any pics to go with this issue? I'm confused as to why its "fighting" you...
  19. Feb 10, 2012 at 11:36 PM
    himmie
    himmie No.
    Sarah
    AZ-WI
    08 TRD Off Road 4x4
    Yes.
    What lift are you installing, by the way?
  20. Feb 10, 2012 at 11:37 PM
    S.B.
    Sean
    San Diego
    15 Taco
    To get the coilover in (on both trucks) I used a a prybar to lower the lca. And for the top I used the same technique for the uca.
