Recovery Formula...
Discussion in 'Off-Roading & Trails' started by gjbonner, Jul 11, 2009.
  1. May 1, 2012 at 7:22 AM
    #41
    NwiTACO
    NwiTACO Big tars, little/no bed.
    Mark
    Indiana
    05 TRD Sport
    Custom Everything, 1 Ton Axles F & R
    Recent recovery from this weekend:
  2. May 1, 2012 at 9:16 AM
    #42
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Nice. Looks like some fun trails.
  3. May 12, 2012 at 8:01 AM
    #43
    gjbonner
    gjbonner [OP] Well-Known Member
    Guy
    Northern Idaho
    07 Tacoma Off Road TRD
    Rhino Lined exterior,Fab Tech 6", 1.25" SpiderTrax spacers, Wheels painted Rustoleum Hammered Black, All Pro front plate bumper, Warn 9.5 ti winch, BHLM, Cig lighter constant on, Door beep toggle switch, Locker mod, Lock/unlock beeper Mod, Rear tailights smoked, 750w inverter with the outlets and on/off switch wired to rear of the console, Blacked out badges, blacked out rear bumper.
  4. Aug 12, 2012 at 9:34 PM
    #44
    sde780
    sde780 Well-Known Member
    In the first section of your post, a vehicle's weight is the force perpendicular to the ground no? Since you're on a hill, "Grade Resistance" will not be the same as the vehicles weight, because the hill is not perpendicular to the ground. As such, the steeper the hill, the closer the resistance approaches the vehicle's weight.
    At least that's how I understood it from my physics classes, feel free to correct me if I'm wrong :)
  5. Dec 9, 2012 at 1:17 PM
    #45
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Well Im glad someone out there takes the time to conduct such an equation before begining a recovery. I have never had to deal with some of the pictured recoveries as seen here but I have had the opportunity to pull a few mud engulfed vehicles out, including myself on occasion. I understand the risks involved with such recoveries but I have never really used such an equation to adjust my winch techniques accordingly. I generally base most of my techniques on common sense and my basic knowledge of physics however I will take what I have just read and utilize this information on my future recoveries.
  6. Feb 3, 2013 at 12:15 PM
    #46
    gtaz67
    gtaz67 Member
    greg
    las vegas
    11 trd sport 4x4
    wheels tires, not much else so far
    How many stops for hot dogs would you like to add to the calculation?
  7. Sep 5, 2013 at 11:40 PM
    #47
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
  8. Oct 24, 2013 at 8:53 PM
    #48
    MisterM70
    MisterM70 Well-Known Member
    Jack
    Mesa, Az
    2012 Super White-TRD OR SB
    -Icon remote resi 2.5 extended travel coil overs Front and Rear - Icon Billet UCA's - Icon progressive AAL's - Toyo 255/85/16 - Bud Built Aluminum 5 Piece Skids-
    I have found the OP's original post extremely helpful and wanted to learn more.
    I recently was scouting a trail head solo and got stuck. I still had cell reception and read this thread and and also downloaded the full army recovery guide FM20-22
    https://archive.org/details/Fm20-22VehicleRecoveryOperations.
    I have a TJm stealth 9000 winch, 4 shackles, tree strap, snatch block, synthetic sling, 100' extension strap, Hi-lift extreme and a snatch block. All brand new, never used other than the winch that was used once to pull a pre runner up a hill.
    I probably could have figured it out with out this info...but after attempting to use my hi lift and straps to pull me backwards, off a ledge (front of truck on sliders/belly front tires off ground) I quickly realized there was a major resistance issue that I would not overcome without mechanical help.
    Reading this article, doing some math and designing a proper rig and I was back on 4 wheels and moving forward.
    Anyone going off road should have to understand these principles and pass a test prior to heading out.
    Thanks again Tacoma world and cell reception.
    Kefka and fred_on_dirt like this.
  9. Nov 14, 2013 at 1:01 PM
    #49
    DefyInertia
    DefyInertia Saratogian
    Nate
    NorCal
    '05 DCLB 4x4 SR5#8 (white)
    Toytec Ultimate: ~3" up front via coil overs, LR UCAs, and SB delete; 2+ out back with AAL and new shocks. Leer cap, padded sleeping platform in bed
    THANK YOU for this thread; I read the whole thing. However, I think the question of baseline resistence on flat ground needs to be futher addressed.
    Why is the baseline resistence assumed to equal the weight of the loaded vehicle? This seems overly conservative (i.e., at 90 degrees (verticle) this would be an accurate calc. but on flat ground it would not be). Why not start with 10/20/30% of loaded vehicle weight as your baseline and then add in mire and other resistence adjustment factors?
    Please help me understand.
    My current winch is a hi-lift...which is rated at ~5000 to 7000 depending on the tackle you have. I'm going to go search hi-lift recovery threads.
    PS - what about rocking back and forth, suddenly slipping off/into ledges, jolts, etc....I would think inertia would come into play here but...
  10. Dec 3, 2013 at 10:56 AM
    #50
    Manwithoutaplan
    ID
  11. Dec 3, 2013 at 5:53 PM
    #51
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    how does one unstuck from sand on say beach or dune without burring my spare tire or a pullpal????
    got stuck real good on my way out of beach yesterday morning...
    i was fucking around in 2wd in some sugar and then i went to flip it in 4wd and i couldnt get out and i got out n looked and i was bottomed out big time all around....
    thank god there was one small tree about 150' out....so i winched
    but in the future......id like to make it easier....
    yes i know i could have aired down and stayed in 4wd and this would never of happened
    i thought i saw someplace something about 3 pieces of re-bar?
    but idk
    any ideas that are proven
  12. Dec 3, 2013 at 6:01 PM
    #52
    ImplicitlyAlberta
    David
    edmonton
    Pullpal??
    K just googled it nevermind.
  13. Dec 3, 2013 at 6:05 PM
    #53
    ImplicitlyAlberta
    David
    edmonton
    I've got one of these. Got one a long time ago when I was a rookie 4wheeler. I have no sand or loose enough soil around these parts though.
    Being that I just googled a pull pal clearly you don't want this.
    A hilift jack and some traction pads would probably work.
  14. Dec 3, 2013 at 6:28 PM
    #54
    brutalguyracing
    F.U> GUYZ
    broken mods
    what is that?
    u want to sell it?
  15. Dec 3, 2013 at 7:00 PM
    #55
    ImplicitlyAlberta
    David
    edmonton
    The thing weighs a ton. It would cost more to ship than its worth. They are kinda cool though with a couple different ways to use them.
  16. Dec 3, 2013 at 7:25 PM
    #56
    brutalguyracing
    F.U> GUYZ
    broken mods
    U ever used it?
    How much was it
  17. Dec 4, 2013 at 3:21 PM
    #57
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
  18. Dec 4, 2013 at 4:41 PM
    #58
    ImplicitlyAlberta
    David
    edmonton
    I probably paid $150 to $200 for it. I tried it in gravel and couldn't get it to bite very well. They are said to work great in sand. Very little sand around here though.
  19. Apr 20, 2014 at 1:25 PM
    #59
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
  20. Jun 21, 2014 at 10:24 AM
    #60
    Esckay
    Esckay Well-Known Member
    Sean
    Whale's Vagina
    2013 TRD Sport 4WD DCLB
    OME 885s, Dakars, 30" LED bar, G4 elite, auto pop n lock to pd, tint
