Recovery Gear / Expo Gear
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ross K., Jan 18, 2015.
  1. Jan 18, 2015 at 5:09 PM
    Ross K.
    Ross K. [OP] Member
    Ross
    Mechanicsburg, PA
    07 Tacoma DCSB TRD Sport
    2.5 " in Lift, ARB Front, Blacked HL and TL, Cooper 285s on DCs, TRD CAI, weather techs, 6" KC Hilites on CBI hood mounts, pioneer touchscreen radio swap, optima YT.
    Building and equiping my 07 DCSB Sport for Rausch Creek in the spring. Already have winch , tow strap, shovel and chainsaw / axe. Looking to see what I need further for recovery gear and equipment for moderately technical trails at Rausch and weekend wheeling in PA. All suggestions on specific brands / manufacturers welcome so I can get a better list of what works and what just takes up space. Thanks.
  2. Jan 18, 2015 at 8:53 PM
    SlimBo84
    SlimBo84 Some Guy
    Colorado
    '11 TRD Off-Road
    ATO front bumper, Body Armor rear bumper w/ swing arm, AP sliders and front skid, ATO bed crossbars w/ Thule M.O.A.B. basket, Warn VR8000-s, 285/70R/17 Goodyear Wrangler MT/R w/ Kevlar, 17" XD Series wheels, Fox 2.5 coilovers w/ res., Fox 2.5 shocks w/ res., AP Expo leaf springs, extended rear breaklines, VIAIR HD OBA, 2x 9.5" HID LightForce, Rigid fog lights, and much more to come.
    You can do a lot with just those items. A snatch block is very useful as well. Do you have a Hi-Lift or some other brand of the same type of jack? If you are wheeling with others (as it is always preferred) a super yanker like a Buddy Rope is good to have as well if you are working in mud/snow. Its a dynamic rope used to yank someone out of a tight spot. The rope stretches and contracts like a rubber band. I have used mine quite a few times with guys I have wheeled with. I always carry extra shackles, truck parts (usually only after I break something). I actually have extra replacement bolts for my lower shock mounts for the rear. I have rattled them off on the trail before. Make sure you have gloves too.
    Hope that helps. I had to figure it all out by experience. I wheel by myself a lot. I shouldn't but sometimes its hard to get guys out with me when I want to go and its sometimes last minute. But, all that said, I have never wheeled there before. I'm in CO. Maybe some local guys will have better suggestions for that area.
  3. Jan 19, 2015 at 4:02 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Max trax are a must for recovery
  4. Jan 19, 2015 at 8:54 AM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    An X-jack (exhaust jack) would have saved me from my last two quicksand disasters. I now have one for the next "got stuck" situation.
  5. Jan 19, 2015 at 9:37 AM
    Fifthwind
    Fifthwind Master of None
    Murph
    Lehigh Valley, PA
    Scully
    Barcelona Red 09 DCOR- Icon 2.5" ECOs w/CDC - 14" 700lb, ICON 2.0 RR Ext rears, AP EXPO pack, Diff Wedge, Diff and Skid Drop, Discoverer S/T 255/85/16, Ride-Rite Bags w/ Daystars, ARB Bull/winch Bumper, Warn 8k, ARB CMK12, Budbuilt skids, BAMF bolt on sliders BAMF diff diaper, bedlights, hoodlights, BAMF CB, etc.
    I've been to Rausch more than once, and the Maxx Trax haven't been that much of a help. I have seen the Hi-Lift jacks used frequently, hopefully you have a good set of sliders. Most frequent recovery is lack of traction due to boulder under frame member.
    Wheeling alone is not only a bad idea, but not allowed at RC. They will perma-ban you if necessary, and it is too good a place to get banned from.
    Tow strap points front and rear, and you already have a tow strap.
    Fire extinguisher. 5- 10lbs should cover you. It's your truck, not sure if insurance covers a fire while off-roading.
    After last year, I added some JB weld and make sure to carry spare fluids. Used oil will get you home and will just get dumped out during repair anyway.
    Skids if you want to attempt black trails. Most vids do not convey the experience adequately.
  6. Jan 19, 2015 at 1:03 PM
    Ross K.
    Ross K. [OP] Member
    Ross
    Mechanicsburg, PA
    Sliders are coming shortly, and at least a fuel tank skid. Hi Lift I'll pick up this week along with the snatch block and shackles. Appreciate the input, shouldn't be wheeling alone unless my buddy's cherokee grenades. Any particular brands for block and shackles. I've used Crosby gear for work and military, but I can't justify spending 150+ on a shackle.
  7. Jan 19, 2015 at 2:30 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 TUNDRA
  8. Jan 20, 2015 at 5:39 AM
    Fifthwind
    Murph
    Lehigh Valley, PA
    Scully
    10 or 20 dollar 3/4 inch d riings are fine as we only weight 2 to 3 tons and only pulling over or out of obstacles and not lifting via crane.
    Gas tank skid was last on my list as front ifs and transfer far more important. Rear diff diaper if you plan to run loaded and off your meds.
    Figure out a weight for your winch cable if you have steel cable, larger groups rarely need winch as a push can get you off a belly drag most times.
    No mud bogs at Rausch but you can go for a swim at the frog hole and have the pleasure of removing your interior to get cleaned out
