Recovery Gear on sale
Discussion in 'Deals & Coupons' started by sidetracked, Feb 1, 2019.
  1. Feb 1, 2019 at 5:14 PM
    sidetracked
    sidetracked [OP] Well-Known Member
    Folsom, CA
    1 of each
    Freshen up your recovery gear with 15% off at Sidetracked Off Road
    Synthetic winch ropes 3x8" x100' for $150 with free shipping
    Winchline extensions in 50 and 100'
    Kinetic Snatch ropes $110 with free shipping
    tow straps, soft shackles, etc all on sale.
    Hit me up or use code SNOW on the website.
    https://www.sidetrackedoffroad.com
    If your local I have smittybilt x20 10K winches with synthetic rope for $550 out the door, and i'll throw in a free soft shackle if you pay cash.
    thanks!
  2. Feb 1, 2019 at 5:16 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have a brand new Smittybilt x20 in the garage what would it take to switch it over to synthetic line?
  3. Feb 1, 2019 at 5:36 PM
    sidetracked
    Folsom, CA
    1 of each
    rope and fairlead combo should do it!
    mcharfauros likes this.
  4. Feb 1, 2019 at 6:41 PM
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    Awesome deal! Interested in some soft shackles
    sidetracked[OP] likes this.
  5. Feb 1, 2019 at 6:43 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Check what the attachment point to the winch drum is. Switching my Warn from steel to synthetic needed a new attachment thingymajig.
  6. Feb 1, 2019 at 6:47 PM
    mcharfauros
    MO
    Dumb Truck Thangs
    You talking about the puck? What line did you end up going with?
  7. Feb 1, 2019 at 6:58 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Maybe? It was a little piece that basically jammed the end of the synthetic line into the drum if I remember right. I couldn’t get a Xeon 8S locally so I bought the wire cable Xeon 8 and the Warn synthetic line.
    If you really need to know the specifics I probably still have the manual and instructions and could dig them up.
    mcharfauros[QUOTED] likes this.
  8. Feb 1, 2019 at 7:03 PM
    mcharfauros
    MO
    Dumb Truck Thangs
    No worries, just wondering since i got a deal on a warn zeon 10k, and want to use synthetic. I bought a amsteel blue line, but the drum end isnt looped like the warn spydura ends are
  9. Feb 1, 2019 at 7:05 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    Give me a minute to finish this beer and I’ll see if I can find the manuals. Pretty sure I saved them and they’re in the basement.
  10. Feb 1, 2019 at 7:12 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
  11. Feb 1, 2019 at 7:29 PM
    sidetracked
    Folsom, CA
    1 of each
    Yeah there are different drum attachments. Some use a bolt, others slide the rope through the drum, etc. My rope has a lug on it to bolt onto the drum, but you can make it work with other styles as well with a little work.
  12. Feb 1, 2019 at 7:34 PM
    motodude95
    motodude95 Well-Known Member
    Jim
    2012 MGM TRD Sport DCLB, OME 886s, 33s
    Been looking into recovery straps- I checked out your website and like the products. Quick question though- what is the difference between a recovery strap and a recovery rope? I've been meaning to buy a strap and I see you have a rope on there for 3 times as much as the strap. Are there certain situations where one is better than the other?
  13. Feb 1, 2019 at 7:58 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    3F614B22-3D65-446A-9F5A-23BBDB393E8D.jpg 81655220-65A8-41B4-8722-5951BB115488.jpg
  14. Feb 1, 2019 at 8:12 PM
    sidetracked
    Folsom, CA
    1 of each
    Hi,
    Good question. The tow strap has very little give or stretch to it and is better used when you just need to tow someone like maybe a broken Rig you are pulling out that isn't stuck. Or can be used to get someone unstuck from a simple situation that doesn't require "yanking" on them. Although a lot of us do it anyway, hard throttle yanking on a buried Rig with a tow strap is dangerous as it generates a shock load that likes to break mount points, shackles, Etc.
    That is when you want to use the recovery rope. It is elastic and stretches so there is not a harsh shock load so you can yank a stuck Rig out of the mud or snow. They also build kinetic energy and give you a greater pulling force.
    Hope that helps!
  15. Feb 1, 2019 at 8:14 PM
    crazysccrmd
    Alaska
    Aprilia Tuareg 660
    @sidetracked Your code was only 10% when I checked the price of soft shackles. Just a heads up, not sure if it’s working that way across the board.
  16. Feb 1, 2019 at 8:18 PM
    sidetracked
    Folsom, CA
    1 of each
    Thanks for the heads up, I've fixed the discount. May need to reload the page.
  17. Feb 1, 2019 at 8:18 PM
    mcharfauros
    MO
    Dumb Truck Thangs
    Appreciate it boss, I get how it works. However my Amsteel line doesn’t cave a loop on the drum end to use with the warm puck that’s jam fitted into the drum.
  18. Feb 1, 2019 at 8:55 PM
    brian3676
    brian3676 Well-Known Member
    Brian
    2008 4Runner V8
    Been on the fence for a while about a recovery rope. $106 shipped for a 1"x30' was too good to pass up though!
    Thanks.
    mcharfauros and sidetracked[OP] like this.
  19. Feb 7, 2019 at 9:35 AM
    seoulja99
    seoulja99 Well-Known Member
    E.J.
    Oahu
    2012 DCSB 4x4 V6 TX Baja (1GR-FE)
    all things mall rated
    Does the discount and free shipping also apply to Hawaii, Alaska, Guam, APO/FPO, and/or Puerto Rico?
  20. Feb 7, 2019 at 10:08 AM
    sidetracked
    Folsom, CA
    1 of each
    Yeah I can still do that for ya
    thanks!
    morgan
    mcharfauros and seoulja99 like this.
