Recovery gear question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hakabo, Dec 9, 2012.
  1. Dec 13, 2012 at 10:16 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Yes. :eek: Pretty much.
    Agreed
    Agreed
  2. Dec 13, 2012 at 10:18 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
  3. Dec 14, 2012 at 6:53 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i like the explanations. makes sense. im not against additional safety, just wondering how much yanking power you could put on this truck before really expensive stuff starts to break. one way to find out i guess heh heh heh
  4. Dec 14, 2012 at 7:03 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    I'm not an engineer, especially a materials engineer, so I can't get into the tensile strength of the frame and receiver but if I had to take an educated guess, I would say -- a lot!
  5. Dec 14, 2012 at 7:25 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    With the exception of stupidly large running starts using non kinetic straps, you will snap axles and burn up your torque converter/clutch before you damage for frame.
  6. Dec 17, 2012 at 3:23 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Well... whatdya know.
    I don't think they're made in America and proof loaded but I'd feel safe using them.
    -Our ¾” forged shackles meet performance requirements of Federal Specification RR-C-271D, Type IVA, Class 2. The working load limit is noted on each shackle. The WLL for the ¾” shackle is 4 ½ tons, ultimate yield is 57,000lbs.
    -We use standard 3/8” hitch pins that have a minimum break strength of 50,000lbs.
    -The shackle bracket is forged and has a minimum break strength of 57,000lbs.
    Good news. Works for me!
  7. Dec 17, 2012 at 5:47 PM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Some asshole stole my shackle off the back of my truck...I suggest you all keep your shackles locked up in your tool box or inside in a storage compartment.
    Doesn't matter what its rated for if its MIA when you need it! :eek:
  8. Dec 17, 2012 at 5:50 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I got a reciever with shackle from Amazon and the damn thing will only slide in about half way before getting stuck, it looks like the corners are just a hair too big. Any way to get it to fit? I thought about just sanding it a little bit, but that would be very tedious with just paper...
  9. Dec 17, 2012 at 6:18 PM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Grinder :notsure:
  10. Dec 17, 2012 at 6:31 PM
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    He took the time to email someone else and pass on my question then fwd the answer. After he asked me why I needed this info I replied:
    He answered in return:
    See below, hope this is enough info to cover your questions.
    And the info I posted was fwd'd from another employee. Well my faith is restored back in Warn but maybe not so much in that particular guy, he wasn't very pleasant.
    Yeah... I do. Sadly, as I think they look kinda cool hanging down. :cool: :poser: Haha.
    Air grinder with abrasive sanding disk or a angle grinder with a flap wheel would be my choice. A file would be my last choice but not sand paper, unless you've got a belt sander. HF sells some cheap stuff you could probably get it done with if you don't have those tools.
  11. Dec 17, 2012 at 6:53 PM
    ElTacoCaliente
    ElTacoCaliente Well-Known Member
    Charlotte, NC
    2012 Ram Power Wagon ST
    xEleventy billion on the receiver shackle, I've had the same one for 8 years now, works great!!!
    For the guy with the one that won't fit- if you don't have the $$$ for something in the way of a power sander or grinder, use a file, you'll be pleasantly surprised by how quick a file will chew through the metal! (WAY quicker than hand sanding!!!)
  12. Dec 17, 2012 at 7:57 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    First things I bought for my truck:
    ARB snatch strap (the 17.5k strap is sufficient for the Tacoma)
    Smitty receiver mounted shackle
    Extra Smitty shackles
    Don't cheap out on your gear.
    Warn also makes a receiver shackle and TJM makes shackles. Warn is USA and TJM I believe is Australia. The Smitty stuff I bought was China. FYI, if you care.
  13. Dec 18, 2012 at 4:35 AM
    DBTaco
    DBTaco Well-Known Member
    NC
    '08 4x4 TRD off road
    Do they make a shackle to go in your receiver(just the shackle)? Or does it all come attached to a receiver hitch?
  14. Dec 18, 2012 at 5:55 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    The truck weights a lot less then 6500# you could pick the whole damn thing up with a crane and a standard 2X2" draw bar.
  15. Dec 18, 2012 at 9:41 AM
    #35
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
  16. Dec 18, 2012 at 9:57 AM
    #36
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
  17. Dec 18, 2012 at 11:11 AM
    #37
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Good point - I keep my stuff behind the back seats.
  18. Dec 18, 2012 at 1:18 PM
    #38
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    You don't need the dog bone with a shackle, unless the pin is seized...
  19. Dec 18, 2012 at 5:33 PM
    #39
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    I don't think I would use just the pin for fear of bending it making it a real pain to get out on the other hand through a draw bar the shear force is close to 30,000#
