Recovery Jack for lift Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoJey, Aug 31, 2022.
  1. Aug 31, 2022 at 9:16 AM
    TacoJey
    TacoJey [OP] New Member
    Jeremy
    2017 TRD Sport
    Long time reader, first time posting.
    Just did a 2” lift and wheel tire change on my TRD Sport. Just curious what affordable options are out there for jacks. I do not have sliders or places to use a hi lift Jack. Thanks in advance.
  2. Aug 31, 2022 at 9:19 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Harbor Freight floor jack. Not light or compact but its a real jack.
    TacoJey[OP] likes this.
  3. Aug 31, 2022 at 9:23 AM
    TacoJey
    Jeremy
    2017 TRD Sport
    Any links to what you may recommend or use are helpful. Also note, this is to replace the stock one under the seat.
  4. Aug 31, 2022 at 9:26 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Harbor freight bastard jack with pro eagle parts. Mine mounts in the bed:
    Chunk, drizzoh, tonered and 1 other person like this.
  5. Aug 31, 2022 at 9:27 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You don't necessarily need to replace the OE jack with a lift. For a rear flat, it will still jack the axle just fine. Up front, you can jack the LCA or subframe. A small 2x6 shim would make up the distance if needed.
    I did replace my floor jack when I put on a new suspension because my old one couldn't get it up high enough for tire rotations. I bought a HF Daytona Long Reach:
  6. Aug 31, 2022 at 9:30 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    There might be some telescoping hydraulic options but I doubt any will fit under the seat. The difference in height needed to lift the vehicle to change a tire it's only as much as the difference in tire size /2. So a 33" tire will need a jack capable of lifting 1.75" higher assuming the lift did not extend the down travel distance of the suspension. You could put a 3" lift or no lift on the truck, the lift hight requirement is the same if the tire diameter is the same.
    Finding a jack with a large area base so that it can be used on soft surfaces is the tough part.
  7. Aug 31, 2022 at 9:36 AM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
  8. Aug 31, 2022 at 9:39 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    mic_sierra likes this.
  9. Aug 31, 2022 at 9:40 AM
    DingleTower
    DingleTower My truck is like yer truck
    Manitoba
    Pro MT - Lunar Rock
  10. Aug 31, 2022 at 9:42 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    For the very few punctures that I have had, all were fixable with a plug. The lack of compressor was my biggest issue.
    Thoroughly cutting down a tire or two is such a rare thing that you likely do not have a worry.
    Rock Lobster[QUOTED] likes this.
  11. Aug 31, 2022 at 9:45 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
  12. Aug 31, 2022 at 9:49 AM
    Wyckedan
    Wyckedan Well-Known Member
    Dan
    Woodinville WA
    2014 Stormtrooper AC 2009 Ducati Hypermotard 1100s.
    1 fully operational Death Star
    I've only ever had complete sidewall failure. In my experience I'm more likely to have that than a simple puncture.
    Project Farm just tested a bunch of floor jacks and the HF Daytona did almost as well as the Snap-On version, it's a solid jack if you have the room for it. If you keep a jack in the bed off your truck, make sure and test it every so often. Hydraulic fluid can leak and make it worthless
    Speedbird and tonered[QUOTED] like this.
  13. Aug 31, 2022 at 9:50 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I do keep a plug kit and inflator behind the back seat. :fistbump:
    My priorities are a) get off the road, B) get it as far as the next tire shop. I've had several flats, but its been over 25 years since I've last had to install the spare.
    Kind of funny discussion, my niece just had a catastrophic blowout last night. No spare in her car, but then again, she didn't make it off the freeway either. I told her parents "good. Worst thing you can possibly do is dick around with a tire jack in 80mph traffic, at night."
    71tattooguy and tonered[QUOTED] like this.
  14. Aug 31, 2022 at 9:51 AM
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    you got any details on this? what parts did you swap out?
  15. Aug 31, 2022 at 10:02 AM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    I know a Tacoma is different but i have a 3" lift on 35's on my Land Cruiser and still use the standard jack. But i do have solid axles front and rear. I just take a few 12"x12" 3/4" plywood square as a base and I'm good. Air compressor is probably a bigger issue.
    trdo-r and tonered like this.
  16. Aug 31, 2022 at 10:02 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    :hattip:
    Same here. Getting a compressor was a big step.
    I have only had a couple away from home. Most I find either from a slow leak during a pressure check or weirdly as I am ready to leave. I had a couple on the highway. Changing a tire along side the road is never fun.
    It is a good thing that your niece got out of there safely.
    RIX TUX and Rock Lobster[QUOTED] like this.
  17. Aug 31, 2022 at 10:04 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I changed a transmission in a box truck on the side of the highway. I'd rather ride Top Thrill Dragster at Cedar Point naked in a hail storm than do that again.
    That said, I've used the stock jack to pull a front tire off on a trail. I have a 3" lift with 34's. The jack will get a little sketchy but it works. Rear isn't a problem at all.
  18. Aug 31, 2022 at 10:05 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    It all depends on experience.
    The floor jack stays at home. Going with the OE jack for now.
    Thanks! I had an HF jack for 25yrs and it worked well. The Daytona has been killer though.
    stevesnj likes this.
  19. Aug 31, 2022 at 10:06 AM
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    HF 1.5ton with pro-eagle like parts from 911 Motorsports.
  20. Aug 31, 2022 at 10:24 AM
    geekhouse23
    99TacoDriver[QUOTED] likes this.
