recovery/snatch from trailer ball?
Discussion in 'Off-Roading & Trails' started by 2KTacoPr3runn3r, Jan 8, 2011.
  1. Jan 8, 2011 at 7:00 PM
    2KTacoPr3runn3r
    2KTacoPr3runn3r [OP] Well-Known Member
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    Bilstein 5100 adjustables, 2 inch top plate spacer, bilstein 5100 rears and 2 inch blocks. Flowmaster super 10 with dual 4 inch tips.
    is it bad to get pulled out/snatched by the trailer ball attached to the tongue of the bumper not to a hitch?
  2. Jan 8, 2011 at 7:11 PM
    907taco
    907taco Alaskan Assassin
    Bobby
    Alaska
    2010 BlackSandPearl 4x4
    ultimate lift kit ( toytec ) ome dakar leaf pack , w/ extended length billies, LR uca's, Pro comp 7089s, KM2's 285 70 17, neoprene seat covers, weather techs, CBI sliders w/kickout, URD ss, cab mount chop, VHT night shade tint>tails,3rd B-light. Debadged. Grillecraft grille, rear diff breather mod. CBI Moab front bumper, warn M8000 winch, HID kragens 7", Hella's micro fogs. retrofit headlights HIDS, LED solutions maps/license! 886 back up light mod,
    I have never had problem pulling people out, but not one was ever terribly stuck and did not need to jerked too hard to pull em out. I would have to say it depends on the situation. stuck up to axles in mud (the kind that just blends in with the vehicle and suction comes into play) I would not use trailer ball....i would try to get to the frame or factory pull points but not so stuck vehicles i don't see why not.
  3. Jan 8, 2011 at 7:14 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    If you pull hard enough your bumper will bend out.
  4. Jan 8, 2011 at 7:18 PM
    rhodehard09
    rhodehard09 sometimes nonsense is the only sense someone has
    tampa, fl
    09 TRD Off Road 4x4 doublecab
    3" lift, allpro u-bolt flip kit,285/75/16 km2s, hella hid lights, hid conversions for headlights and foglights, led everything, debadged, 9145 reverse light bulbs, black tail lights, black headlight mod,trail-gear rock sliders, dynomax ultra flo muffler,satoshi with custom woven stainless grill,hella 100watt floods in grill, pioneer 4100 in dash dvd player, pioneer 800watt 4 channel amp, pioneer 4way 6x9s, pioneer 4 way 6.5s, 2 rockford p3 10's,rockford power 500.1 mono amp w/bass knob, 7 pin relocated, highlift and mount in bed, diff breather mod, led bed lights, secondary air filter removed,t-rex eyelids, mefab bumper bar, muddy under carriage
    as long as you use a snatch strap and not a towing strap or chain, you will be fine. trailer ball are rated for alot more than the bullshit shackles we all use.
    whoa. i just reread your initial post. i would not attempt to snatch from a bumper mounted ball.
  5. Jan 8, 2011 at 7:18 PM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    Probably not the best option but it could work if it's your only option it could work. The bumpers aren't rated for nearly as much weight as a receiver or attaching directly to the frame if you can. It depends on what you're trying to tow from, like it the vehicle is really bogged down in mud or down a steep embankment the bumper hitch probably isn't the best place to tow from.
  6. Jan 8, 2011 at 8:01 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    ya it would be light stuff. not so much a snatch just more of a pull with a recovery strap. im just worried about that tongue bending out cus of the pressure
  7. Jan 8, 2011 at 8:31 PM
    RAT PRODUCTS
    RAT PRODUCTS Raw Strength Equipment
    Farmington, MN
    Cummins Coal Rollin SOB
    Smokin with a smarty.
    The Taco bumpers are notoriously thin, weak metal...
  8. Jan 8, 2011 at 8:32 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    That bumper isn't being held on by the most sturdy attachments to the frame. If all u needed was a small pull I guess it would be okay but if your stuck stuck or have to be pulled up a hill I wouldn't do it
  9. Jan 8, 2011 at 8:50 PM
    4x4Runner
    4x4Runner Now with more Oi Vey! Moderator
    Drunken Sailor
    Somewhere between Maine and Florida
    2017 4Runner Smashed Ass Edition
    KDSS
    Never EVER recover or attempt to recover using the trailer ball! I have to dig it up but I recall an article from Bill Burke where he talks about someone being killed.
    This is from his site.
  10. Jan 8, 2011 at 9:05 PM
    2KTacoPr3runn3r
    Andrew
    Petaluma
    2008 Dodge Ram 1500
    damn scary shit. i need to get a reciever. or a new bumper since i dont tow with my taco
  11. Jan 8, 2011 at 9:09 PM
    4x4Runner
    Drunken Sailor
    KDSS
    Get the Toyota tow package that bolts up or an equivalent bolt on receiver hitch. What ever you do do not try to recover using the ball!!
  12. Jan 8, 2011 at 9:12 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Put the strap on the frame, not the bumper, or pull from the front recovery point with a shackle. A class three hitch would be another good spot, but not a bumper mounted ball. It's not rated for anything over 1000lbs.
  13. Jan 9, 2011 at 5:27 PM
    maxamillion2345
    maxamillion2345 Make Nevada Great Again, build the wall
    Max
    Nevada
    80 series LC
    Tons and 40s
    Trailer balls have killed people. Not worth the risk.
