recovery strap questions
Discussion in 'Off-Roading & Trails' started by Tacomada, Mar 5, 2011.
  1. Mar 5, 2011 at 10:23 PM
    Tacomada
    Tacomada [OP] Well-Known Member
    TBC - Canadiana
    2010 TRD Off Road
    Hey guys. Quick question,
    On a trip and found a couple options for a recovery strap.
    2 inch by 20. 9000 tow 18000 break. Would this be adequate? Price is 35 dollars
    Or would I be better with a 3inch by 20 13500 tow 27000 break for 55.
    Thanks
  2. Mar 5, 2011 at 10:37 PM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    I'd go 2" by 20'
  3. Mar 6, 2011 at 12:39 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah. You *want* it to stretch. I had a 3" strap and Tom from Badlands 4x4 training suggested it didn't have enough stretch for lighter weight trucks.
  4. Mar 6, 2011 at 12:46 AM
    RelentlessFab
    RelentlessFab Tacoma offroad armor fabricating beast Vendor
    Eric
    Eastern side of the Sierras: Sparks, NV
    07 SR5 6mt to 03 SR5 to 08 Sport and 17 6MT TRD OR
    Myself, I like using a 2"x30ft strap, but also have a 2"x20ft strap I keep in the truck as well. Make sure its a recovery strap with loop ends, you dont want the hook end tow straps
  5. Mar 6, 2011 at 8:09 AM
    merrit
    merrit Well-Known Member
    Las Vegas
    seriously depussified oc to
    2X30 is the standard for our sized vehicles
    I use a 30 x 7/8" recovery rope it has more of a bungie effect than a strap
  6. Mar 6, 2011 at 8:27 AM
    brettb
    brettb Well-Known Member
    Brett
    Laramie, Wyoming
    '99 Tacoma
    Just wondering, why loops and not hooks?
  7. Mar 6, 2011 at 9:19 AM
    Tacomada
    TBC - Canadiana
    2010 TRD Off Road
    Thanks for the advice. The straps do have loop ends for sure. They also have 30 foot lengths which I may get instead or as well. I sent a picture of the strap I took in the store to the twlive page for anyone interested.
    Hooks are bad as they turn into projectiles if the strap becomes disconnected or breaks. That's my understanding at least.
  8. Mar 6, 2011 at 9:51 AM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    2x20 or 2x30 would be fine with double eyelets.
  9. Mar 6, 2011 at 11:48 AM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    I have 2x30 & a 3x30. I like my 2x30 better. Pic of me using my 2x30 [​IMG]
  10. Mar 10, 2011 at 10:18 PM
    Chickenmunga
    Chickenmunga Nuggety
    Hillsboro, Oregon
    08 TRD Offroad DC 4x4 (read the build)
  11. Mar 11, 2011 at 4:54 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If the strap breaks - that hook becomes a projectile and can be very deadly.
    I'd recommend a KEEPER Stretch-n-Snatch strap. If you can afford a wider one, GET IT.
  12. Mar 11, 2011 at 8:07 AM
    Chickenmunga
    Hillsboro, Oregon
    if you watch the video I post, that's not an entirely good assumption. You would want a wider strap with less ply that still matches the desired tensile strength.
    A snatch strap works off of the idea that it is going to stretch. Getting a strap that has too high of a tensile strength for the job eliminates that stretch and you are essentially yanking with a tow strap.
  13. Mar 11, 2011 at 8:10 AM
    Jreays
    Jreays Member
    Jeremy
    Ohio
    09 4x4 Sport Double
    I got a recovery 2in x 20ft recovery strap for Christmas. It doesn't have hooks. I figure I could put it over the ball hitch on the taco but how would I connect it to say a car stuck in a ditch?
  14. Mar 11, 2011 at 8:15 AM
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Selkirk, NY
    4x4 reg cab, 5 speed
    Better tires Hurcules Terra Track, trimmed front mud flaps, (access limited tonneau-took off) softopper, ats running boards, Piaa fogs, window vents, Wireless thermometer, extra bed rings, valley hitch
  15. Mar 11, 2011 at 8:16 AM
    Chickenmunga
    Hillsboro, Oregon
    Putting it over the ball is a bad idea. You can either slip off or you can shear the bolt, causing it to be a projectile.
    I currently take the ball out and put a D ring shackle in its place. Works great and I haven't found any research that says I'm doing something dangerous, so I haven't bought an actual hitch pin recovery shackle.
    You hook to the other vehicle via a tow point with a D ring shackle. If you can't find a place where a d ring shackle fits, then it's best to walk away and call the tow truck.
  16. Mar 11, 2011 at 8:33 AM
    Janster
    Jandy
    Lancaster, PA
    Not a good assumption for what?
    Are you saying the 2" strap is better than the 3" strap?
    I've owned & used Stretch-n-snaps straps for many years - including 2's & 3" straps and they stretch just fine and get the job done either way on the trails. I'd personally rather have the 3" with a higher tensile strength than the 2".
    For on the trails - you're not gonna notice much difference between the 2" or 3", but only peace of mind that you have a stronger strap to deal with the situation.
  17. Mar 11, 2011 at 10:38 AM
    Chickenmunga
    Hillsboro, Oregon
    Watch the video, it should explain what I'm trying to say.
    A 3" strap is better than a 2" strap PROVIDED that the 3" strap has less plies and both are rated at the same tensile strength.
    Having a higher tensile strength isn't a case of "it's stronger, so it's better". You are changing a dynamic pull into a static pull, introducing stress on the vehicle and danger into your pull.
  18. Mar 11, 2011 at 11:30 AM
    Janster
    Jandy
    Lancaster, PA
    So, are we splitting atoms here?
    Yeah, I tried to watch the entire video but I almost fell asleep.
  19. Mar 11, 2011 at 12:37 PM
    Chickenmunga
    Hillsboro, Oregon
    I'm just being really picky over a point that tends to be highly overlooked :D
    I found it really interesting and wanted to ask questions :p
  20. Mar 15, 2011 at 8:10 PM
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    Using a Smittybilt 2''x30' recovery strap to pull a Ford & a Jeep up a 8% grade @ the same time.:D
