Recovery Straps - Proper Usage
Discussion in 'Off-Roading & Trails' started by Agent475, Dec 18, 2008.
  1. Jan 12, 2009 at 12:30 PM
    A_Ninja_Racer
    A_Ninja_Racer Well-Known Member
    Tampa, FL
    08 PreRunner TRD Debadged
    I was at my local mud hole the other day and a guy tried to pull another truck out of the mud with a chain. That night I learned a very valuble lesson at his expense. The chain snapped at the stuck vehicle, flew up in the air and because it was still connected to the pulling truck it came all the way around and shattered his front windshield. I got lucky. I was sitting in the back of my truck and he was pulling in my direction. if that chain hadn't stayed connected to his truck It would have taken me out:eek:.
  2. Jan 12, 2009 at 12:30 PM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    Great Post :D
  3. Jan 12, 2009 at 9:26 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Over the years I have seen more things busted up by using chains in place of a strap and it's usually not because the chain failed, it is simply due to the no give shock load that occurs.
    gears and axle splines don't like that crap.
    Have also seen a few windshields destroyed when using straps were hooked to parts not intended to be used for recovery purposes
  4. Jan 12, 2009 at 10:19 PM
    nighthawk87
    nighthawk87 Well-Known Member
    how can you put one end of the strap through the other ends loop? You can only do this once, what about the other side? Geese people...
  5. Jan 13, 2009 at 3:59 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    D-rings are your friends. I carry atleast 4 of these.
    And don't forget about TREE SAVER straps!
  6. Jan 13, 2009 at 9:55 AM
    sonjay
    sonjay Well-Known Member
    I saw on the Dakar yesterday they used that same bungee strap that the Icelanders used on Top Gear. Same idea I guess on sand!
  7. Jan 13, 2009 at 11:50 AM
    Janster
    Jandy
    Lancaster, PA
    You can buy the stretchy kind. They're called "Stretch-n-Snatch" and they're made by KEEPER.
    I have a couple of 'em. They're nicer to work with than regular straps for tugging. Not as harsh on the vehicle. YOu can get a run at it and not worry about the jolt (cuz there isn't one).
    (sorry if this was already mentioned earlier, haven't read the whole thread)
  8. Jan 13, 2009 at 12:02 PM
    Snipe
    Pacific NW
    08 TRD Off Road
    Don't go cheap on shackles either folks, I run a crane and we have been seeing lots of rigging failures due the China crap that is being dumped on the market lately.
    And an old riggers trick when dealing with shackles like pictured above, turn the thumb bolt all the way in and then back it off 1/8 of a turn, it stops them from binding when the shaft gets tugged on.
  9. Jan 13, 2009 at 12:41 PM
    archerytarget
    archerytarget BTHOB
    College Station, TX
    01 PreRunner SR5
    Brush guard, KC HiLites SlimLites, Chrome tube side steps, Deck plate mod, Cobra 19 Ultra III, 2' cb antenna, Painted black stock wheels, TSC toolbox, Sprayed-on bedliner, Trailer hitch, Homemade headache rack with rear lights, spidertrax spacers, 3" OME coilover lift
    What do you mean by weighing down your recovery line?
  10. Jan 13, 2009 at 12:47 PM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    put something over it (floor mats, jackets, something that will stay on the strap and won't hurt you) because IF the strap breaks, there's at least 5000#s that is being unleashed and you don't know where it's going, and depending on where it breaks, it could be coming right for you or your truck. If you have something over it, it will absorb some of the force and will fall to the ground harmlessly...at least thats what I think is the point of weighing it down. Someone that actually knows will be here shortly :p
  11. Jan 13, 2009 at 4:34 PM
    A_Ninja_Racer
    Tampa, FL
    I think what they mean is you have 1 loop on each end. You take the loop on one end stick your hand through the loop and grab the strap emediately below that same loop and pull it back through the loop. You can do this on each end regardless of weather one end is attached to a vehicle.
  12. Jan 13, 2009 at 7:22 PM
    archerytarget
    archerytarget BTHOB
    College Station, TX
    01 PreRunner SR5
    so i have a tow strap with hooks and one of those large (2 in diameter) tow ropes with hooks. are those bad for recovery?
    And say if i was pulling someone out with a true recovery strap, it can be jerked and not break? and is it the best thing to have? should 1 or 2 be used? And how many times can a recovery strap be used?
    I'm just trying to get things straight in my head about all this...
  13. Jan 13, 2009 at 7:50 PM
    JimBeam
    JimBeam BECAUSE INTERNETS!! Moderator
    JB
    2015 Tundra
    no hooks...those are bad!
    get a recovery strap like whats being offered in the ARB group buy thread...you can yank with it a whole lot safer
  14. Jan 13, 2009 at 8:08 PM
    archerytarget
    archerytarget BTHOB
    College Station, TX
    01 PreRunner SR5
    sounds good, thanks :cool:
    is there a certain amount of times you can use the recovery strap with it being stretchy?
  15. Jan 13, 2009 at 8:10 PM
    #35
    JimBeam
    JB
    2015 Tundra
    no...but you should always inspect the strap before and after use for fraying seams etc...any damage and it should be replaced
  16. Jan 13, 2009 at 8:16 PM
    #36
    archerytarget
    archerytarget BTHOB
    College Station, TX
    01 PreRunner SR5
    alright thanks a lot
    ive used that rope with hooks a couple times and i guess i got lucky
    what kind of strap is in the ARB group buy? website?
  17. Jan 13, 2009 at 8:19 PM
    #37
    JimBeam
    JB
    2015 Tundra
    a really nice one...its on this site...look in the group buy folder for info
    its like 52 bucks but can yank up to 17K lbs i think :confused:
  18. Jan 13, 2009 at 8:30 PM
    #38
    archerytarget
    archerytarget BTHOB
    College Station, TX
    01 PreRunner SR5
    thanks man :cool:
