Recovery Straps?
Discussion in 'Off-Roading & Trails' started by Nielsen23, Sep 15, 2013.
  1. Sep 15, 2013 at 3:44 PM
    Nielsen23
    Nielsen23 [OP] Well-Known Member
    Nick
    Michigan
    2003 Tacoma Double Cab 4X4
    I recently pulled my buddy out of a mudhole that for some reason he thought he could make it through with his stock Cherokee with 150,xxx miles. I used an old chain that I had laying around because it was all I had. It's just a matter of time until it breaks and leave MAJOR damage and I need a good recovery strap bad!
    I'm a strong believer that you get what you pay for and I would like to buy a strap that will last a long time and not let me down.
    I've heard great things about the ARB recovery straps. Anyone else have any insight about other recovery straps?:bowdown:
  2. Sep 15, 2013 at 3:57 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
  3. Sep 15, 2013 at 3:59 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    I love my ARB strap. A little expensive but awesome.
  4. Sep 15, 2013 at 4:05 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    wheelers
    unless you're after overpriced boutique...
  5. Sep 15, 2013 at 4:06 PM
    PcBuilder14
    Brent
    Nor Cal
    May be expensive, but they know what they're doing. I'll never go to any other brand. You can tell a difference when you use it.
  6. Sep 15, 2013 at 4:31 PM
    KenLyns
    Belly of the Beast
    Icon also makes one, though it's a couple of bucks more than ARB.
  7. Sep 15, 2013 at 4:35 PM
    Nielsen23
    Nick
    Michigan
    It seems to be that it's a toss up between the Icon and the ARB.
    The ARB is rated for 17,500 and the Icon is rated for 18,000 but the Icon is 23 feet and the ARB is 30 feet. Not really seeing a big difference, between these 2 except for length, is it just a toss up?:notsure:
  8. Sep 15, 2013 at 4:38 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    I would go with the ARB.
  9. Sep 15, 2013 at 4:40 PM
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Go for the longer one, I've pulled people out where I needed every inch to avoid the same hole they were in.
  10. Sep 15, 2013 at 5:02 PM
    Nielsen23
    Nick
    Michigan
    Just bought the ARB!:dancingbacon:
    Thanks for the help guys, Nick.
  11. Sep 15, 2013 at 5:09 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
  12. Sep 15, 2013 at 5:22 PM
    Primo 95
    Primo 95 Well-Known Member
    Primo!
    San Antonio, TX
    2012 DCSB 4X4
    265/75/16 S/T Maxx 16X8.5 Level 8 Trackers 5100 1.75 HID, LED interior, 3" N-Fab step bars
    I had a $50 gift card to Four Wheel Parts and picked up this Pro Comp 2" x 20' 20,000lb strap for like $38. Overkill for a Tacoma, but you never know when a buddy with a bigger truck will need it.
    Always remember to properly store and thoroughly wash your straps of any mud/sand after using. These abrasives will break down the fibers and lead to pre-mature failure.
    http://www.4wheelparts.com/Winches-....aspx?t_c=18&t_s=190&t_pt=5083&t_pn=EXP220000
  13. Sep 15, 2013 at 5:26 PM
    Spoonman
    Jamie
    Alberta
    Doesn't matter what truck is bigger...the straps needs to be correct for the lightest truck. (Usually the tacoma) to utilize the kinetic energy created
    Good advice on keeping the straps clean. I clean mine every time it gets muddy. eww muddy straps.
  14. Sep 15, 2013 at 5:30 PM
    Nielsen23
    Nick
    Michigan
    Yeah Spoonman, I got the ARB 705.
    Thanks for the help man!
  15. Sep 15, 2013 at 9:12 PM
    BradyT88
    BradyT88 Well-Known Member
    Just make more kinetic energy with some slack and the skinny pedal ;) haha
    Does the few thousand pounds between the straps really make that much of a difference?
  16. Sep 15, 2013 at 9:16 PM
    User Name01
    User Name01 Little boy from FairyTale Land
    Bolbi Stroganovsky
    Wherever the next wind project is
    TRD Sport Barcelona Red Metallic Dbl Cab 4x4
    I have some strap that I got from a refinery. It is a 30' overhead cary strap with a 30,000lb rating. Pretty good.
  17. Sep 15, 2013 at 9:47 PM
    PcBuilder14
    Brent
    Nor Cal
    A strap that isn't rated for you vehicle weight doesn't work as well. It may be stronger, but it also is built to stretch under heavier loads than our trucks could ever produce.
  18. Sep 16, 2013 at 1:50 PM
    Madjik_Man
    Colorado Front Range
    Can someone sum up the best options for a 1st gen?
    My recovery strap is 20 years old and has seen MUCH better days.
  19. Sep 16, 2013 at 2:40 PM
    KenLyns
    Belly of the Beast
  20. Sep 16, 2013 at 3:35 PM
    BradyT88
    So what would be the ideal breaking strength for say a 5000lb pickup? Like 10,000 lbs?
