Recovery Straps?
Discussion in 'Off-Roading & Trails' started by Nielsen23, Sep 15, 2013.
  1. Sep 16, 2013 at 4:52 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In theory the breaking strength of the strap should be lower than the breaking strength of the recovery point on the vehicle. A broken strap is better than a metal shackle or hitch end flying like a projectile. Are any of your recovery points stronger than 9 tons? :D
    Of course, the strength of the strap can decrease with factors like off-angle pulling (strap riding on some sharp edge) and contamination.
  2. Sep 16, 2013 at 4:57 PM
    Blueitrgsr
    Blueitrgsr Well-Known Member
    Brad
    Gainesville, Fl
    2006 Reg Cab 4wd
    Some bilsteins, OME 885's, and an AAL.
  3. Sep 16, 2013 at 5:13 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    meh...... I would never go with a 20k rated strap or lower ever.
    mud can exert 100lbs of holding force per sqft of interference
    Ive seen a Tacoma stuck in the mud so bad two trucks or a 8k winch by itself couldn't move it. Ill stick with my 30k straps so no matter what I'm safe if I use common sense and use proper throttle control. It's not like every truck I wheel with is a midsized light Tacoma. If I had plenty of room and spare cash I might buy a more springy strap rated for less and carry both, but until I hit the lotto Ill go with the heavy stuff. I would also rather use my 7/8" shackles then 3/4" but you can chock that up to being paranoid.
  4. Sep 16, 2013 at 7:56 PM
    BradyT88
    BradyT88 Well-Known Member
    What's the frame rated for?:cool: haha
  5. Sep 18, 2013 at 10:35 PM
    Man Overboard
    Man Overboard Member
    2005 SR5 Prerunner
  6. Sep 24, 2013 at 11:00 AM
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    I have an ARB 17500 lb 30 foot recovery strap. Pulled me n my buddies out of many a bad spots :)
    I did a lot of research before I purchased and that seemed to be the best value and quality for the money. If i recall correctly, I got it for $60-70 off Amazon
  7. Sep 24, 2013 at 11:36 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    On a side note. We are thinking of coming out with a Heavy Duty Strap about 3 feet long for use when someone else's vehicle does not have any recovery points. It would allow you to wrap it around any point on the vehicle, and then hook to your Recovery Strap, to prevent damage to your nice strap.
    Would anyone be interested in this?
  8. Sep 24, 2013 at 12:02 PM
    XXXX
    sKiP
    05 Prius
    Sounds good. Maybe 2" wide and a little thicker would be better than 3" wide. On vehicles with no recovery points I find it hard to get my 3" strap wrapped around stuff. Had to use a wheel on a Scion because it was to wide and had to use a axle on a Eagle talon the same winter. I'm using your guys 3" wide tree strap for that stuff.
  9. Sep 24, 2013 at 12:09 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Yep, I was thinking 2" wide HD material with larger eyes so you can loop it through itself easier if needed.
  10. Sep 24, 2013 at 12:11 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    :thumbsup:
  11. Sep 24, 2013 at 12:14 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
    The truth is that you will never be fully prepared with a single strap. at the minimum, it's good to have a single properly rated tow strap, and properly rated snatch strap (or kenetic rope equivelant).
  12. Sep 24, 2013 at 1:36 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    x2
  13. Sep 24, 2013 at 1:53 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    As far as shackles go, get the good forged alloy ones, i have one of those in 3/4 and a no name forged carbon one in 3/4. The alloy one is rated for 14,000lbs and the cheap one 9500lbs. I have also had good luck with the Smitty built 2"x30'x20,000lb straps from 4 wheel parts.
  14. Sep 24, 2013 at 2:01 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Shackles... Crosby or CM
  15. Sep 24, 2013 at 2:04 PM
    #35
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Bubba Rope for the win.
    Flippin love mine
    You can see a shit load of videos out there with guys stuck deep in mud using the bubba to get them out. Rope holds up and stretchs perfect. This helps both the person stuck and the guy/gal doing the pulling.
    HS did a special on them a while back thanks to me :)
    Link to Bubba Rope site, check it out
    http://www.bubbarope.com/
    Flat straps were never my friend but were certainly affordable.
  16. Sep 24, 2013 at 2:23 PM
    #36
    MonkeyProof
    SoCal- SGV
    Bubba rope is ideal for mud, but not for rocks
  17. Sep 24, 2013 at 5:45 PM
    #37
    colinb17
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    mmmm, crosby.
    our company policy states that we only use crosby hardware on our project sites. at least up to the point that crosby doesn't make anything big enough. best shackles money can buy.
  18. Sep 24, 2013 at 5:49 PM
    #38
    chipnoreo
    Anna
    Alaska
    Ram Eco Diesel
    I'd be interested.... so many people are so unprepared... and then I have to figure out how to attach to their car. "so uh... i can get you out. you might not have a bumper when i am done....."
    I have a pretty basic recovery set up. so far has been enough. In it I have,
    -snatch strap
    -tow strap
    -multiple shackles
    -pin to stick in the two hitch for the guys who don't have a rear recovery point....
    -front and rear points on my truck
    -shovel
    Like i said basic, but covers all the major bases. :)
  19. Sep 26, 2013 at 12:01 PM
    #39
    Erik65
    Erik65 Dog slave
    Erik
    Oxford, MA
    2011 Timberland Mica TX Pro DC
    Stainless exhaust, 16" TRD wheels, 285x75x16 MTR Kevlars, Icon Stage IV, Icon Secondary shock hoop with adjustable remote reservoir bypass shocks, ATO shackle flip kit, AP U-bolt flip, AP Skids (IFS, transmission, T-case, diff cover)
    Why's that?
  20. Sep 26, 2013 at 1:57 PM
    #40
    XXXX
    sKiP
    05 Prius
    thunk about it
