Recovery Straps
Discussion in 'Recovery' started by Albinator, Jan 27, 2016.
  1. Jan 28, 2016 at 9:08 AM
    Nighthawk
    Nighthawk 'streme spoats
    Levi
    Casper Wyoming
    2008 Red TRD OR AC V6
    Bilstein 5100's w/ Eibach coil overs in front (set at 3" of lift). Front diff drop kit. Extended Bilstein 5100's in the rear. Deaver 2" AAL in rear w/ axle shims. 285 x 75 r 16 Goodyear Duratracks. Wheelers steelies type B, AFE cold air intake. Sway bar delete. All Pro Apex front bumper (rattle canned Rustoleum primer + flat black). Plasti-dipped emblems. Mud flaps removed.
    It sounds like the type of recovery the OP would be involved in is unlikely to be sketchy. As long as you know what points you can and cant pull on, these straps are fine. They look awful close to the one I use on a pretty regular basis, and that's just a strap I picked up from Murdoch's for 20 bucks.
  2. Apr 6, 2018 at 6:36 PM
    bangin4WV
    bangin4WV Well-Known Member
    Rocky
    WV.
    2016 SR5 2.7 MGM ACLB
    33s/sliders
  3. Apr 7, 2018 at 5:34 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    I hadn't seen those before but it looks like they should work.
    bangin4WV likes this.
  4. Apr 7, 2018 at 5:58 PM
    bangin4WV
    Rocky
    WV.
    33s/sliders
    I lived in Wenatchee for 13 years, you close?
  5. Apr 7, 2018 at 7:04 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Tri-Cities
