Recovery Tow Anchor Points
Discussion in '2nd Gen. Tacomas (2005-2015)' started by NAYo2002, Nov 1, 2010.
  1. Nov 1, 2010 at 7:07 PM
    NAYo2002
    NAYo2002 [OP] Well-Known Member
    Great Falls, MT
    '09 Tacoma 4x4 TRD Off Road
    Michelin LTX A/T2, TRD Skid Plate, WeatherTech DigiFit Liners, OEM Bed Extender, OEM Bed mat, Advantage TorzaTop Trifold Tonneau, Pop & Lock PL5300
    I searched all over the forum about this but couldnt find the info I was looking for. Can someone tell me whether or not I can use the points circled in red as anchors for towing someone out? I find it curious that I have a tow hooks in the front but none in the rear. I plan on using a D-ring for the point on the second pic.
  2. Nov 1, 2010 at 7:13 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Absolutely not!!!
    You've got a hitch....use it. Do you have a draw bar?
    If not, get yourself a draw bar to put in your receiver of your hitch.
    Get yourself a d-ring like this:
    Put the D-ring inside the hole where the ball mounts.
    You can use that as your tow point.
  3. Nov 1, 2010 at 7:15 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
  4. Nov 1, 2010 at 7:20 PM
    loaderman82
    loaderman82 Well-Known Member
    Dalton
    Flippin, AR
    2008 Off-Road
    They make a shackle that is just for this! Here's a pic of one.:)
  5. Nov 1, 2010 at 7:20 PM
    ImpulseRed008
    Susan
    SC
    08 PreRunner SR5 V6 w/tow pkg
    ^ x3 absolutely not.
  6. Nov 1, 2010 at 7:22 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    I think those holes are to hang the chains on when you have a trailer hooked up. Please for yours and everyone elses safety do not use them as a recovery point.
  7. Nov 1, 2010 at 7:22 PM
    jandrews
    '09 FourDubDee TRD OR
    Lord no, not unless you want to damage your expensive hitch and possibly hurt people.
  8. Nov 1, 2010 at 7:27 PM
    Janster
    Jandy
    Lancaster, PA
    Those drawbar d-ing combos are cool but sometimes its cheaper to buy the draw bar & d-ring separately especially if you go to a farm/home center type shop.
  9. Nov 1, 2010 at 7:39 PM
    Airun
    Airun Well-Known Member
    Aaron
    Show Me State
    TRD sport, DCLB, 4wd
    Debadged, custom emblem, Husky liners, custom bedrail Yak Trak setup with load bars, , BakFlip Fibermax, OME 3" lift with LightRacing UCAs
    My safety chain hook points are severely deformed from the aforementioned procedure, but this is on my T100. Worked great the several times I've done this, but yeah definitely not a great idea.
  10. Nov 1, 2010 at 7:43 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Buy that shackle/receiver thing. Don't use those holes circled in the picture, they will bend and/or rip... ask me why I know.
    idahodesert likes this.
  11. Nov 1, 2010 at 7:49 PM
    NAYo2002
    Great Falls, MT
    So we have no factory recovery points on the rear of our "off road" trucks? Weak! Also, I've heard it's bad to use the front tow hooks since the gears aren't meant to pull heavy loads in reverse.
  12. Nov 1, 2010 at 7:53 PM
    Jason'sLawnCare
    You could just put a pin through the hitch and put a strap around that.
    The front recovery hook not the ideal place to use if you are doing the recovering. If you are being recovered from there it should be fine.
  13. Nov 1, 2010 at 7:53 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    yeah pull people out in drive.
  14. Nov 1, 2010 at 7:54 PM
    nvdeserted
    Reno, NV
    If you're pulling someone out it's better to hook them to the rear of your rig.
    Avoid pulling in from the front if you can, but I've done it plenty of times with no bad results.
  15. Nov 1, 2010 at 7:58 PM
    ajohnson
    ajohnson Glamour Shot
    Andy
    Charlotte, NC
    07 DCLB TRD Sport Prerunner 4x4
    Things and stuff and such
  16. Nov 1, 2010 at 7:58 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    due tell:confused::confused::confused::confused:
  17. Nov 1, 2010 at 8:25 PM
    Airun
    Aaron
    Show Me State
    Yeah "do tell."
  18. Nov 1, 2010 at 8:29 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    That would work in a pinch, but I would avoid using a pin like that. It's easy to bend the pin without the drawbar in place.
    It'll probably get you unstuck, but have to torch the pin out.
  19. Nov 2, 2010 at 1:42 AM
    island808
    island808 Me l've got brains.
    Jedediah
    hawaii
    '10 6speed 4x4 access cab
    I did use those in a pinch with my GMC.. it severely deformed them just to hold me from sliding as I backed up (2wd truck on a bank near a cliff wet grass rain, and a big root that was slick as shit to get over)
    They're 1/4" steel and they wont rip but they are strictly for your safety chains.
  20. Nov 2, 2010 at 1:50 AM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    Um, isn't the usual hitch pin for a tacoma 5/8's?
