Recovery tow hooks
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoforever, Oct 31, 2019.
  1. Nov 3, 2019 at 4:17 PM
    Tacoforever
    Tacoforever [OP] Well-Known Member
    Kenneth
    Northwest Indiana
    2007 Tacoma TRD Sport double cab 4x4
    Lifted, 3" Icon UCA's Icon coilovers and shocks. Custom leather interior LED light bar, LED fog lamps, oversized tires.
    That's a nice setup!
  2. Nov 3, 2019 at 4:30 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Thanks
  3. Nov 3, 2019 at 4:41 PM
    Tacoforever
    Kenneth
    Northwest Indiana
    That's an awesome hidden hitch. You made all those brackets handmade?
  4. Nov 4, 2019 at 4:36 AM
    rnish
    Tacoma 2nd gen
    I prepped and painted everything. It was all bought off the interweb.
  5. Nov 4, 2019 at 6:12 AM
    Juisebocks
    Juisebocks Commander of the Inglorious Badger
    Drew
    2015 SR5 2.7L AT OPAF,DTF&PITA
    "Stock+"
    Who makes those brackets?
  6. Nov 4, 2019 at 12:20 PM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
  7. Nov 4, 2019 at 12:38 PM
    andrew61987
    andrew61987 Well-Known Member
    2008 Access Cab 4WD, 2.7L 5 speed
    I would at least put a carefully measured sleeve/bolt spacer on those bolts inside the crossmember. A nice and thick one that fits snugly over the bolt. That would allow you to torque the bolt against the sleeve in a way that wont want to bring the crossmember out of square. It will also halve the pull-out forces on the bolt hole by distributing force across two sheets of steel instead of just one.
    I wouldn't pull with it as is.
    Tacoforever[OP] likes this.
