Recovery Treds _DEALS_
Discussion in 'Deals & Coupons' started by ramonortiz55, Nov 10, 2015.
  1. Nov 10, 2015 at 11:39 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    I saw this link being posted in other forums:
    https://www.kickstarter.com/projects/evolvenpd/tred-pro-total-recovery-and-extraction-device-for
    Apparently you can buy a set of Treds from an upcoming company for 50% off. Any guys have input or experience with these kind of purchases?
    About this project
    THE JOURNEY
    We’ve been on a journey to develop the world’s most advanced off road and 4x4 recovery device.
    There have been multiple variations of recovery ramps dating back to the first world wars where there was an aluminium track used. Since then there have been different variations with people making them out of steel, other people making them out of plastic.
    Traction boards or recovery ramps work by giving the vehicles tyres something to grip onto. Once the tyres have effectively grabbed onto the ramp the vehicle literally pops up out of the ground and out of the sticky situation. The traction board or ramp then allows the vehicle to build up momentum along the board before hitting the soft ground again.
    Recovery ramps are the best form of solo recovery for a vehicle and they’re also far safer then using highly stressed winches and other steel components that cause terrible injuries when they fail.
    In Australia most people go four wheel driving or know somebody that goes four wheel driving and TRED is one of the most common accessories.
    THE PROBLEM
    Loss of traction: When heading off road for work or play loss of traction can not only disrupt your journey but can put you and your equipment in harms way. Traditional recovery equipment requires the use of winches or towing straps either requiring fixed objects such as trees or another vehicle to tow you out. Both of which are not always readily available.
    Existing recovery ramps: One of the biggest issues with existing recovery ramps is when a user accidentally spins their wheels it can cause irreversible damage to the product that they may have paid up to $300 for. Keeping wheel spin to a minimum is one of the biggest challenges and requires a lot of skill when you lose traction in sand, mud, snow and other terrains. It instantly generates a very high heat which goes beyond the melt point of the plastic that they’re made from. As soon as that melt point is breached it starts to melt the material away removing any chance of the tyre gaining traction.
    Existing Recovery Ramps
    THE SOLUTION: TRED PRO
    Since launching the original TRED in 2012 we have received incredible feedback from our end users and direct customers, being our retail and distribution partners. Through social media, trade events, years of in-field testing and directly engaging with our customers we have aggregated this information to develop TRED Pro™
    TRED Pro™ is the world's most advanced and highly engineered all-in-one off-road vehicle recovery device, specially designed to get your four-wheel drive, ATV and equipment out of trouble when traction is lost in sand, mud or snow. TRED Pro™ is the next generation of the already hugely successful TRED™ off-road recovery device which is the worlds largest selling brand in the category. Engineered and manufactured in Australia, TRED Pro™ will out perform any other traction aid in the market. TRED Pro™ will allow you to explore with confidence, without letting traction disrupt your journey.
    The TRED Pro
    THE MATERIAL
    EXOTRED™ - Patented Dual Composite Construction For Ultimate Durability
    TRED Pro’s unique and patented composite construction, ensures that in the unlikely event that your wheels spin during a recovery, the ramp/teeth will not suffer instant catastrophic damage as has been experienced with other leading recovery ramp products. Due to the special polyolefin material blend TRED Pro's can handle high levels of flex, are highly durable and wear resistant. The mix of elasticity and tough rigid design in the main body means that your TRED Pro’s maintain a high level of pressure on your tyre to provide ultimate traction whilst still being able to take the flex of being under vehicle weight on unstable ground.
    All Terrain – 4 Seasons
    TRED Pro has gone one step further than our original TRED product to ensure both the products design and material is optimised for use across a variety of terrains and seasons. Our customers work and play in some of the harshest environments on earth and TRED Pro is designed to be there when you need it most. Sand, Mud and Snow all provide for some great fun but also offer some tricky and sometimes hazardous driving situations and TRED Pro is designed to work across all of them.
    THE TYRES
    SIPE-LOCK™ – Patented Grip Profile For Ultimate Traction
    The new TRED Pro features a unique patented grip profile, specifically engineered to engage with the one common denominator in most tires, the water evacuation channels on the outer edges, known in the tire industry as sipes, we call it SIPE-LOCK™. By using advanced technologies such as 3D scanning and CAD modelling we inspected hundreds of the biggest brand tires around the world to optimise the TRED Pro design. This feature makes TRED Pro the ultimate in traction for recovery devices. By creating a database of the worlds biggest selling off road tires we were able to use real data, dimensions and tread patterns to optimize our design more so than any other recovery device of this type in history.
    THE MOUNTING BRACKET
    The New TRED Mounting Bracket: Suitable for TRED Pro, TRED 800, TRED 1100 & MAXTRAX.
    The TRED Pro Mounting Kit has been designed to be easy to mount in a variety of ways and allows you to mount two sets of the same model (ie. TRED 800, TRED 1100, TRED Pro, MAXTRAX, and some other brands) perfectly nested. You will also be able to mount and secure a set of TRED 1100's and a set of the TRED Pro together.
    The New TRED Mounting Bracket - Suitable for TRED Pro, TRED 800, TRED 1100 & MAXTRAX
    RETRO FIT
    TRED Pro Will Fit To Your Existing Mounting Brackets
    We have designed the new TRED Pro with the same mounting points as the previous models allowing it to retrofit to your existing TRED 800 and TRED 1100 mounting brackets as well as including an updated set of mounting points to suit the new TRED Pro mounting bracket and other major brands such as MAXTRAX and other recovery ramp mounting products. Your new TRED Pro’s will simply slide onto your existing mounting brackets or bolts with no adjustment required – upgrading to your new TRED Pro’s is that easy.
    Retrofit: TRED Pro Will Fit To Your Existing Mounting Brackets (Mounting Holes Highlighted)
    TRED Pro retrofitted to original TRED Mounting Kit
    THE SHOVEL
    Improved Shovel & Handles + New Contour Ramp
    Integrated design features enhanced ergonomics and provides maximum grip, comfort and control to clear debris & obstructions for optimum TRED placement prior to recovery. The new contour ramp has been engineered specifically to hug the tyre for optimum tire traction and vehicle recovery in all conditions.
    TRED Pro Features
    Underside of TRED Pro
    ADDITIONAL FEATURES & BENEFITS
    Lower Profile - Better Stacking TRED Pro’s have been designed with a lower profile and tighter nesting to save valuable storage space. This also allows for shorter mounting kit pins due to reduced stack height, meaning less equipment protruding from your vehicle.
    Lifetime Warranty - The only off road vehicle recovery device with a Lifetime Warranty!
    Australian Made - Proudly Australian made, owned and operated by 4WD enthusiasts.
    Stealth Mode Engaged - Dual Colour Tone - TRED Pro comes in our unique New Gun Metal Grey body combined with Stealth Black teeth. TRED Pro is super functional and also looks great. For Kickstarter backers only, a limited number of Army Camouflage coloured TRED Pro’s will be available.
    WHY LAUNCH ON KICKSTARTER
    Lower Cost To Customer | Speed To Market | Direct Customer Engagement
    There are multiple benefits to launching a product via a crowdfunding campaign, however we felt it was a great opportunity to use a platform like Kickstarter to help bring TRED Pro to market in the shortest amount of time possible. We see terrific value in launching TRED Pro to the international market and leveraging Kickstarter’s worldwide popularity to find out what the market wants and engage with customers. Ultimately if we used traditional channels and processes it would take twelve (12) to eighteen (18) months before it is available to customers. To guarantee TRED Pro becomes a reality in less than six (6) months and ensure it is made available globally as economically as possible, we see Kickstarter as being the perfect proponent in raising awareness and achieving support from interested backers.
    We have already carried out the R&D phase over months and months of work and the final design is finished (unless the market intel tells are something we're missing. Another benefit of launching on Kickstarter). The funding will ensure manufacturing is accelerated and the product is brought to market globally extremely fast.
    Based on volume should particular geographical markets result in volume sales we will be able to leverage even cheaper freight via full container loads and any saving will be passed on directly to our customers, making the product even cheaper.
    Ultimately we have the opportunity based on successfully achieving the goal to bring TRED Pro to you in a third of the time and for a drastically cheaper price.
    OUR STORY
    Evolve New Product Development (NPD) was formed with a single purpose; to facilitate and guide an individual's or company's product idea from a concept to a market-ready product.
    Evolve NPD is part of a larger organisation, the Evolve Group which offers in house capabilities include consultative product design and development, prototyping, tool fabrication, manufacturing, branding, marketing, sourcing, sales and distribution. We are the pre-eminent one stop shop for new product development with a proven track record of bringing successful products to market, both here in Australia and abroad.
    WHY TRED PRO
    • SIPE-LOCK™ – Patented Grip Profile For Ultimate Traction
    • EXOTRED™ - Patented Dual Composite Construction For Ultimate Durability
    • Retro Fit - TRED Pro Will Fit To Your Existing Mounting Brackets
    • All Terrain | 4 Seasons - Sand, Mud, Snow and more
    • The New TRED Mounting Bracket - Suitable for TRED Pro, TRED 800, TRED 1100 & MAXTRAX
    • Dual Colour Tone - TRED Pro comes in our unique New Gun Metal Grey body combined with Stealth Black teeth
    • Improved Shovel & Handles + New Contour Ramp
    • Lower Profile - Better Stacking
    • Lifetime Warranty - The only off road vehicle recovery device with a Lifetime Warranty!
    • Australian Made - Proudly Australian made, owned, design, developed and operated by 4WD enthusiasts.
    TRED Pro Features & Benefits
    REWARD DETAILS
    PRO BACKER KIT
    TRED PRO BEACH TOWEL
    TRED PRO T-SHIRT
    TRED PRO MOUNTING KIT
    TRED PRO CARRY BAG
    SUPER EARLY BIRD SPECIAL
    2ND QUARTER SPECIAL
    SUPER EARLY BIRD SPECIAL + TRED PRO MOUNTING KIT
    THE TRED PRO
    VIP TRED PRO
    TRED PRO KIT 1
    LIMITED EDITION CAMO COLOUR TRED PRO
    SUPER EARLY BIRD DOUBLE SET + TRED PRO MOUNTING KIT
    TRED PRO ULTIMATE OFF-ROAD KIT
    RESELLER PACK
    SPECIFICATIONS
    TRED Pro comes in a set of two (pair). Single unit dimensions below:
    • Dimensions Length: 46 inches (1160mm) Width: 13 inches (330mm) Height: 2.76 inches (70mm)
    • Weight: 10.14 lbs (4.6kgs) Single unit
    • Temperature range: -15° to +60° C
    PRODUCTION TIMELINE
    Production Timeline
    THE TEAM
    Doggman, docloco and DrFunker like this.
  2. Nov 10, 2015 at 11:42 AM
    ramonortiz55
    Ramon
    Texas
    stock
    I AM NOT SUPPORTING OR BACKING THIS.
    I AM NOT PUSHING A GROUP BUY ON THESE.
    I AM POSTING THIS FOR A POSSIBLE DEAL.
    Is it legit?
  3. Nov 10, 2015 at 11:47 AM
    ramonortiz55
    Ramon
    Texas
    stock
    MTopp likes this.
  4. Nov 10, 2015 at 11:48 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Hm..interesting. I'm wondering if they addressed the issue of the plastic cracking and breaking. Seems like better traction and lower profile is the priority. It is interesting how they will work with existing mounting pins i.e. Maxtrax pins. I admire their solution to fix some of the existing problems with the current model and I wish they success in their campaign.
    I think I'll stick with my Maxtrax..
    tacothai, DrFunker and Unchained 5150 like this.
  5. Nov 10, 2015 at 11:48 AM
    ramonortiz55
    Ramon
    Texas
    stock
    so they were an existing company?
  6. Nov 10, 2015 at 11:49 AM
    geekhouse23
    Yes sir.
  7. Nov 10, 2015 at 11:51 AM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I'm with geekhouse23 you have to go where tried and true reliability is. If it looks to good to be true it probably is, MAXTRAX FTW
    geekhouse23 likes this.
  8. Nov 10, 2015 at 11:55 AM
    geekhouse23
  9. Nov 10, 2015 at 12:01 PM
    Pirhett
    Pirhett Instagram @pirhett_ship
    Rhett
    San Diego
    2014 TRD Sport 4x4 DCLB MGM
    Stock...
    I saw similar ^ that states these kinda boards crack almost immediately but the lugs don't melt as fast
  10. Nov 10, 2015 at 12:03 PM
    geekhouse23
    Plus the new kickstarter version still only has one ramp..I wonder when they're gonna learn :rolleyes:
  11. Nov 10, 2015 at 12:05 PM
    geekhouse23
  12. Nov 10, 2015 at 12:05 PM
    ramonortiz55
    Ramon
    Texas
    stock
    one ramp? huh
  13. Nov 10, 2015 at 12:07 PM
    Mcdees84
    Mcdees84 Well-Known Member
    Tallahassee, FL
    2014 MGM DCSB-TRD O/R
    @ramonortiz55, looks interesting. I just emailed the person from the kickstarter campaign to figure out how it works. I'll update here on the response as I'm interested in these as well. Here are the questions I asked:
    1) If you don't meet the total dollar amount of your goal, will I still receive the package I back?
    2) If not, will my money be refunded?
  14. Nov 10, 2015 at 12:10 PM
    geekhouse23
    The TREDs are directional in that they only use one ramp. The Maxtrax are twin shaped meaning they can be used in any direction. The guy in the video I posted explains it better.
  15. Nov 10, 2015 at 12:11 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Here is another question you can ask.
    are the fund prizes cumulative?
    Like if I provide funds at a tier level, do i get all the items AT that tier level as indicated, or do I get the items from THAT tier level and all the ones below it?
  16. Nov 10, 2015 at 12:11 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Thank you. The video doesnt load at work, I will try at home
    geekhouse23[QUOTED] likes this.
  17. Nov 10, 2015 at 12:16 PM
    Mcdees84
    Tallahassee, FL
    I'll ask when they respond, but I'm guessing it's not cumulative. I think you get whatever is in the package you back. I say that b/c I read the comments where guys were wanting to upgrade their investment to get a new package they offered.
  18. Nov 10, 2015 at 12:32 PM
    ramonortiz55
    Ramon
    Texas
    stock
    At the bottom of the screen, click the banner that says "new to kickstarter? here's how it works"
  19. Nov 10, 2015 at 12:50 PM
    DrFunker
    DrFunker Well-Known Member
  20. Nov 10, 2015 at 12:51 PM
    geekhouse23
    Selling point for me really..happy to share
    DrFunker[QUOTED] likes this.
