Red Bullet VVTi Solenoids GB (Primary GB CLOSED)
Discussion in 'Automotive Group Buys' started by 12TRDTacoma, May 14, 2021.
  1. Nov 2, 2021 at 11:49 AM
    #341
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    uh... what?
    Tacoma engines are single VVT. So unless you want one head to change valve timing and not the other, then you need a pair. I do not know if there is any testing or theory on doing only one pair in a dual VVT engine like the other toyota models have.
    Slashaar likes this.
  2. Nov 2, 2021 at 11:54 AM
    #342
    racebug68
    Travis
    Chandler, AZ
    I'd like you to put my name on the list. Now that we know a close approximation of price, I'd guess that there are several folks that haven't committed yet that could put their name down. Perhaps we can get closer to that magic number that gives us the next discount. It doesn't seem crazy to think that 100 people would buy these in the entire TW space, but then again it is a question of if they know about it. Although I will admit getting more than 50 additional people to commit might be a stretch.
  3. Nov 2, 2021 at 12:00 PM
    #343
    Biscuits
    Biscuits Thorny Crown of Entropy
    Swiggity swangin' biggity bangin'
    You're right. My bad.
  4. Nov 2, 2021 at 12:03 PM
    #344
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    I'll add you in.
  5. Nov 2, 2021 at 1:39 PM
    #345
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
  6. Nov 2, 2021 at 1:50 PM
    #346
    12TRDTacoma
    Rob
    Concordia
    Boosted
    kasnerd[QUOTED] likes this.
  7. Nov 2, 2021 at 2:38 PM
    #347
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
  8. Nov 3, 2021 at 8:53 AM
    #348
    racebug68
    Travis
    Chandler, AZ
    I didn't see my name on the list yet. Not sure if you forgot or missed or what
    Also, I think this GB should be linked in some of the other forums/threads again. Now that the price is somewhat known, it is easier to make a decision of cost/value/benefit and I think there will be folks who sign up. I'm not an influencer though - best done by one of you folks. Supercharger thread is a prime candidate.
    For the record, I'm still not fully convinced these will give more power than stock on the highway, climbing hills in high gear where the rpms are somewhat stable if the OEM ones are working correctly. Maybe there is some gain to be had in acceleration scenarios where the stockers are slow to respond to the signals from the ECU and thus a more accurate instantaneous cam position. But for the cost, and ruling out any mis-behavior or wear on the stockers, I feel it is worth a try. There is also a fuel economy argument that can be made, but that is a way tougher technical argument from a cam advance/retard perspective. If something is not working right with the stock ones, these could be a big improvement in economy and performance.
    04TacoRunner likes this.
  9. Nov 3, 2021 at 9:44 AM
    #349
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I'll add you.
    Some of the folks who want/ wanted in weren't super specific about wanting in when they said it, as I added the latest one yesterday which might have been why I missed you. I'll add you to the list.
    The link on the blower thread had been posted a while ago too so the guys knew about it.
    SUMOTNK likes this.
  10. Nov 3, 2021 at 7:20 PM
    #350
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    How many of us got hptuners? I plan on taking before/after logs. Are there specific PID's we should be looking at?
  11. Nov 3, 2021 at 7:57 PM
    #351
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    I want to use the HP tune so bad. Just don’t know with CA’s ecu tune law if it will be smog-able
    Sterling_vH111 and Slashaar like this.
  12. Nov 3, 2021 at 8:01 PM
    #352
    racebug68
    Travis
    Chandler, AZ
    Be careful with before/after logs for things being apples to apples. Temp changes heat soak and other things can skew readings from one run to the next more than the amount of change due to the part under test.
    I am really not sure if anything in the computer that was monitored and tune based on it would pickup anything. Could be wrong though. We aren't doing anything that changes the volume of air ingested at any given RPM, like more boost or airflow restriction reduction (intake/exhaust/porting/etc) would do. Valve lift and duration stay the same but all we are doing is changing the valve timing command vs. actual speed of implementation. I would say that the max air flow the engine can take will stay the same, and thus the fuel required to be supplied is the same. So my argument is that fuel trims, max maf numbers, etc will stay the same within the margin of error. What we are changing is the efficiency, basically the output of the engine by making sure the cam timing is where its commanded to be for peak efficiency. This might be unofficially detectable by the truck feeling faster, or requiring less pedal for a given acceleration, or you getting better fuel economy. But for a given airflow, a certain amount of fuel is required, and a given load dictates spark timing, I doubt any of those things will change for a given operating point of the engine.
    All bets are off if the old solenoids weren't working properly. And I'm sure someone smarter than me is gonna come in here and school me on why I'm wrong. But at least I took a stab at it and backed it with my reasoning.
    scootter82[QUOTED] likes this.
  13. Nov 3, 2021 at 8:44 PM
    #353
    Slashaar
    Josh
    Kansas City, MO
    honestly, I think 0-60 pulls will determine the difference. How fast it jumps into power off the line will determine how fast its opening the solenoid I'd assume from my meager understanding of how these work. I could be super wrong, please correct me if I am.
  14. Nov 3, 2021 at 8:58 PM
    #354
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    HP Tune with a bullydog carb cid (supercharged, smog legal)
    Slashaar and nudavinci64 like this.
  15. Nov 3, 2021 at 9:05 PM
    #355
    racebug68
    Travis
    Chandler, AZ
    to my knowledge it is still the same calibration ID, and thus completely invisible to the smog process. I am sure there is no check or fail based on the values in any parameter of the tune... but I don't live in CA so I don't really know. But a crap ton of Californians have the HPTuned upgrades from JustDSM... I think you need to read into it further to get comfortable with it.
  16. Nov 3, 2021 at 9:59 PM
    #356
    Murphinator
    Murphinator Well-Known Member
    Anthony
    SoCal
    14 DCSB 4x4
    I think the smog check will also check the checksum of the tune. Which will be different than the HP tuner tune. So you would just want to flash the stock trd tune back on when you go to get smogged. Come to think about it, I wonder how they are going to deal with the fact that the trd tune which is valid and the bullydog tune which is also valid are different but use the same calibration id. I guess it will have to have multiple checksums that are accepted..
  17. Nov 3, 2021 at 10:09 PM
    #357
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Their program is flawed because the manufacturer reflashes vehicles computer multiple times during the warranty period of customer ownership. Whether it be for engine management program issues or transmission shift/ shift quality issues. Of course all vehicle computers will be different than the original checksum and flash file. The fact that we had to get the TRD tune on ours and for others that did not get the TRD tune, Bullydog, makes us modified by default. CARB legal modified! :D
  18. Nov 4, 2021 at 2:09 PM
    #358
    point45
    point45 Well-Known Member
    SoCal, OC
    05 DCSB TRD offroad
    Put me down for a set please.
  19. Nov 4, 2021 at 2:16 PM
    #359
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Got you covered.
    point45[QUOTED] likes this.
  20. Nov 4, 2021 at 2:34 PM
    #360
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    when you load a tune, it changes the cid. thus is why Magnusson won't sell you a supercharger in CA w/o bullytuner so its carb compliant.
