Redarc Brake Controller Install on 2017 TRD Sport (Step by Step w/ pics)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RBaptist, Sep 23, 2018.
  1. Dec 22, 2018 at 9:28 PM
    ceng
    ceng Active Member
    Jake
    ‘19 Tacoma TRD OR Manual
    So you push the button and it applies the brakes on the trailer?
  2. Dec 23, 2018 at 8:08 AM
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    OP may weigh in with the technical details but yes, the button push is like tapping your truck brakes quickly to lose speed quickly. In case of a brake controlled it is a needed tool in event your trailer gets started into a death wobble or sway situation and you need to bring it back under control. ( Examples are being passed closely by an 18 wheeler/trailer or going down a steep grade with curves, these situations can cause sway.) For 98% of the time the controller has the ability to determine the situation and no need for a driver to touch the controller.
    RBaptist[OP] likes this.
  3. Dec 23, 2018 at 9:41 AM
    RBaptist
    RBaptist [OP] Well-Known Member
    Newnan, Ga
    2017 TRD Sport - Magnetic Grey
    It does, but it bases it on the mode that you are in. When you are towing, there are 2 modes you can put the Redarc in:
    1) Proportional Mode (Blue mode) - this is basically what is used 99% of the time. After you've dialed in the normal 'force' - when you push the pedal, Redarc scales the force of the brake from there automatically based on how fast you are hitting the pedal and decelerating
    2) User Control Mode (Green mode) - When you push the brake pedal, the trailer brake force applied is fixed based on what (numeric) value you set it to regardless of how hard you push the truck's pedal and are decelerating
    So back to 'pushing the button' - usually only used if a trailer starts swaying:
    *If you are running in Proportional Mode and hit the button, it will apply light braking to the trailer (only) without pushing the truck's brake pedal
    *If you are running in User Control Mode, it will apply the trailer brakes (only) at whatever 'force' setting you have the Redarc on (no scaling, automation, etc)
    Below is a review from etrailer where they do a (basic) demo of the Redarc. May help as well
    https://www.etrailer.com/tv-Demo-Redarc-Brake-Controller-331-EBRH-ACCV2.aspx
    stealthmode and Mountain2018 like this.
  4. Dec 23, 2018 at 10:01 AM
    ceng
    ceng Active Member
    Jake
    Thank you
  5. Dec 26, 2018 at 6:54 PM
    coarsegold1
    coarsegold1 Well-Known Member
    Having had to use the manual slider proportionally in a highway emergency in my last tow rig, this was my first thought as well. It is a super clean install, and looks like a great unit, but the "button push" idea is still a bit of a concern.
  6. Dec 27, 2018 at 6:04 AM
    RBaptist
    Newnan, Ga
    I dunno - seems to work fine. I guess the difference is pushing a button and trusting a computer vs. sliding the slider. I hit it once in (blue) mode to see how it worked and it did as advertised....put light braking on (could feel the truck decel slightly) which should stop a sway condition. I believe you can also turn it while pushing and it would dial in more or less (but I didn’t test that).
  7. Mar 10, 2019 at 9:30 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    Just ordered the redarc last night along with a switch spot for it. Plan on starting the install as soon as it arrive. I have new camper waiting to be picked up!
  8. Mar 15, 2019 at 8:00 PM
    Amanelot
    Amanelot Member
    Texas
    Finished install. Not sure if it's working. The light fades in and out blue whenever I push it. Hopefully that is normal. I'm heading to pick up the trailer tomorrow so I guess I'll find out then if it works or not.
    Such a clean looking brake controller. I'm going to love not banging my knees on a box!
    stealthmode and RBaptist[OP] like this.
  9. Mar 16, 2019 at 7:27 AM
    RBaptist
    Newnan, Ga
    That’s normal for a while with no trailer attached.
    Also When you plug up for the first time it will flash for the first 20-40 braking cycles while it learns it’s orientation. (Don’t have the manual in front of me, but the color patterns are in there). Caught me off guard the first time I towed with it but completely normal.
  10. Mar 16, 2019 at 7:54 AM
    Amanelot
    Amanelot Member
    Texas
    Awesome! Thank you for the write up. So much good info on this forum!
    RBaptist[QUOTED][OP] likes this.
  11. May 10, 2019 at 8:46 AM
    jwilson2899
    jwilson2899 Well-Known Member
    Front Royal, VA
    2017 Tacoma DCSB TRD OR 4x4, BP-51's with medum Dakars, TRD Proser, 285/70/17 KO2s
    Full on TRD "Proseur", BP-51/medium Dakar, 285/70/17 KO2's, HID/LED everywhere
    Thanks for the awesome writeup @RBaptist , I was able to get everything installed and looks/works great.
    mcharfauros and RBaptist[OP] like this.
  12. Jun 21, 2019 at 6:08 PM
    SKUNKB8
    SKUNKB8 Member
    2019 Quicksand DCLB TRDS
    none yet...
    Great job on this write up! I bought one a while ago but haven't gotten around to the install. Finding this gave me a little motivation to get it done. I'll definitely be using some of your tricks.
  13. Jul 29, 2019 at 11:17 AM
    Rocket350
    Rocket350 Member
    2019 TRD Sport MT
    Has anyone shortened the length of either harness, or just spliced as purchased?
  14. Jul 29, 2019 at 7:19 PM
    RBaptist
    Newnan, Ga
    I didn’t do it, but it won’t hurt it to do it. There’s lots of room back there behind the dash so I just coiled it and zip tied it. Figured if I took it out of the truck someday I’d have all the wire I needed - but truth be told I’ll end up selling it with the truck
    Rocket350[QUOTED] likes this.
  15. Jul 30, 2019 at 1:03 PM
    #35
    JD45535
    JD45535 Well-Known Member
    Jeff
    2017 Black TRD Sport
    Pro Comp Series 34 Wheels Falken Wildpeak Tires Rough Country Bed Cover Cali Raised LED Fogs and Ditch Lights
    Very nice write up!
  16. Aug 11, 2019 at 5:09 AM
    #36
    Rocket350
    Rocket350 Member
    2019 TRD Sport MT
    Thanks for tutorial!! Thought about moving the Clutch Start Cancel switch up but would have had to slightly modify the switch plate. May do so in the future. Cant wait to test the performance of the Redarc. Thanks again!20190803_092542.jpg 20190803_103256.jpg
  17. Oct 3, 2019 at 9:28 AM
    #37
    NorthWestTaco
    NorthWestTaco Well-Known Member
    I know this is an old post.
    Saving this for my install!
    Great write up this is exactly what i wanted to do!
    Have had this controller in the cart for months now!
    RBaptist[OP] and Amanelot like this.
  18. Oct 5, 2019 at 7:46 PM
    #38
    Amanelot
    Amanelot Member
    Texas
    Just do it, man. Love mine. Currently on a 2 week camping trip with travel trailer and it has been working flawlessly.
    Bonus: no brake controller is hitting my knee while driving
  19. Oct 6, 2019 at 11:29 AM
    #39
    NorthWestTaco
    Ordered it all the other night! it's only money right? But looked at the parts store at brake boosters and they're all over $100 and are the big boxes so why not spend a little more money and get this SUPER clean install? Will look completely stock and thats the most enticing thing about it!
    Should have everything in a week or so!
  20. Oct 10, 2019 at 7:12 PM
    #40
    RBaptist
    Newnan, Ga
    It’s a little more than some other options but it’s a really good controller *and* it looks stock. Mine is still going strong - zero complaints.
