Redarc Tow Pro Liberty
Discussion in 'Towing' started by tacomalimited23, Jan 7, 2024.
  1. Jan 7, 2024 at 9:21 AM
    tacomalimited23
    tacomalimited23 [OP] Well-Known Member
    I am wondering if anyone out there has this brake controller and pulls a travel trailer. Was wondering for an approx 4300 lb TT, what setting you run in at on the dial (0-10) with your Tacoma. And, generally a review of it. Thanks.
  2. Jan 7, 2024 at 10:10 AM
    Da Voke
    Da Voke Well-Known Member
    Canada
    2020 DCLB Sport (Stolen and recovered)
    I’ve got a liberty. My trailer is about 3500. The unit works great. No complaints. As far as setting goes, just get out on the road and adjust it so the the brake force with the trailer feels about the same as the truck by itself in normal conditions. That should get you in the ballpark. You shouldn’t feel the trailer pulling back on the truck or the truck being pushed by the trailer.
  3. Jan 7, 2024 at 10:28 AM
    tacomalimited23
    Thanks. I appreciate the info. At that weight, do you find that you keep it around the same number most of the time, like 4 or 5?
  4. Jan 7, 2024 at 12:08 PM
    Da Voke
    Canada
    I can’t remember what number but once it’s set I generally don’t touch it again
  5. Jan 7, 2024 at 1:54 PM
    Nessmuk
    Nessmuk Well-Known Member
    Bob
    Charlottesville, Va
    2.7 5sp AC w/SR & convenience pkg
    I use one and it is set to 3 or 4. I’ve never gone over that pulling out Tab 320S Boondock.
  6. Jan 10, 2024 at 2:00 PM
    tacomalimited23
    I just installed mine. I don't have a trailer attached. When I press the button on the Redarc, the light turns blue and then fades away after about a second. Is this normal when a trailer is not attached?
  7. Jan 10, 2024 at 5:10 PM
    wiljayhi
    wiljayhi “..ain’t nobody’s business if I do…”
    Jim
    Murky Water, MB, eh?
    3G, Tuned
    Yes.
  8. Jan 13, 2024 at 1:13 PM
    Max8
    Max8 Thinking Outside The Box until they close the lid
    23 SR5 DCLB stock
    2012 ARE DCU contractor cap, Transmission aftercooler kit (Iconic Fabrication & Hayden 698), Bed Stiffeners (Kwikfab LLC), Firestone airbag leaf springs, wye connector and pressure gauge, Tailgate security mod (mfgr. by Christian06 on TW), OEM mud flaps, OEM tailgate electronic lock, Tow-Pro Elite Electric Brake Controller, Anytime Backup Camera hardwired 42 ft to camper, RCI Alum. Skid plates & cat covers, 2WD LO mod (BB Tuning), Fumoto oil drain, ECT Always-On Mod (hardness by Funman1steve), 6awg DC DC tow charger wiring, inline 60 amp breakers & battery terminals, Kill switch, KJTO driver side grab handle, Hood hold open gas struts, Scangauge III, Seat Covers (Seat Covers Unlimited... wearing poorly),
    Hardwired unit, #10 12v wires back to 7 pin connector, twisted and soldered connections.
    Set to 3 to 4 for 2800lb Nucamp trailer (another 320s boondock!)
    Set to 5 to 7 for 4200lb cargo trailer depending on load.
    To test trailer ebrakes I jam a rod between seat and brake button and go back and listen/spin/volt-check ebrakes. Handy.
    To calibrate I use button to test ebrakes for wheel lock, without truck brakes. Back setting off two numbers, and test at various speeds with truck brakes.
    Morning condensation can make brakes grab badly and you need to use brakes a few times before resetting.
    Cargo weight can change setting needed.
    An infrared thermometer (point and shoot) is helpful during process of adjusting manual trailer brakes; snug without overheating.
    Varied resistance in trailer wiring left vs right can create hard side pull. Had to rebuild one trailer with separate unspliced wiring left and right from 7pin box to correct this. Easily measured with voltmeter.
