Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Jul 31, 2016 at 6:40 AM
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Recent
    F5624436-7349-4ED5-A0A7-58123A12D2DA.jpg blue holler.jpg 9646E04B-F002-459F-9FC2-8824B1F14FB2.jpg A68E655D-DFA3-4597-83FD-D18C4F0A4864.jpg
    Photo credit @Brussell56 ^^^
    Previous
    Link to previous build:
    https://www.tacomaworld.com/threads/rngrs-debatable-debacle-build.402063/
    Vehicle
    2001 Tacoma SR5 4x4 extra cab 2.7L manual. Purchased July 2016 with 54,XXX miles.
    Link to FS thread where I found it:
    https://www.tacomaworld.com/threads/2001-tacoma-sr5-4x4-only-54-800-miles.441530/
    Purpose
    Unlike the original build, this will not be my daily driver. :D This truck will be a toy and a tool. Like any tool, it is very capable of completing certain tasks, while it completely fails to handle others. The purpose of this build is to identify and modify the areas where it fails. I learned a lot from the last truck. Those lessons will play a big role here. I'll be adding pictures of what I have done so far and what I do as I go from here.
    Modifications
    Suspension-
    (Page 4-6)
    OME nitrocharger sport shocks
    OME 881 coils
    OME trim packer
    2" extended studs
    OME Dakar leaf pack
    OME shackles
    Wheelers bushings
    Extended SS brake lines
    Brake proportioning bracket
    All-Pro rear axle relocation plate
    Camburg uniball UCAs (p.58-59)
    3/8” top spacers (p.110)
    @Plastics Guy front bumps (p.110)
    Exterior/In bed-
    Snugtop shell (p.11)
    Yakima Rack on shell (p.12)
    Quick fists on Yakima Bars (p.13)
    PlastiDip shell roof (p.70)
    Color matched grille (p.28)
    Hi-lift mount (p.34)
    D-ring tie downs (p.34)
    Folding side mirrors (p.63)
    Trim for cut bedsides (p.82)
    Toolbox (p.136-138)
    Wheels/Tires and related-
    Interco TSL LTB 34x10.5r16 (p.151)
    BF Goodrich KM2 255/85/16E (p.6)
    Spare- maxis bighorn 255/85/16 (p.23)
    Spidertrax 1.25" wheel spacers (p.4)
    2nd gen 16" alloys
    ProComp 5 star wheels (p.46-47)
    8oz. offroad dynabeads per tire
    Steel lug nuts (p.4)
    Pro Comp extended lug nuts (p.46)
    Pinch weld mod (page 9)
    Flush fender flare screws (p.10)
    More fender well trimming (p.19)
    Washer fluid reservoir relocation. (p.23)
    Fender flare trimming (p.30)
    More fender flare trimming (p.61)
    Death of a KM2 (p.63)
    Good article about fitting 255/85/16 http://www.expeditionswest.com/equipment/tacoma/bfg_mt_km.html
    Armor-
    Stubbs Welding HD-SKO sliders (p.17)
    Grip tape on sliders (p.18)
    All-pro Baja tube bumper (p.32-33)
    AP IFS skid 3/16 steel (p.33)
    AP trans. skid 3/16 steel (p.34)
    DIY high-clearance rear bumper (p.72-76)
    On Board Air-
    ARB CKMA12 compressor (page 7)
    ARB pump up kit
    ARB inflator with gauge
    Currie Deflator (p.46)
    10# Co2 tank (p.150)
    Trail Comms-
    Midland 75-822 CB radio
    2' firestik antenna (p.39)
    Firestik quick disconnect (p.42)
    Firestik spring (p.42)
    Firestik hood mount (p.39)
    Firestik fire ring coax (p.39)
    Interior-
    Pioneer DEH-X3910BT (p.19)
    RAM/PanaVise phone mount (p.21)
    Vinyl flooring (p.35,40,41)
    ScanGaugeII (p.48)
    Door buzzer delete (p.63)
    Driveline-
    Powertrax no-slip rear locker (p.22)
    Remanufactured oem CV axle (p.60)
    Nitro 5.29 gears (p.76-87)
    Spartan front locker (p.99)
    Trail gear 4.70 crawlbox w/RADesigns triple sticks (p.115-132)
    Other-
    Exhaust cut behind the axle (p.5)
    Drunken Yard Fab diff breather (p.28)
    Ball Joint Replacement (p.25)
    Tundra Brakes (p.45-47)
    Engo 9000# winch (p.108)
    Lighting-
    Refinished headlights (page 8)
    LED reverse bulbs (p.24)
    Color matched corner lights. (P.29)
    Blinker relocation (p.29)
    Jumpers LED dome light (p.24)
    eBay headlights & corners (p.52)
    Trail gear LED blinkers (p.53)
    ADV Monster fogs (p.146)
    VisionX Dura 600 floods (p.146)
    Paranoid Fab switch panel w/OTRATTW rockers (p.146)
    To Do List-
    Build T-case skid
    Replace gas tank
    LROR gas tank skid
    Here we go.................................
  2. Jul 31, 2016 at 6:41 AM
    rngr
    01 SR5 4x4 2.7L
  3. Jul 31, 2016 at 6:41 AM
    rngr
    01 SR5 4x4 2.7L
  4. Jul 31, 2016 at 6:41 AM
    rngr
    01 SR5 4x4 2.7L
    essjay, BassAckwards and ChadsPride like this.
  5. Jul 31, 2016 at 6:45 AM
    rngr
    01 SR5 4x4 2.7L
    Just after bringing it home. 54,XXX miles
    lo2hi, BassAckwards, Manfred and 3 others like this.
  6. Jul 31, 2016 at 6:46 AM
    rngr
    01 SR5 4x4 2.7L
    Mmmmeaty...
  7. Jul 31, 2016 at 6:59 AM
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
  8. Jul 31, 2016 at 6:59 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Mines part 2
  9. Jul 31, 2016 at 7:25 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Dibs pending updates
  10. Jul 31, 2016 at 7:31 AM
    rngr
    01 SR5 4x4 2.7L
    There's going to be a powertrax no slip in this trucks near future thanks to you. Yay for three wheel drive!
    I want your roof rack.
    beertimecontinuum likes this.
  11. Jul 31, 2016 at 7:54 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Get yourself one! Only 10 holes in the roof!
    rngr[OP] likes this.
  12. Jul 31, 2016 at 7:58 AM
    rngr
    01 SR5 4x4 2.7L
    Maybe one day. Lots of higher priorities first. :)
  13. Jul 31, 2016 at 8:02 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    BOOOO....subbed anyway
  14. Jul 31, 2016 at 8:06 AM
    rngr
    01 SR5 4x4 2.7L
    :thumbsup:This is a safe space. You can Boo whoever or whatever you want here.
  15. Jul 31, 2016 at 9:02 AM
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    In for dumb shit.
  16. Jul 31, 2016 at 9:34 AM
    rngr
    01 SR5 4x4 2.7L
    :bananadance:
    Dave41079[QUOTED] likes this.
  17. Jul 31, 2016 at 9:35 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Don't say gay though
  18. Jul 31, 2016 at 9:36 AM
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    You're welcome. And don't worry, I'll get to enjoy it also. Haha
    rngr[QUOTED][OP] likes this.
  19. Jul 31, 2016 at 9:37 AM
    rngr
    01 SR5 4x4 2.7L
    ^^^he said the G word. Ban him.
  20. Jul 31, 2016 at 9:42 AM
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Why the hell am i always late to these damn parties? Shit's pissin me off :D
    Subbed :cool:
