Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Nov 7, 2018 at 8:13 AM
    #2241
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Snowed 3'' yesterday.
    Its cold now. Spent 3 days standing in the wind doing production audio...was fun but not that fun haha now its just cold.
  2. Nov 7, 2018 at 8:35 AM
    #2242
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I rarely break anything. You telling me I don't wheel hard enough?
  3. Nov 7, 2018 at 9:11 AM
    #2243
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    I'm good for something once a year. 2 years ago it was a front axle that wrecked a hub and front locker...$2k later I've got spare RCV's and hubs now. Last year was a cut down tire....$3k later, I've got new tires and 17" aluminum beadlocks.
    I do my best to channel the inner Bob Ross in me and say that breaks are just happy little accidents...
    My bank account feels differently.
  4. Nov 7, 2018 at 9:16 AM
    #2244
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    I said if nothing breaks in the group :rolleyes:
    You said you rarely break anything so you do break so I guess you have wheeled hard or made bad decisions :notsure:
    Dave41079 likes this.
  5. Nov 7, 2018 at 9:37 AM
    #2245
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Good info. Thanks!
    Gideonnnnnnnnn!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    :rofl:
  6. Nov 7, 2018 at 10:32 AM
    #2246
    Robertocritser
    Robertocritser Well-Known Member
    Levi
    KY
    08 sport
    ATM6969420 series
    I am normally the one that breaks. This time I broke and didn't realize it till we got back to camp. Then Carter came in clutch with jb weld
    Dave41079 and dirty deeds like this.
  7. Nov 7, 2018 at 10:57 AM
    #2247
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I pushed mine out with a bottle jack inside. I already had the bed off so it wasn't too bad. Just make sure you can still access the release valve for the bottle jack. I also recommend having an empty tank of gas.
    I'd like to try and raise my tank up an inch. I've dented my frame where the tank is the lowest. Not sure how well a skid would hold up to my abuse.
    rngr[OP] likes this.
  8. Nov 7, 2018 at 11:08 AM
    #2248
    rngr
    01 SR5 4x4 2.7L
    And the handy dandy gear oil pump. :humble:
  9. Nov 7, 2018 at 11:27 AM
    #2249
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    You're just comparing the rest of the world to you. You break something every time your truck moves from the driveway. Haha Wheeling hard is subjective. Saying you gotta break something to be wheeling hard seems very simple minded and personal opinion bias. Most of the time, I would argue just drive better. Some of the time, you needed to do a quick maintenance check before hand. Some of the time, you just do ill advised shit. Some of the time, shit just breaks cause nothing lasts forever. Etc .... don't lump your "bad luck" in with the rest of us.
    There's no "blows a kiss" emoji so you get this instead ... :censored:
    Thank God for random stuff in the tool box. Haha
  10. Nov 7, 2018 at 11:32 AM
    #2250
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    First time I have ever needed a skid there as well haha
  11. Nov 7, 2018 at 11:47 AM
    #2251
    JBTacoma
    Jeff
    Cullman Alabama
    Actually Im not comparing anyone, I said if nothing breaks your not wheeling hard enough, did not say that you don't wheel hard. If you wheel hard enough something will break.
    I don't break every time but I do break, as you stated so do you. Wheeling hard is subjective no doubt. Never said you have to break something to be wheeling hard, said If you are wheeling with a group and nothing breaks you are not wheeling hard enough trails. Because if you wheel hard enough even you will break something. Some times people see what they want to see in a statement, it happens.
  12. Nov 7, 2018 at 11:51 AM
    #2252
    cynicalrider
    cynicalrider #NFG
    Jersey
    I'd like to raise my tank too, but at the same time I feel it's the best DS protector so I don't mind it's location. I just need something stronger to put up with the abuse. The stock skid couldn't do it so I am likely pulling the trigger on the low range one and be done with it. I'm honestly surprised it's held up as long as it has. Solid 4 years of hard wheeling and I only REALLY dented it last year.
  13. Nov 7, 2018 at 12:13 PM
    #2253
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    I wheel soft. So soft. And fluffy.
  14. Nov 7, 2018 at 12:20 PM
    #2254
    Reh5108
    Idaho
    The front mount point on mine is bent. Not sure if the rigidity of a skid would have helped prevent that or make it worse.
  15. Nov 7, 2018 at 2:15 PM
    #2255
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I like you sir :fistbump:
    TN_TacoSupreme and Dave41079 like this.
  16. Nov 7, 2018 at 2:17 PM
    #2256
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Well when you try to drive over a straight faced wall with a drop off on the other side, your gonna hit something in the middle. Wheel soft like Dave and you could've prevented that.
  17. Nov 7, 2018 at 2:42 PM
    #2257
    JBTacoma
    Jeff
    Cullman Alabama
    :thumbsup:
  18. Nov 7, 2018 at 3:00 PM
    #2258
    rngr
    01 SR5 4x4 2.7L
    Dave also has a soft lap.
    *cue AOP campfire pic.
    JBTacoma and Dave41079 like this.
  19. Nov 7, 2018 at 3:41 PM
    #2259
    Dave41079
    Dave...
    Nashville, TN
    Stay there long enough, and that will change.
  20. Nov 7, 2018 at 3:43 PM
    #2260
    Robertocritser
    Levi
    KY
    08 sport
    ATM6969420 series
    Fuck your right!
