Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Apr 22, 2019 at 4:42 PM
    #2421
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    I’m going to assume you mean you foil taped over the duct tape, then sealed over all of it. :rofl:
  2. Apr 22, 2019 at 4:55 PM
    #2422
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Get Gorilla Tape, it is black. Black =TRD PRO :cheers:
  3. Apr 22, 2019 at 4:59 PM
    #2423
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Like HVAC foil tape! :D
    rngr[QUOTED][OP] likes this.
  4. Apr 22, 2019 at 5:16 PM
    #2424
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    LOL!!! no that fancy foil duct tape! I removed the old shit tape first
  5. Apr 22, 2019 at 5:56 PM
    #2425
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    The MarMount mod will help with the motor wanting to rotate. I don't think the additional vibes are too bad. Only really notice it at idle.
  6. Apr 22, 2019 at 6:09 PM
    #2426
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    When i got the FRS from Gid, his bank told us they mailed title and not their problem if we didn't recieve it. Had to apply for lost title. Not a big deal in my county.
    edit: my county printed a title on the spot. His county said it takes 2-3 weeks to do. :rolleyes:
  7. Apr 22, 2019 at 7:36 PM
    #2427
    rngr
    01 SR5 4x4 2.7L
    MarMount mod? What’s that?
    Yea, It shouldn’t have been a big deal. It was more of the fact that I he told me he had the title and the truck was a manual, then I show up to find an automatic truck with no title. No title. No sale.
  8. Apr 22, 2019 at 7:55 PM
    #2428
    Reh5108
    Idaho
  9. Apr 23, 2019 at 8:40 PM
    #2429
    slander
    Hickory, NC
    You can also go super old school and weld some chain on there. I didnt do anything with mine and they are actually still in good shape. Swapping them out this summer (maybe depending on job/moving) with some fresh amounts. Going back and forth between the mar mount and just chaining them.
    Reh5108 likes this.
  10. Apr 23, 2019 at 9:06 PM
    #2430
    rngr
    01 SR5 4x4 2.7L
    Getting closer. Test fitted the shifters. Cut out more floorboard.
  11. Apr 23, 2019 at 9:09 PM
    #2431
    rngr
    01 SR5 4x4 2.7L
    Also go the rear shafts in the truck. Ran into a problem with the front. It’s a hair too long. Total length will fit between the two flanges, but the studs on the T-case flange won’t allow it slide in.
    Anybody know how those are in there? Are they just pressed in? Anybody ever tapped one out?
  12. Apr 23, 2019 at 9:30 PM
    #2432
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Didn't want to use the BFH approach?
  13. Apr 23, 2019 at 9:31 PM
    #2433
    rngr
    01 SR5 4x4 2.7L
    To what?
  14. Apr 23, 2019 at 9:39 PM
    #2434
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Just pressed in and they can be pushed out. I’d be a little concerned about the driveshaft bottoming out under load though. IFS diff “shouldn’t” move much but...
  15. Apr 23, 2019 at 9:39 PM
    #2435
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    So the shifter linkages can clear the tunnel.
  16. Apr 23, 2019 at 9:41 PM
    #2436
    rngr
    01 SR5 4x4 2.7L
    Never really considered it. Almost positive there isn’t room for that though.
  17. Apr 23, 2019 at 9:43 PM
    #2437
    rngr
    01 SR5 4x4 2.7L
    Well shit.
  18. Apr 23, 2019 at 10:05 PM
    #2438
    slander
    Hickory, NC
    Try putting the tcase end on first then the diff side, it may fit that way. Ask me how I know LOL!!!
    If anything your driveshaft should be getting longer under load as the tcase flange raises as everything torques over.
    Good thing you cut that floor out, helps a ton with adjusting the shift rods.
    ThunderOne and jubei like this.
  19. Apr 24, 2019 at 4:48 AM
    #2439
    rngr
    01 SR5 4x4 2.7L
    Tried that. All the hard lines on the steering rack were in the way. It was 10pm though, so my fuck it threshold was pretty low. Will try again tonight.
    I swear I could finish this truck in a day, if I had a day to work. Instead it's real job, side job, TeeBall coaching, soccer games, honey-do's, daddy duties, and then scramble to wrench on the truck for an hour before crashing hard. :facepalm:
    ThunderOne, Justinogo and jubei like this.
  20. Apr 24, 2019 at 6:33 AM
    #2440
    slander
    Hickory, NC
    That's why I dont have kids and I still can't get shit done! Yea you kind of have to play a dance of moving it all kinds if weird ways to get it on there, attaching to the tcase end first.
    rngr[OP] likes this.
