Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Apr 27, 2019 at 8:55 PM
    #2461
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    It touches my leg because I had to bend it outboard that far to clear 2nd gear.
    Dave41079[QUOTED] likes this.
  2. Apr 27, 2019 at 10:52 PM
    #2462
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Can you just break your leg and reset it to clear the shifter then?
  3. Apr 28, 2019 at 9:59 AM
    #2463
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I just take the shift knob off the shifter closest to my leg while wheeling so it clears evreything.
  4. Apr 28, 2019 at 11:00 AM
    #2464
    rngr
    01 SR5 4x4 2.7L
    It’s not the knob that’s the issue. It’s the shifter itself. I’ll figure something out.
  5. Apr 28, 2019 at 11:06 AM
    #2465
    slander
    Hickory, NC
  6. Apr 29, 2019 at 5:39 AM
    #2466
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    More bending. Bend everything. Then cut some stuff. Then bend some more.
    I think that's the process.
    :D
  7. Apr 29, 2019 at 5:51 AM
    #2467
    rngr
    01 SR5 4x4 2.7L
    Yep. That was the process. Except you have to take all the linkage apart every time you make a change. Then heat it up. Then let it cool. Then put it all back together. Then find out you didn't bend it enough. Then repeat the whole process just to bend it too much. Next thing you know, you have spent 4 hours fiddlefucking with shifters.
    That, in a nutshell, has been the crawlbox install theme. Geoff said it best. There's really nothing hard about any of this. Just extremely time consuming and aggravating.
  8. Apr 29, 2019 at 7:23 AM
    #2468
    slander
    Hickory, NC
    Yea getting it physically in the truck is the easy part, it's all the fucking around and "tuning it" that takes forever. Wait until you SAS it!
    ThunderOne, allenfab and rngr[OP] like this.
  9. Apr 29, 2019 at 7:26 AM
    #2469
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Yup shifters are easily THE most time consuming part of the whole install. PIA trying to get thm to line up without hitting each other and making sure they fully engage.
  10. Apr 29, 2019 at 6:05 PM
    #2470
    rngr
    01 SR5 4x4 2.7L
    Amen to that. This is their final resting place. Now to rebuild this gaping hole in my floor. Do you have any pics of what you did there?
  11. Apr 29, 2019 at 6:32 PM
    #2471
    slander
    Hickory, NC
    I picked up some sheet metal from an ace hardware and smashed it with a hammer over a brick until it was the right shape. Wish I had a picture, but then again if you made it this far you should be able to figure it out!
    What did you end up doing for the breather for the cases?
  12. Apr 29, 2019 at 6:34 PM
    #2472
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    I'll see if I can find some pics or see if I can take a few in a couple days. Basically I made an access panel where the rear position of the shifters (on top of the rear chain case) with some aluminum and nutserts. That way all that I needed to cover up would be covered by carpet, sounddeadners, and the plastic console.
    **Edit** and some 1/8" rubber gasket I used to cut out to seal around the whole area after I used nutserts and bolted the rubber shifter boot ring to it.
    slander and rngr[QUOTED][OP] like this.
  13. Apr 29, 2019 at 6:43 PM
    #2473
    rngr
    01 SR5 4x4 2.7L
    Nothing yet. Going to get the floor mocked up, then take it all back apart to Put gasket maker under my shifter bases, locktite linkage hardware, and run breathers.
    Nice!
  14. Apr 29, 2019 at 6:54 PM
    #2474
    slander
    Hickory, NC
    I used some plastic expandable nutserts for my triple stick shifter base, I have to top fill my cases through the crawler shifter (on the mini truck style cases the crawler and transfer case share fluid) and this was the best way to do it. I recommend doing some sort of a nutsert either plastic or metal because self taping sheet metal screwing the shifter on is halfass and the way I did it for waaay too long and it never fit quite right.
  15. Apr 29, 2019 at 6:58 PM
    #2475
    rngr
    01 SR5 4x4 2.7L
    Made a quick template out of some super thin aluminum I had. Will make a final one out of a larger thicker piece I have. Needs to come down further on each side of the tunnel. Run some self rappers through it and a bead of that sealant underneath and call it a day?74CC2087-3C36-4B19-AB05-024A232CDDAF.jpg
    slander likes this.
  16. Apr 29, 2019 at 6:59 PM
    #2476
    rngr
    01 SR5 4x4 2.7L
    *** goes to google wtf a nursert is. BRB...
    Prayn4surf, 14Tacos4me and jubei like this.
  17. Apr 29, 2019 at 7:00 PM
    #2477
    slander
    Hickory, NC
    For my breather I screwed a brass hose barb into that threaded hole you see by the shifter base by the trans adapter and ran a hose up to the engine bay. As for the rear case when it was with the chain drive, I ran the hose from the factory nipple and zip tied along the same hose up into the engine bay as well.
    rngr[OP] likes this.
  18. Apr 29, 2019 at 7:01 PM
    #2478
    slander
    Hickory, NC
    Fucking phone autocorrect.
  19. Apr 30, 2019 at 6:23 AM
    #2479
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    You forgot to say "ghost ride the whip" :facepalm:
    ThunderOne likes this.
  20. Apr 30, 2019 at 6:33 AM
    #2480
    rngr
    01 SR5 4x4 2.7L
    I’m am terribly sorry that I let you down, buddy.
