Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Oct 25, 2016 at 4:29 PM
    #241
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Ha ha. No sir. I had a gift card to 4WP that came with my tires that was about to expire. Figured these would be handy to have here and there.
    Delta00[QUOTED] likes this.
  2. Oct 25, 2016 at 5:29 PM
    #242
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I figured CO2 as well, but hell you can always use those damn things
    Delta00 and rngr[OP] like this.
  3. Oct 25, 2016 at 5:37 PM
    #243
    rngr
    01 SR5 4x4 2.7L
    The only thing I have planned for them as of now is to put a couple on the roof rack to hold my fishing poles, kayak paddles, and such.
  4. Oct 25, 2016 at 5:38 PM
    #244
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Which ones do you think you'll use to hold your such, the biggest ones?
    11TRDTX and rngr[QUOTED][OP] like this.
  5. Oct 25, 2016 at 5:47 PM
    #245
    rngr
    01 SR5 4x4 2.7L
    You're a nut.
    Dave41079[QUOTED] likes this.
  6. Oct 27, 2016 at 8:03 AM
    #246
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Haha I laughed
    rngr[OP] and Dave41079[QUOTED] like this.
  7. Oct 30, 2016 at 2:27 PM
    #247
    rngr
    01 SR5 4x4 2.7L
    Crom and Dave41079 like this.
  8. Oct 30, 2016 at 3:32 PM
    #248
    Dave41079
    Dave...
    Nashville, TN
    Do the nuts sit low enough so they won't scratch whatever you put into them? Hard to tell from the angle of your pictures.
  9. Oct 30, 2016 at 4:32 PM
    #249
    rngr
    01 SR5 4x4 2.7L
    The nuts sit perfectly flush with the bottom of the fist. So, they will contact whatever the fist is holding. Will it scratch it? I don't know. I not worried about it. You could probably put some rubber hose or something over the nut if you wanted.
    Crom and Dave41079[QUOTED] like this.
  10. Nov 9, 2016 at 8:19 AM
    #250
    rngr
    01 SR5 4x4 2.7L
    Last day singing the working man's blues for 4 days. :yes:
    ERMB, Crom, Dave41079 and 4 others like this.
  11. Nov 11, 2016 at 12:01 PM
    #251
    rngr
    01 SR5 4x4 2.7L
    Spent the last two days on the Caney Fork. It was a nice little 10 or so mile float from Happy Hollow to Stonewall Access. We set up camp at the Smith Fork confluence along the way.
    It was great to get out and explore with a couple friends. Major props to my beautiful wife for holding down the fort solo.
    Crom and BYJOSHCOOK like this.
  12. Nov 11, 2016 at 12:02 PM
    #252
    rngr
    01 SR5 4x4 2.7L
  13. Nov 11, 2016 at 12:31 PM
    #253
    Dave41079
    Dave...
    Nashville, TN
    I wish I had been able to join you guys for this.
    rngr[OP] likes this.
  14. Nov 11, 2016 at 12:43 PM
    #254
    rngr
    01 SR5 4x4 2.7L
    Me too. We will go again. It was really nice. We took our time, fished, caved, cooked, and had a blast. It was perfect weather for sitting around a fire.
    On the other side, I think I am done with tent camping. I hate setting them up and taking them down, then letting them dry when i get home. I also broke the door zipper last night.
    I was so envious of my buddy's hammock setup. Easy up, easy down, easy storage. I think I'll be investing in one.
  15. Nov 11, 2016 at 3:03 PM
    #255
    Dave41079
    Dave...
    Nashville, TN
    I can get you set up right. I've been hammock camping for years now. I have extra gear if you want to try some things out before you buy.
    rngr[QUOTED][OP] likes this.
  16. Nov 11, 2016 at 3:13 PM
    #256
    rngr
    01 SR5 4x4 2.7L
    What are the basics?
    Hammock, straps, tarp. What else?
    My buddy had some sort of thermal yoga-mat looking thing he put in the bottom of the hammock.
  17. Nov 11, 2016 at 6:38 PM
    #257
    Dave41079
    Dave...
    Nashville, TN
    Like most things in life, there's more than one way to skin a cat. Mine is having a down top quilt and down under quilt. The under quilt hangs below the hammock to insulate you from the air. In a hammock below 60ish degrees, you will freeze because of all the thermal loss to convection and body heat radiation. Some people do like your friend and put a pad in the hammock and lay on that with a quilt or sleeping bag on top of them. I did that for a long time until I could afford the under quilt. A bugnet is also a near necessity here in late spring through early fall. Some hammocks have the bugnet attached, while others have them as a separate item. For your tree straps, remember that nylon stretches and polyester doesn't. A tight hammock at bedtime with nylon straps will have your ass on the ground by morning. I prefer whoopie slings for suspension because they're small, lightweight, and easy to use. They're made of amsteel, which is the same thing synthetic winch lines are made from.
    Things to figure out for yourself are whether you want to use it backpacking, car camping, kayak/canoe camping. If you want to use it for mild weather or all year long. Do you plan on being out in downpours, or might get caught out in the occasional unexpected shower. Good, cheap, and light...pick two.
  18. Nov 11, 2016 at 8:09 PM
    #258
    rngr
    01 SR5 4x4 2.7L
    Oooo there's a lot more to it than thought. Ha ha. I need to study up a little thanks for the info.
  19. Nov 11, 2016 at 8:21 PM
    #259
    Dave41079
    Dave...
    Nashville, TN
    https://www.youtube.com/watch?v=d7NZVqpBUV0
    Watch this entire series of videos and you'll know more than you want to.
  20. Nov 12, 2016 at 5:48 AM
    #260
    rngr
    01 SR5 4x4 2.7L
