Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. May 31, 2017 at 4:58 AM
    #701
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Free. Fits 2nd gen bed rails.
  2. May 31, 2017 at 7:21 PM
    #702
    alee891
    alee891 Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Sub'd
    jubei and rngr[OP] like this.
  3. Jun 2, 2017 at 5:23 AM
    #703
    rngr
    01 SR5 4x4 2.7L
    This will be about the tenth time I've said this, but I'm serious this time.
    I'm done with my stupid magnetic CB antenna. Looking at this. Probably will be mounted on a tail gate or ditch light bracket.
    https://www.rightchannelradios.com/collections/cb-antennas/products/firestik-cb-antenna-kit
    3' or 4'?????? I only use the radio on the trail. I have no need to talk to someone 5 miles away.
    I see the coax usually comes in 18' lengths. Is there any disadvantage to having suck a long cable if it isn't needed?
    Dave41079 and 11TRDTX like this.
  4. Jun 2, 2017 at 5:29 AM
    #704
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    3' if it's just for the trails. They have 9' lengths of coax.
  5. Jun 2, 2017 at 5:50 AM
    #705
    rngr
    01 SR5 4x4 2.7L
    Yea I saw that, but I might need more if I go the tailgate mount route. Wondering if there is any issue with bundling up several extra feet if cable.
  6. Jun 2, 2017 at 5:52 AM
    #706
    rngr
    01 SR5 4x4 2.7L
    For some reason I thought I remembered someone saying that having lots of extra coax would hurt signal quality.
  7. Jun 2, 2017 at 6:06 AM
    #707
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    i meant 9' for an A-pillar mount. I used 18' and coiled up about a foot worth, and i haven't had any issues.
  8. Jun 2, 2017 at 6:18 AM
    #708
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    It's good practice with long coax runs to coil them up and then twist the coil into a figure eight and tie it up that way. Otherwise the coax itself can tend to act as an antenna and pick up noise. Also should help with the VSWR.
  9. Jun 2, 2017 at 6:24 AM
    #709
    rhion82
    rhion82 El Duderino
    Mitchell
    TN/GA
    16 Taco
    How you like your OME 1st gen set up? I'm about to pull the trigger on the kit for myself.
  10. Jun 2, 2017 at 6:33 AM
    #710
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    I still don't know why you have so many problems with your magnetic mount. Every time I put it on your roof for you it stays on. Mine doesn't fall off either. Has to be operator error. :luvya:
    Also, couldn't resist...
    You're asking if there's a disadvantage to sucking a long cable...you been doing "squats" with Zachk?
  11. Jun 2, 2017 at 6:55 AM
    #711
    rngr
    01 SR5 4x4 2.7L
    Yea, that's what I remember. Thanks! so, you're saying having a long cable helps with VSWR (whatever that means:anonymous:)?
    It is...okay. I am very very pleased with the dakars. They carry moderate weight and flex well. The shock absorbers leave a lot to be desired though. I plan to move to a nice performance coilover when these are dead. I was much more satisfied with the ride of my 2nd gen with 5100's (probably comparing apples to oranges due to the different trucks). However, the reviews I read about the 1st gen 5100's made me to opt for OME this time around. Don't let me scare you, they are just fine. You just won't hear me rambling on about how sweet my truck rides.
    Save me the money of buying a new antenna and ride around with me to make the magnet behave. Gid spent half a day with his arm out the window holding it.
    Lots of squats with Zachk.
    Dave41079[QUOTED] likes this.
  12. Jun 2, 2017 at 7:36 AM
    #712
    jubei
    NoCo
    Stuff. Also things.
    Haha!
    In the CB/HAM world, you'll see references to SWR, which stands for Standing Wave Ratio. VSWR is just a more precise way of saying the same thing. I work in the radio frequency world, so its habit to use VSWR. Anyway, think of it in rough terms as a measure of the reflected power versus how much power is input to the antenna. If the antenna is relecting most of the energy back to the radio, it isn't being transmitted (and radiated) and it might actually blow up the output stage of the radio.
    So, in the interest of getting good range (because range is proportional to power transmitted), you hook up an SWR meter to your CB setup, and you tune the antenna until you're better than 1.5:1.
    And to clarify, long cables aren't usually a good thing, especially at long wavelengths like CB and HAM. But since most of us don't want to deal with connectorizing a cable cut to the perfect length, you buy one a specific length and coil up the excess. Since coiling a conductor increases its inductance (don't worry about what that is), you twist the coil into a figure eight to eliminate that effect.
    /end nerd out
  13. Jun 2, 2017 at 7:52 AM
    #713
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Wilson Lil Will and 18' of coax. No issues except when mag mount meets parking garage.
    I blame operator error.
  14. Jun 2, 2017 at 8:08 AM
    #714
    rngr
    01 SR5 4x4 2.7L
    That's awesome. I love a good nerd out.
    jubei[QUOTED] likes this.
  15. Jun 2, 2017 at 8:25 AM
    #715
    rngr
    01 SR5 4x4 2.7L
    Correct.
  16. Jun 2, 2017 at 8:53 AM
    #716
    rngr
    01 SR5 4x4 2.7L
    Obviously. Ha Ha. Won't make that mistake again.
  17. Jun 2, 2017 at 10:38 AM
    #717
    Dave41079
    Dave...
    Nashville, TN
    Mine is a K40, and works great.
  18. Jun 2, 2017 at 11:42 AM
    #718
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I'll tell him the truth .... They are fine for the road, not fine for the trails. Generally a soft pavement ride equals a bouncy dirt ride. His truck made me sea sick riding on the trails. Back and forth and back and forth and back and forth and you get the idea. I don't know if there is a median between those shocks and good coilovers (probably bad coilovers) but good God you don't know what you're missing if you've never had properly valved coilovers on your truck while trail riding.
    I'm saying this without any other point of reference because I don't know how a stock 1st gen rides but I can imagine a world in which all you enjoy out of the new shocks is the lift.
  19. Jun 4, 2017 at 1:32 PM
    #719
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Did you have trouble getting the old tow hook bolts to line up? Not a bolt length issue but an alignment issue. I've every other bolt in but those tow hooks bolts.
    The frame seems to be too narrow for the bolts to line up on bottom but it can't be any wider or the bumper won't slide back over the frame horns :notsure:
  20. Jun 4, 2017 at 3:38 PM
    #720
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    :sawzall::welder::cheers:
