Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Jun 4, 2017 at 4:27 PM
    #721
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Cosmetically it's good to go. Structurally it needs those bolts. A little Dremel work might get it where it needs to be.
  2. Jun 4, 2017 at 6:53 PM
    #722
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Having trouble picturing what you're needing. The only thing I ran into was having to cut two little tits off the part where the two bolts come in from the side.
    Also, those tow hook bolts were too long.
  3. Jun 4, 2017 at 6:56 PM
    #723
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I just edited my original question for relevance lol.
    I'll have to take pictures tomorrow to better explain it but....
    The two bolts that go in from the bottom, bolt heads down. Those will not line up but all others will. I used a floor jack to try to spread the sections of frame to line the holes up but it was a no go. This bumper is a little different than yours and is well used.
  4. Jun 4, 2017 at 7:09 PM
    #724
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Think I read some where that the first gen has two different possible bumper mount configurations. Maybe saw it in the Demello interest thread...
  5. Jun 4, 2017 at 7:11 PM
    #725
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    That is correct. This bumper should, and nearly does, bolt right up with no issues, modifications or additional parts needed. The 95.5-00 need the frame mount add-on.
  6. Jun 4, 2017 at 7:16 PM
    #726
    rngr
    01 SR5 4x4 2.7L
    I gotcha. So, the bolt hikes in the bumper need to be slightly more inboard than they are?
  7. Jun 4, 2017 at 7:20 PM
    #727
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Correct. I'm hesitant to do any cutting because the holes are so close to the edge of the mounting bracket.
  8. Jun 4, 2017 at 7:21 PM
    #728
    beertimecontinuum
    Everett
    Bring it to the Yard?
  9. Jun 4, 2017 at 7:21 PM
    #729
    rngr
    01 SR5 4x4 2.7L
    I'm sure Everett will weld it to your frame for a tall boy.
    @beertimecontinuum
    beertimecontinuum likes this.
  10. Jun 4, 2017 at 7:22 PM
    #730
    rngr
    01 SR5 4x4 2.7L
    Lol called it. ^^^
  11. Jun 4, 2017 at 7:25 PM
    #731
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Ha!
    I'll post some pictures up tomorrow in the TN thread and see what the peanut gallery thinks before we do any tall boy fueled cutting.
  12. Jun 4, 2017 at 7:28 PM
    #732
    beertimecontinuum
    Everett
    Just let me know. I've turned away slider jobs for the next month due to house projects but yours should be quick and easy I'd say.
    Breezy[QUOTED] likes this.
  13. Jun 5, 2017 at 10:38 AM
    #733
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Sounds like you just need new tabs welded on
  14. Jun 5, 2017 at 10:50 AM
    #734
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    That's an option. Likely the strongest option too.
  15. Jun 5, 2017 at 11:04 AM
    #735
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Me installing it is THE strongest option ...
    beertimecontinuum and Dave41079 like this.
  16. Jun 5, 2017 at 12:53 PM
    #736
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Cool I'll send you my address :thumbsup:
  17. Jun 5, 2017 at 1:53 PM
    #737
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    :D
  18. Jun 13, 2017 at 2:24 PM
    #738
    cynicalrider
    cynicalrider #NFG
    Jersey
    Sub. :thumbsup: Vinyl looks good man.
    rngr[OP] likes this.
  19. Jun 13, 2017 at 3:19 PM
    #739
    rngr
    01 SR5 4x4 2.7L
    :hattip:
  20. Jun 15, 2017 at 1:25 PM
    #740
    rngr
    01 SR5 4x4 2.7L
    Ordered my new CB set up today. Going to be running a 2 foot fire stick at the edge of the hood and front fender. Also grabbed a spring and a quick disconnect.
    My old magnetic antenna is now available for free to anyone who wants it. Works just fine if you have someone to ride around holding it to the roof or if you mount it to the hood.
    *** disclaimer*** it sucks ass, but hey, what do you expect for free?
    :cheers:
    Dave41079, rhion82 and 11TRDTX like this.
