Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Nov 13, 2017 at 9:08 AM
    #1261
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    I ordered my last KM2 from 4WD. Got it in 3 days I think.
    rngr[OP] likes this.
  2. Nov 13, 2017 at 9:15 AM
    #1262
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Moved the spare to the back. The new maxxis was a tiny bit taller, so I aired it down a little. Both now measure 33" exactly i mounted. Truck isn't trying to drag me off the road anymore. Alignment is fubar though.
    Not sure what I was sitting on, but apparently I was giving it hell. Ate 8 lugs in a row. Ha ha.
    11TRDTX, beertimecontinuum and jubei like this.
  3. Nov 13, 2017 at 9:18 AM
    #1263
    rngr
    01 SR5 4x4 2.7L
    Also, the paint on my hood and roof is failing. I knew there was a reason I don't wash this thing. Probably derp it to see if it looks ok, then maybe order some vinyl to replace it. Idk.
  4. Nov 13, 2017 at 9:19 AM
    #1264
    rngr
    01 SR5 4x4 2.7L
    beertimecontinuum likes this.
  5. Nov 13, 2017 at 11:06 AM
    #1265
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    think his are decals.
    You might be better off trying to rattle can it.
    I derped roof on wifes highlander. Had to do a few coats of the "glossifier" to make it look ok. Had trouble getting a smooth finish across the whole thing for some reason. Mostly good but a few spots feel rough, feels like 60 grit paper there. White derp gets stains from mud and tree tannins. Can't clean it.
  6. Nov 13, 2017 at 11:36 AM
    #1266
    rngr
    01 SR5 4x4 2.7L
    Probably will give it a try. Plan to use black and follow the hump on the hood.
    Worst case I’ll peel it off.
  7. Nov 13, 2017 at 11:43 AM
    #1267
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    i used black derp on bumper and wheels of my old white truck. Took a number of thick coats to make it look even, no darker spots. After baking in summer sun for a few months, it was a pretty hard tough layer. Had a really dull matte finish but held up really well.
    11TRDTX and rngr[OP] like this.
  8. Nov 13, 2017 at 11:59 AM
    #1268
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    You're supposed to spray 8-12 thin layers of the derp to get a nice even finish. I've had better results from a power painter than a spray can though.
  9. Nov 13, 2017 at 2:48 PM
    #1269
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    It's derp. Turning gray in the sun. Looks good wet
    rngr[QUOTED][OP] likes this.
  10. Nov 13, 2017 at 3:16 PM
    #1270
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Lots of things look good wet :evil:
  11. Nov 13, 2017 at 3:44 PM
    #1271
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
  12. Nov 14, 2017 at 4:30 AM
    #1272
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Everetts' shag carpet on his chest is one of my favorites :censored:
  13. Nov 14, 2017 at 4:50 AM
    #1273
    rngr
    01 SR5 4x4 2.7L
    That is quite the impressive chest bush.
  14. Nov 14, 2017 at 4:51 AM
    #1274
    rngr
    01 SR5 4x4 2.7L
    Also impressive that he manages to find a way to show it off at every single meet, regardless of the weather.
    beertimecontinuum and 11TRDTX like this.
  15. Nov 14, 2017 at 6:44 AM
    #1275
    beertimecontinuum
    Everett
    Groovy baby AF
    BYJOSHCOOK and Justinogo like this.
  16. Nov 14, 2017 at 8:32 AM
    #1276
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah I used to not question it but after that sexual robe fire dance display, it's worth pondering on.
  17. Nov 14, 2017 at 5:43 PM
    #1277
    rngr
    01 SR5 4x4 2.7L
    Yesterday I called 4wd and inquired about the tire. Sure enough, they had them in stock for the same price as 4wp. So then I explained that I was going to call and cancel my order with 4wp and call them back to order the Tire. The guy on the phone acted really weird about this. Enough so that I didn’t go through with my plan.
    Today, I received this email. 4wp finally got my claim processed. Notice the signature line, and logos at the bottom. Haha.
    https://youtu.be/6UQ7HoOJwfQ
    All makes sense now. Ha ha. Tire should be here Thursday.
  18. Nov 14, 2017 at 8:16 PM
    #1278
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    GEEZ. You just made the Tacoma guys look stupid. Those boys in their full size domestics with 9" lifts and 325/20-24 mud tires are going to feel vindicated now.
    unsubd
  19. Nov 14, 2017 at 8:20 PM
    #1279
    rngr
    01 SR5 4x4 2.7L
    Wha...wait...umm.
    You lost me. :notsure:
  20. Nov 14, 2017 at 8:25 PM
    #1280
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Later, in the 4WP/4WD breakroom: "dude dude dude. Bro, seriously. He wanted to cancel his order because we suck and lost his tire but then he wanted to place a new order with us for the same tire we were gonna ship anyway because we rock!"
    rngr[OP] and beertimecontinuum like this.
