Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Nov 26, 2017 at 10:10 AM
    #1321
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Keep em guessing
  2. Nov 27, 2017 at 4:30 AM
    #1322
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    It's likely Carter sounds like a sophisticated aristocrat compared to the locals from that area.
  3. Nov 27, 2017 at 4:56 AM
    #1323
    rngr
    01 SR5 4x4 2.7L
    @423 TACO crawled out from under a rock down that way.
    Dave41079[QUOTED] likes this.
  4. Nov 29, 2017 at 5:52 AM
    #1324
    rngr
    01 SR5 4x4 2.7L
    I am re-evaluating my on board repair/recovery/spare parts stuff. I think I remember seeing someone call it an "Oh Shit Kit" :p I want to be fully self sufficient in the case of an "oh shit" moment. Sure, i'm usually with a group, but you never know. Plus, I don't like relying on what someone else may or may not have.
    Please help me think, make suggestions, and critique as you see fit.
    Tools
    1/2" drive ratchet
    metric sockets - all the usual ones (think I could disassemble 90% of my truck with a 10 and 12mm)
    36mm socket for cv axle nut
    What other random sizes might be needed?
    Breaker bar
    metric wrenches
    assorted pliers
    channel locks
    pry bar
    BFH
    block of wood
    ether
    PB blaster
    valve stem core removal tool
    duct tape
    locktite
    zip ties
    jumper cables
    screw drivers
    Spare Parts
    CV axle
    valve stems
    valve stem cores
    tire plug kit
    Lower ball joint
    Lug nuts
    I'm sure I've forgot a lot, but that's why I'm doing this... Let's hear it.
    11TRDTX, TN_TacoSupreme and jubei like this.
  5. Nov 29, 2017 at 6:02 AM
    #1325
    rngr
    01 SR5 4x4 2.7L
    @tacotim448 where did you get those valve stems that thread in from the outside?
    pretty handy in a pinch
  6. Nov 29, 2017 at 6:03 AM
    #1326
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    I don't see tow straps listed? What about a screwdriver, like the one with multiple tips. Gloves?
    rngr[QUOTED][OP] likes this.
  7. Nov 29, 2017 at 6:05 AM
    #1327
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Slide hammer made great work at getting that damn CV out on the trail :notsure: Crowbar works just as good but not as efficient IMO.
    Impact if you've got it
    Various extensions and reducers possibly
    Locktite and various fluids
    11TRDTX and rngr[OP] like this.
  8. Nov 29, 2017 at 6:14 AM
    #1328
    rngr
    01 SR5 4x4 2.7L
    Yes! All of that is already on the truck. Just forgot to list it.
    Don't have an impact. Yes on the extensions.
    Updating list. Thx!
  9. Nov 29, 2017 at 6:17 AM
    #1329
    Extra Hard Taco
    R.J.
    Devil's Island
    Yeah, I figured you probably already had straps somewhere else. What are you using to carry your recovery gear in?
  10. Nov 29, 2017 at 6:25 AM
    #1330
    rngr
    01 SR5 4x4 2.7L
    I have an ammo can with straps/ shackles and suck that lives in the back seat.
  11. Nov 29, 2017 at 6:35 AM
    #1331
    cynicalrider
    cynicalrider #NFG
    Jersey
    My parts list is:
    OTRE's
    1 ITRE
    U-joint
    Drive shaft (a little excessive for a first gen but still)
    This is a cool tool to use in a pinch if you destroy a valve stem that doesn't require breaking the bead:
    https://www.amazon.com/gp/product/B06Y1TQZK4/ref=oh_aui_detailpage_o04_s02?ie=UTF8&psc=1
    IIRC the CV nut is 35 MM but 36 will work, but I try to use the 35 if I have it.
    A jump pack is always good to have if you have a single battery.
    A pitman puller is also nice to carry to change a tie rod or LBJ.
    rngr[QUOTED][OP] and jubei like this.
  12. Nov 29, 2017 at 6:51 AM
    #1332
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
    Emergency can of Miller Lite
  13. Nov 29, 2017 at 7:01 AM
    #1333
    Extra Hard Taco
    R.J.
    Devil's Island
    Not enough, need at least a six pack of any libation juice. :cheers:
  14. Nov 29, 2017 at 7:37 AM
    #1334
    Dave41079
    Dave...
    Nashville, TN
    AAA
    11TRDTX likes this.
  15. Nov 29, 2017 at 7:43 AM
    #1335
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
    Map torch.
    slander and rngr[OP] like this.
  16. Nov 29, 2017 at 7:47 AM
    #1336
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    vice-grips
    ujoint
    c-clamp big enough for ujoint
    snap-ring pliers
    couple of hose clamps
    electrical wire and some connectors
    fuses
    and the 2 most important:
    zipties
    ducktape
  17. Nov 29, 2017 at 7:47 AM
    #1337
    Dave41079
    Dave...
    Nashville, TN
    A couple of nice big tarps. One for laying on to do the work, and another to lay parts and tools on so you can see what and where everything is.
  18. Nov 29, 2017 at 9:16 AM
    #1338
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Shop with a lift
    rngr[OP] and BYJOSHCOOK like this.
  19. Nov 29, 2017 at 9:31 AM
    #1339
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I never leave home without my tampons.
    Twinkies too. When you break down and need s snack, those things will never be out of date.
    beertimecontinuum and BYJOSHCOOK like this.
  20. Nov 29, 2017 at 9:33 AM
    #1340
    Dacapster
    Dacapster Well-Known Member
    Hugh
    14 trd
    Many coming
    Hack saw /chainsaw
    rngr[OP] likes this.
