Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Nov 30, 2017 at 12:47 PM
    #1361
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    I think that's the weekend I'm getting my rear oil seal/bearings replaced. But it's 3 hours one way
  2. Nov 30, 2017 at 12:59 PM
    #1362
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Invitation is open :thumbsup:
    BYJOSHCOOK[QUOTED] likes this.
  3. Nov 30, 2017 at 3:52 PM
    #1363
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    I can't believe you would do that to a perfectly good km2.
    totmacher and 11TRDTX like this.
  4. Nov 30, 2017 at 4:00 PM
    #1364
    rngr
    01 SR5 4x4 2.7L
    My kids thank you. They think it’s much better as a swing.
    11TRDTX likes this.
  5. Nov 30, 2017 at 4:39 PM
    #1365
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I just recently went through this exercise as well. The above looks like a good list. I would add some old upper and lower radiator hoses, some lengths of random vaccume/fuel hose and bailing wire. Those three items have bailed some friends out a few times using my spares. For a first gen that's about all you need since nothing really breaks on 33s, provided you have real Toyota CVs and not some parts house shit. That TRE puller is super helpful, I just got a $12 one from vatozone and holy shit is it useful. I would also carry some JB weld and a bottle of "the right stuff" 1min gasket maker.
    And get a set of inverted torx sockets, you will need those if you ever break a CV shaft off inside the pax axle tube and have to take that tube off. I learned that the hard way.
    These: https://www.amazon.com/dp/B01FOQJM0...t=&hvlocphy=9021648&hvtargid=pla-302114064864
  6. Nov 30, 2017 at 4:59 PM
    #1366
    rngr
    01 SR5 4x4 2.7L
    Thanks man! More good info.
  7. Dec 1, 2017 at 6:23 AM
    #1367
    cynicalrider
    cynicalrider #NFG
    Jersey
    Shit I forgot quick steel as well! I sealed a busted oil pan with that shit. Also torque wrench capable of going as high as a CV nut needs. And I know we are getting into crazy territory but I have used an angle grinder a number of times. Battery powered preferred but electric is okay if you have 2nd gens with inverters. I needed this when I blew my front diff and needed to make a 2wd kit. Also a 2wd kit is nice to have so you don't need to destroy good CV's to make one.
    Dalandser and rngr[OP] like this.
  8. Dec 1, 2017 at 7:40 AM
    #1368
    rngr
    01 SR5 4x4 2.7L
    I’m going to need a service bed on this thing to haul all this stuff. :eek:
  9. Dec 1, 2017 at 8:03 AM
    #1369
    cynicalrider
    cynicalrider #NFG
    Jersey
    :rofl: True. I use both my cubbies, my tool box, a plano gun case, and a tub to fit it all. A lot of my stuff is based on tough wheeling trips though, wouldn't carry as much for less intense stuff.
    rngr[QUOTED][OP] likes this.
  10. Dec 1, 2017 at 10:12 AM
    #1370
    slander
    Hickory, NC
    Action packed for the win. I had a bed rail mounted tool box and could barely fit anything in there, with the action packer that's physically smaller I can fit everything and then some. As an added bonus the action packer doesn't get snagged on trees/rocks like that damn bed mounted box did.
    I carry 2 spare driveshafts, 2 tool bags (one with tools, the other with u joints, zip ties, bailing wire, sealent etc) a spare steering box, a spare ps pump, an ammo can with spare hub parts, crawl box input shaft and mainshaft, 1 gallon of antifreeze, 1gallon of distilled water, 3 qts of gear lube, 3qts of atf, spare hydro hoses and fittings, a full set of TREs, misc ujoint yokes, and 2 rear axle shafts between the back of the bed and the box all with room left over to stuff my recovery gear in there. I couldn't even carry a third of that with the bed rail mounted tool box that took up a larger footprint. All that stuff will get me home provided I don't blow up the trans or get water in my motor and mess it up. Then again who's dumb enough to do that, right.....
    tacotim448, 11TRDTX and Justinogo like this.
  11. Dec 1, 2017 at 10:15 AM
    #1371
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
    Shit...just tow a spare truck!
    11TRDTX likes this.
  12. Dec 1, 2017 at 11:32 AM
    #1372
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    I don't know anyone who has gotten water in their motor then proceeded to beat the shit out of it immediately afterwards ...
    And ole Action Packer Mike will be super excited to read this post.
  13. Dec 1, 2017 at 11:43 AM
    #1373
    rngr
    01 SR5 4x4 2.7L
    Haha. @mpkramer71
  14. Dec 1, 2017 at 1:07 PM
    #1374
    slander
    Hickory, NC
    Practically. It's not the wheeling that bothers me, it's the 8+hr drive I have to take to reach anywhere cool to wheel! Most of it is if I have those parts with me, it won't break lol.
  15. Dec 1, 2017 at 1:09 PM
    #1375
    Dave41079
    Dave41079 Words go here.
    Dave...
    Nashville, TN
    The shittiest of boxes
    Things, stuff, and whatnot.
    Sounds like you need a trailer and a tow rig.
  16. Dec 1, 2017 at 1:18 PM
    #1376
    TN_TacoSupreme
    Allen
    Springfield, TN
    Or a U-Haul and move to these parts...partner.
    KRAMERICA and Dave41079[QUOTED] like this.
  17. Dec 1, 2017 at 1:25 PM
    #1377
    slander
    Hickory, NC
    Been there, done that don't want any of that ever again.
    No need it all fits in my action packer!
  18. Dec 1, 2017 at 1:28 PM
    #1378
    TN_TacoSupreme
    Allen
    Springfield, TN
    I meant you move here.
    Closer to all the cool kids.
  19. Dec 1, 2017 at 1:32 PM
    #1379
    TN_TacoSupreme
    Allen
    Springfield, TN
    Boy that'd be a hell of a conversation starter...." Honey...I wanna pack up all our stuff and move to TN so it's easier for me to wheel...ok?"
    rngr[OP] and 11TRDTX like this.
  20. Dec 1, 2017 at 1:43 PM
    #1380
    slander
    Hickory, NC
    That's my case for moving to Idaho lol
    Dave41079, jubei and Justinogo like this.
