Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Jan 3, 2018 at 6:30 AM
    #1481
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Badass!
  2. Jan 3, 2018 at 6:35 AM
    #1482
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    I know I am! The bumper is pretty cool too, huh? ;)
  3. Jan 3, 2018 at 3:52 PM
    #1483
    slander
    Hickory, NC
    The bumpers cool, the pics not so much. Need to be tipped on it's side into the water
  4. Jan 3, 2018 at 3:59 PM
    #1484
    rngr
    01 SR5 4x4 2.7L
  5. Jan 3, 2018 at 4:00 PM
    #1485
    TN_TacoSupreme
    TN_TacoSupreme The Yota Peddler
    Allen
    Springfield, TN
    2014 Silver Tacoma TRD Sport
    As much as I can til' my wife blocks my Amazon account...
    Steel baby buggy bumper looks good :thumbsup:
    Did your lil' beagle morph into a Pitt?
  6. Jan 3, 2018 at 4:29 PM
    #1486
    rngr
    01 SR5 4x4 2.7L
    Haha no. That’s Spot. He was a stray that earned himself a home with my friend. He’s really sweet. 70# of muscle, but is absolutely the most gentle dog I’ve ever seen. It’s really odd to watch Liz, the little red Aussie in the other pics, completely dominate him. Haha. He doesn’t care though... just wants someone to scratch his belly.
  7. Jan 3, 2018 at 6:04 PM
    #1487
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    sub'd :bananadance:
    rngr[OP] likes this.
  8. Jan 4, 2018 at 6:20 AM
    #1488
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
  9. Jan 4, 2018 at 6:21 AM
    #1489
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Build one. I believe in you.
  10. Jan 4, 2018 at 10:07 AM
    #1490
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Thanks :rolleyes: Maybe one day. Many other things that need to be done before a bumper.
  11. Jan 4, 2018 at 11:05 AM
    #1491
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yes but Carter will build you one for cost. All you gotta do is cut your bedsides and put it on. Bring it to a meet and I'll put it on. Hell bring the material to a meet and I'll build it for you. Haha
  12. Jan 4, 2018 at 11:15 AM
    #1492
    rngr
    01 SR5 4x4 2.7L
    Nope
    Hell of a deal right there.
  13. Jan 4, 2018 at 6:07 PM
    #1493
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    Great, thanks Carter! So generous!
    I'll order the supplies. Thanks again!
  14. Jan 4, 2018 at 6:30 PM
    #1494
    rngr
    01 SR5 4x4 2.7L
    Buddy it really is pretty simple. As long as you have a grinder and welder you can do it. Bandsaw and plasma make it easier.
  15. Jan 4, 2018 at 7:08 PM
    #1495
    Breezy
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    You have grinder and welder, yes?
  16. Jan 4, 2018 at 7:17 PM
    #1496
    rngr
    01 SR5 4x4 2.7L
    No welder.
  17. Jan 9, 2018 at 7:14 AM
    #1497
    rngr
    01 SR5 4x4 2.7L
    After a mini-sidebar of me wanting to get some bigger nasty tires, we're back on schedule. haha. I have an appointment with a guy to bend some tube for bed hoops in a couple weeks. Yay!!! Need to weld on a couple loops for safety chains.
    The next project is going to be gears. My main reason for wanting to make the switch is off-road rather than on (although it will be nice there too). In 4L, my 1st gear is too high when I need to crawl, leading to lots of clutch work. It’s pretty exhausting in the rocks. Likewise, 2nd is too high for those situations where you need speed/momentum. (Think steep, muddy hill climb). It’ll end up bogging down on me.
    I am currently trying to decide b/w 4.88 and 5.29. I think 4.88 would be the best "all around" while on 33's. However, My truck doesn't get much "all around" use. I'm either wheeling, or towing, or putting around home, where 55-60 mph is the most it sees. So being over-geared might not be that big of a deal. Plus, 5.29 would allow me to make the swap to 35's if I wanted. I think the 5.29s and 33's would be monstrous off-road, but I want to figure out if it would be bearable on-road. I used this calculator to find this information. http://www.grimmjeeper.com/gears.html
    The above shows RPMs in 5th at different speeds with the different possible gearsets/tire sizes. Top row is stock.
    *** For all you 2nd gen fellers, the accepted standard for 1st gens is 4.88 for 33's, and 5.29 for 35's.*** Opinions welcome and wanted.
    jubei likes this.
  18. Jan 9, 2018 at 7:37 AM
    #1498
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Ask Monte for some more advice. He has a pretty good handle on gearing and what pros and cons there are for each. But if you really are considering 35's I'd save up and do it all in one sweep. It'd be cheaper but take longer
    rngr[QUOTED][OP] likes this.
  19. Jan 9, 2018 at 7:56 AM
    #1499
    rngr
    01 SR5 4x4 2.7L
    Good idea! @Blackdawg cate to take a look 2 posts up and see what you think? I know there is an engine discrepancy to consider, but I figure you’ll still have a pretty good nose for it.
    Josh, this decision isn’t being made on the possibility of 35s. In all likelyhood it’ll never happen. This thing does so good on 33s. I just don’t want to go through all of this and still be wishing for more gear.
    BYJOSHCOOK[QUOTED] likes this.
  20. Jan 9, 2018 at 8:03 AM
    #1500
    rngr
    01 SR5 4x4 2.7L
    @allmotorrex which set of those rpms is closest to what you had on 35s?
