Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Jan 25, 2018 at 6:04 AM
    #1561
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Tim? Yeah, second gen problems :rolleyes:
    We'll see how bad it is for me. I got really light tires so the only concern is RPM
  2. Jan 25, 2018 at 6:06 AM
    #1562
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    No, it was a first gen. Somewhere up north IIRC
  3. Jan 25, 2018 at 6:10 AM
    #1563
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    Ah, gotcha. Well fingers crossed then haha, I doubt I'll have gears by LBL so that will be the test. 5.29s are coming at some point though
    Tires are only 10lbs more than my 265s and way lighter than most 315s so I'm hoping that alleviates a lot of the stress on components
    BYJOSHCOOK[QUOTED] likes this.
  4. Jan 25, 2018 at 7:17 AM
    #1564
    cynicalrider
    cynicalrider #NFG
    Jersey
    FWIW I ran the stock gears on 35's for a month or so. Definitely sluggish but not terrible. Being a manual definitely made it easier.
    Justinogo likes this.
  5. Jan 25, 2018 at 7:39 AM
    #1565
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    Gearing has nothing to do with diff strength.
  6. Jan 25, 2018 at 8:05 AM
    #1566
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    4.10s and 35s...sucks.
    You can get around town fine though. Highway driving...forget it.
    Also your tranny will hate you, hope you have a scan gauge to keep an eye on your tranny temps. You'll really be straining it.
  7. Jan 25, 2018 at 8:33 AM
    #1567
    cynicalrider
    cynicalrider #NFG
    Jersey
    Why would you be straining the trans? RPM's will be hella low. If there was not enough power you could just downshift to 4th or 3rd, no?
  8. Jan 25, 2018 at 8:40 AM
    #1568
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    No. You can't downshift. Thats against the rules :smack:
  9. Jan 25, 2018 at 8:41 AM
    #1569
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Don’t tell TW that. According to forum logic you aren’t geared right until you can pull the Eisenhower pass in 5th gear at 75
  10. Jan 25, 2018 at 8:47 AM
    #1570
    Blackdawg
    Monte
    Wyoming/St. Louis
    Sure rpms are low, but the load on the engine and tranny is VERY high with tires that big.
    He's a double cab so he has an auto.
    To get the truck moving he will slip a LOT. He also wouldn't be able to use overdrive at all on the highway, there is no way, so he would have to stay in 3rd and thus defeating the "low rpms". The auto will be sweating bullets with 4.10s and 35s. Totally driveable around town. But your asking for major problems offroading and on the highway.
    Its not about low rpms its about how efficient the truck uses the power. This is why everyone that has a heavy offroad rig puts off regearing over and over until they finally do it and are suddenly surprised at how much power they have back and WOW gain a few mpg back! Even though their rpm is higher. The load on the engine is less due to lower gearing so it doesn't have to work as hard. Same goes for the auto tranny.
    Dave41079 and BYJOSHCOOK like this.
  11. Jan 25, 2018 at 8:48 AM
    #1571
    Blackdawg
    Monte
    Wyoming/St. Louis
    I mean...i love being able to accelerate in 5th up steep hills on the interstate...who wouldn't?
    Only other truck i can do that is is my single cab V6 tacoma...and thats cause it weighs nothing and has more power than truck :laugh:
  12. Jan 25, 2018 at 8:57 AM
    #1572
    cynicalrider
    cynicalrider #NFG
    Jersey
    Ah auto problems. :p
    Blackdawg likes this.
  13. Jan 25, 2018 at 9:00 AM
    #1573
    Blackdawg
    Monte
    Wyoming/St. Louis
    no doubt. Love/hate relationship with mine.
  14. Jan 25, 2018 at 9:01 AM
    #1574
    cynicalrider
    cynicalrider #NFG
    Jersey
    Follow Safetydang's steps and manual swap that thing!
  15. Jan 25, 2018 at 9:09 AM
    #1575
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    Except an auto is better that a manual in a trail rig in every way
  16. Jan 25, 2018 at 9:14 AM
    #1576
    Blackdawg
    Monte
    Wyoming/St. Louis
    I've thought about it. But then i drive 48 miles to and from work everyday..doesn't seem bad then. And makes me drive more relaxed so i don't go race truck all the time :anonymous:
    ahhh...the great debate..
    Owning both and wheeling in both..I still prefer the manual personally.
    BYJOSHCOOK likes this.
  17. Jan 25, 2018 at 9:20 AM
    #1577
    cynicalrider
    cynicalrider #NFG
    Jersey
    Never stopped me yet. :burnrubber: Yes it makes it easier, but then you gotta worry about overheating the tranny when crawling.
  18. Jan 25, 2018 at 9:21 AM
    #1578
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    You also can burn your clutch up crawling too
  19. Jan 25, 2018 at 11:21 AM
    #1579
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah I don't agree with that. I just love driving a manual. Just that alone makes it better to me in every way. Is it harder? Yes. Does it take more work? Yes. Can just anyone hop in a manual and trail ride well/at all? No. I happen to love it being harder and more work. I can also drive very well. I've never questioned whether an auto would be better. I see a manual as my only option. You just gotta love the manual game. :thumbsup:
    4xtacoma, BYJOSHCOOK and Blackdawg like this.
  20. Jan 25, 2018 at 11:28 AM
    #1580
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    I like the look all the auto guys give you when you stall it on the trail.
    Also like sitting in my driveway with the engine off slamming gears while making race car sounds.
    :burnrubber:
