Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Jan 25, 2018 at 11:34 AM
    #1581
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Same! Never not owning a manual for my trail rig
    Glad I'm not the only one :fistbump:
    dirty deeds and rngr[QUOTED][OP] like this.
  2. Jan 25, 2018 at 11:59 AM
    #1582
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Tha fuck did you just say?? ....
  3. Jan 25, 2018 at 12:09 PM
    #1583
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Never NOT**** whoops :anonymous:
  4. Jan 25, 2018 at 12:19 PM
    #1584
    Snowy
    Snowy Is neither here nor there
    Connor
    Winnebago, IL
    3 linked 98 Xtra cab
    Stock-ish
    To each their own
  5. Jan 25, 2018 at 1:07 PM
    #1585
    cynicalrider
    cynicalrider #NFG
    Jersey
    My DD is a boring vanilla auto. Great for traffic and long trips. But there is something so satisfying about driving the manual on the trail. The need to finesse yourself up obstacles takes more work, most definitely but I really enjoy it. I don't wheel because it's easy, I wheel because it takes skill to control a vehicle a certain way. And it's a skill I have been perfecting over the years. Also when you get to fast sections of a trail, slamming through gears gives me a boner. That or downshifting into a corner and roosting.
    But like you said @Snowy to each their own.:thumbsup:
    BYJOSHCOOK likes this.
  6. Jan 25, 2018 at 1:29 PM
    #1586
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I use to drive that road a couple times a month with 4.10s and 295s.
    Speed limit is 65, only way I could pull that was in 3rd gear at like 4200rpm for 15 minutes straight.
  7. Jan 25, 2018 at 1:36 PM
    #1587
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    Ouch
  8. Jan 25, 2018 at 1:40 PM
    #1588
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    I stall mine too often :anonymous: 4lo helps a ton but it's such a dog and no fun cranking the RPMs but not moving when you wanna go faster!
    rngr[QUOTED][OP] likes this.
  9. Jan 25, 2018 at 2:07 PM
    #1589
    Snowy
    Connor
    Winnebago, IL
    Stock-ish
    It's all I could do to hold my 7.3 in third while towing the Tacoma through there :D
    On 25E and 119 going to Harlan, there is extensive use of third gear and foot to the floor with the Tacoma...with 5.29's and 37's
    :spy: crawlbox...
    dirty deeds[QUOTED] likes this.
  10. Jan 25, 2018 at 2:24 PM
    #1590
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Yeah for sure. That was my point. I drive one because I love it. Others don't for whatever reason. All good with me.
    slander likes this.
  11. Jan 25, 2018 at 2:24 PM
    #1591
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Hahahaha
  12. Jan 25, 2018 at 2:28 PM
    #1592
    allmotorrex
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    Not much more satisfying then kicking the clutch on a gravel road while getting sideways around a corner. I also kick my clutch when rock climbing on trails. :gossip: Don't tell anyone though. Someone will tell me I'm gonna destroy something. I'll tell them "yeah."
    better keep it in 2wd at LBL. We got some fun to be had :D
  13. Jan 26, 2018 at 7:12 AM
    #1593
    rngr
    01 SR5 4x4 2.7L
    Diffs arrived at ecgs safe and sound. :woot:
    Aaaaannnddd... I’m now teetering on the edge of the next rabbit hole in this truck. Here’s what I’m thinking.
    My plan was to keep running the 33s for a good while. However, I know once a get these gears in I’m going to be itching for 35s hard, which will require firewall tubs.
    It’s winter and I don’t “need” my truck much. During the summer I can’t afford to have the truck down for more than a day or two because I still do the lawn care thing on the side. So the tub job will either be now or a year from now.
    Also, my tires still have a ton of life in them now, and I think would be pretty easy to sell.
    Top contenders at the moment in no particular order are
    Hankook RT03
    Cooper ST pro
    Interco trxus mt
    Interco irok ND
    Again, just a thought for now. We’ll see.
  14. Jan 26, 2018 at 7:15 AM
    #1594
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I'd veto the interco tires if you drive it alot in the summer around town.plus aren't those usually like 36x10?
    It sounds like you need a 5 lug taco to take over lawn care :p 35s are expensive.
  15. Jan 26, 2018 at 7:21 AM
    #1595
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Says the guy who had to buy a tow rig because his trucks too slow on the highway...
    Blackdawg, BYJOSHCOOK and dirty deeds like this.
  16. Jan 26, 2018 at 7:22 AM
    #1596
    rngr
    01 SR5 4x4 2.7L
    Nah. The ND is a 315/75/16 and the trxus is a 35/12.5. I don’t drive it a lot. I just drive it often. Live within 4-5 miles of everything. Benefit of living in a tiny town. Haha.
    Blackdawg[QUOTED] likes this.
  17. Jan 26, 2018 at 7:53 AM
    #1597
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    IROKs would look badass on your truck.
    Since you're tubbing anyway, go 36!
    beertimecontinuum likes this.
  18. Jan 26, 2018 at 8:00 AM
    #1598
    rngr
    01 SR5 4x4 2.7L
    Nah. I feel like 35s will be pushing the limits of what this little truck’s components will handle anyway.
    The irok ND is a tamer tire than the original. More along the lines of the other tires I listed. They actually describe it as an “all terrain” on their site. Even though it’s probably the most aggressive tire on my list.
  19. Jan 26, 2018 at 8:04 AM
    #1599
    Blackdawg
    Monte
    Wyoming/St. Louis
    gotcha.
    I mowed lawns for like 12 years as a kid and into college. Was fun. I kinda miss it.
  20. Jan 26, 2018 at 8:06 AM
    #1600
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    are you really sure you won't want more? :boink:
    bet you'll be on solid axles next year.
    rngr[OP] likes this.
