Redeemed: rngr's Trail Taco w/side of T4R
Discussion in '1st Gen. Builds (1995-2004)' started by rngr, Jul 31, 2016.
  1. Feb 4, 2018 at 12:16 PM
    #1741
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    If that's the one without the button, yes.
    rngr[QUOTED][OP] likes this.
  2. Feb 4, 2018 at 12:25 PM
    #1742
    rngr
    rngr [OP] Aix sponsa
    01 SR5 4x4 2.7L
    That’s it.
    So you did this?
  3. Feb 4, 2018 at 12:57 PM
    #1743
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Verify this in the wireing diagram in the FSM first! I wired my add to a switch, you do this by popping off both shift boots and when you are looking down at the top of the tcase you will see two plugs, one on each side of the top of the case, with wires coming out of them. You want the one that controls the add system (that's where the FSM comes in). Cut the wires off the plug, splice in some extra length and hook then up to a switch. Pretty easy. I didn't fuck around with wireing harnesses and modules like the TTORA link has you doing.
    Yes I had a jshift. I actually had to do this mod when I swapped in the lefty.
    Justinogo likes this.
  4. Feb 4, 2018 at 1:51 PM
    #1744
    GreeGunc
    Jacob
    North GA
    Yes
  5. Feb 7, 2018 at 9:20 AM
    #1745
    cynicalrider
    cynicalrider #NFG
    Jersey
    @Reh5108 has this done as well IIRC
    Reh5108 and rngr[QUOTED][OP] like this.
  6. Feb 7, 2018 at 10:35 AM
    #1746
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    This is where twin sticks come into play as well...nice to throw a lever, make the turn and re-engage. :cool:
  7. Feb 7, 2018 at 10:38 AM
    #1747
    GreeGunc
    Jacob
    North GA
    Or flick a switch make the turn and flick again:burnrubber:
  8. Feb 7, 2018 at 10:52 AM
    #1748
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Been there, did that. Would still reccommend the twin stick to anyone with a lunch box style front locker.
    Also, need to be stopped to re-engage (don't forget a momentary switch so you dont burn up the motor as well). No synchro for the ADD diff fork to slide over. Most of your t-cases besides (factory manual hubs/ j shift) have this synchro so you can maintain moment and still engage.
    Both together make it close to the ARB.........well almost:rolleyes:
  9. Feb 7, 2018 at 10:53 AM
    #1749
    Justinogo
    Justinogo Well-Known Member
    Justin
    Memphis, TN, USA
    1985 4Runner
    3rz, 37s, Locked, 5.29s, 4.7 Marlin case, OG LongFields
    Except no worries about air lines and compressors derping out :thumbsup:
    dirty deeds and ToyRyd04[QUOTED] like this.
  10. Feb 7, 2018 at 11:11 AM
    #1750
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm pretty sure I wired mine differently than you did. I do engage and disengage at slow speeds with the clutch in, going straight and haven't had an issue yet. If my switch is in the on position and I shift from 2wd to 4 the ADD acts as it usually would.
  11. Feb 7, 2018 at 11:12 AM
    #1751
    rngr
    01 SR5 4x4 2.7L
    Should have let you all know what I ended up deciding.
    Drumroll, please...
    35s will be on hold for a bit. Going to save up and put an ARB in the front. Then, I’ll make the move up in tires.
    My goal here isn’t to see how fast I can get this thing double locked on big tires. It is to end up with exactly what I want, and something I’ll be happy with, while having as much fun as I can with it along the way.
    I know I’ll be much happier with a selectable front. Sincerely appreciate everyone’s input along the way.
  12. Feb 7, 2018 at 11:14 AM
    #1752
    rngr
    01 SR5 4x4 2.7L
    Now that you’re here...
    Not sure if I ever told you I ended up going to 5.29 over 4.88. You were right, it’s awesome. As long as you don’t mind your top speed being 70. Haha
    Reh5108[QUOTED] likes this.
  13. Feb 7, 2018 at 11:16 AM
    #1753
    Reh5108
    Idaho
    It actually @ToyRyd04 old diff. I did just help my roommate install one in his 3rd gen 4runner. Hasn't been set back on its feet yet but install seemed pretty easy.
    I like the fact that it does ratchet and allows you to still turn most of the time. I don't have experience with a selectable in the front but I'd imagine it would be near impossible to turn on slick rock.
  14. Feb 7, 2018 at 11:19 AM
    #1754
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    Got me curious...? Did you wire directly to ADD motor, or use with the t-case position sensor?
  15. Feb 7, 2018 at 11:19 AM
    #1755
    Justinogo
    Justin
    Memphis, TN, USA
    1985 4Runner
    ARB by LBL?
  16. Feb 7, 2018 at 11:19 AM
    #1756
    Reh5108
    Idaho
    Well if you're ever tired of screaming down the highway I've got some 4.88s I'll trade ya:D I'm really hoping a small turbo helps me.
  17. Feb 7, 2018 at 11:23 AM
    #1757
    Reh5108
    Idaho
    I just interrupted the signal to the ADD so when the switch is off the ADD doesn't know it's supposed to change positions.
    ToyRyd04[QUOTED] likes this.
  18. Feb 7, 2018 at 11:24 AM
    #1758
    rngr
    01 SR5 4x4 2.7L
    Doubtful. No worries though. Don’t even need 4wd for lbl. Haha.
    Negative. But I’d imagine they’d be pretty easy to sell on here.
  19. Feb 7, 2018 at 11:27 AM
    #1759
    ToyRyd04
    Greg
    Perryville, MD
    '04 PreRunner
    hmmm...well damn idk, dont think the 4wd ecu has anything todo with it so not sure. But that's awesome its working for you, that was really the only big draw back I ever had.
  20. Feb 7, 2018 at 11:27 AM
    #1760
    Reh5108
    Idaho
    I wouldn't be able to sell them to cover half the cost of another regear and arb. I think trading is the only way it would be worth regearing again to me.
