Redline, 2GR-FKS, Tacoma vs Highlander
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Snoman002, Nov 1, 2021.
  1. Nov 1, 2021 at 1:07 PM
    Snoman002
    Snoman002 [OP] Well-Known Member
    Sno
    21 DCSBORSWMT
    Owning both a Highlander and a Tacoma I recently noticed the redline is different between the two, with the Highlander pushing the redline higher.
    Both use the same engine model, what are the differences between the two (engines)?
  2. Nov 1, 2021 at 1:46 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Different tunes, likely different cam profiles etc.
  3. Nov 1, 2021 at 1:49 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    My wife had a 2020 Highlander for a short bit. The power train was a lot more smooth and responsive than my Tacoma. There is a video on youtube by CarCare Nut that explains the difference between the two engines.
    DAS Taco and Snoman002[OP] like this.
  4. Nov 1, 2021 at 1:56 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    7,250rpm here.
    As you can see, HP and TQ are dropping off nicely, which gives a nicer shift than tickling the 6k limiter:
  5. Nov 1, 2021 at 2:20 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Yep.
    Valve timing for intake&exhaust, ignition timing and design differences for intake&exhaust.
    I run a tune that uses stock Camry's valve timing and adjusted ig timing and you can see a difference.
  6. Nov 1, 2021 at 5:09 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Tacoma is tunes for less HP and more torque lower in the RPM range for reliability.
  7. Nov 1, 2021 at 5:10 PM
    Bishop84
    Bishop84 Well-Known Member
    Underhood temps are a major concern as well, along with emissions, fuel economy etc.
    Highlander makes way more power, but isn't designed for sustained loads.
    usmc2msu and Kev250R like this.
  8. Nov 1, 2021 at 5:12 PM
    flatus
    biloxi,ms
    That's funny stuff right there.
    Tacomod, Hank Heel and Vlady like this.
  9. Nov 1, 2021 at 6:11 PM
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
    The tuning including available valve timing ranges are different between the two. There are a number of key differences between different variants of the 2GR.
    But, it is similar enough that it could handle the higher revs without breaking or anything. It’s just tuned differently, making those higher ranges less useful.
    Jeff
    Kev250R and Skydvrr like this.
