Redline feeling at 3500rpm
Discussion in '1st Gen. Tacomas (1995-2004)' started by turkeyhunter21, Nov 22, 2021.
  1. Nov 22, 2021 at 2:23 PM
    turkeyhunter21
    turkeyhunter21 [OP] Well-Known Member
    1998 Supercharged Tacoma 4x4 Limited
    33X12.50-15's and zip-ties.
    I have a 2002 Toyota Tacoma SC. The truck redlines at like 3500rpm when I go to pass and jerks around until I let off gas. New engine in truck. Any ideas?? I’m replacing cats this week. Engine has slight noticeable surges when under normal acceleration then when hammered down on to down shift it just acts like it’s redlined at 3500rpm
  2. Nov 22, 2021 at 6:04 PM
    Glamisman
    Glamisman Well-Known Member
    if SC stands for supercharged… check your plug gaps first.
  3. Nov 22, 2021 at 6:11 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Are you running a 7th injector or some other fuel management?
  4. Nov 22, 2021 at 7:08 PM
    turkeyhunter21
    I’m not running a 7th injector kit and I haven’t checked gaps. I did put new plugs in though.
  5. Nov 22, 2021 at 7:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Wow. Are you at sea level? Any detonation issues?
    I would look there for solutions to your issues. That and crankshaft and camshaft sensors. Not sure if they will throw a CEL. I don't think so.
    @97tacomav6 Didn't you run into an issue with your crank sensor that was limiting RPMs?
  6. Nov 22, 2021 at 7:52 PM
    turkeyhunter21
    I’m not getting any codes just occasional misfire when rev’d too long. I live in Arkansas.
  7. Nov 23, 2021 at 5:40 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    will it rev past 3500rpm at all? like in neutral? if so then crank sensor is toast.
    maineah likes this.
  8. Nov 23, 2021 at 5:46 AM
    devinzz1
    devin
    2023 aclb trd or mt
    i did
    https://youtu.be/Zid2wnJxDSE
  9. Nov 23, 2021 at 5:48 AM
    Clearwater Bill
    Billy
    Largo Florida
    A clogged fuel filter will 'limit' RPM by not providing enough fuel to go higher.
    Just a thought.
  10. Nov 23, 2021 at 5:53 AM
    turkeyhunter21
    No it will not rev past 3500 in neutral either. Very similar to the video. In gear or in neutral.
  11. Nov 23, 2021 at 5:55 AM
    devinzz1
    devin
    2023 aclb trd or mt
    then i would start with crank sensor. get a oem/denso one. I tried a cheap ebay one first and it barely worked at all
  12. Nov 23, 2021 at 6:00 AM
    turkeyhunter21
    Ok thanks. I’ll give it a go. Seems like it’ll be a pain to change out.
  13. Nov 23, 2021 at 6:05 AM
    devinzz1
    devin
    2023 aclb trd or mt
    takes 5 minutes. its in with a single 10mm bolt. you can reach up from the front drivers side under radiator to do it. nothing else needs to be removed.
  14. Nov 23, 2021 at 6:16 AM
    02hilux
    Planet: EARTH
    I am 99.9% sure you have a bad MAF based on your symptom.
  15. Nov 23, 2021 at 7:01 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Unplug the MAF and let it run rich in limp mode. See if it revs better.
  16. Nov 23, 2021 at 7:47 AM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    I don't have a supercharger on my truck but I experience the same thing on my boosted car before. I needed to tighten the spark plug gaps. The spark was getting blown out by boost creating a misfire.
  17. Nov 23, 2021 at 8:29 AM
    turkeyhunter21
    It does not rev better with the MAF sensor unhooked. Still revs out.
  18. Nov 23, 2021 at 8:54 AM
    turkeyhunter21
    How many crank sensors are on the Tacoma? 1 or 2 1 camshaft sensor right?
  19. Nov 23, 2021 at 10:31 AM
    devinzz1
    devin
    2023 aclb trd or mt
    1 crank. 1 cam
  20. Nov 26, 2021 at 6:09 PM
    turkeyhunter21
    MAF sensor and air and fuel filter didn’t change a thing. Same redline at 3500rpm. I guess I’ll be buying a new denso crank sensor
