Redline gear oil vs manual transmission lubricant
Discussion in '1st Gen. Tacomas (1995-2004)' started by y2kh8r, Mar 9, 2016.
  1. Mar 9, 2016 at 2:13 PM
    y2kh8r
    y2kh8r [OP] Member
    01 tacoma 2.4 5-speed
    It seems that Redline is making two gear oil products now, help me pick one! The manual transmission specific version claims to be less slippery and low sulfur for brass synchros. It's also $2.50 more per quart. Anyone used the manual specific stuff?
    While I'm posting, I can't seem to find the drain/fill plugs on my 01 taco.
  2. Mar 9, 2016 at 9:56 PM
    4thone04
    4thone04 Well-Known Member
    jcl
    west END of hwy2
    new at 155,000
    One of the red line oils is a gl-5 and one is gl-4. If your talking about the mtl it's good for the trans proper. The t-case and axles use the gl-4.
  3. Mar 9, 2016 at 11:00 PM
    bry838
    bry838 Well-Known Member
    oregon
    '00 tacoma 2.7 4x4 reg cab 5speed x's 2. '01 T4R 3.4 5 speed
    Drain and fill plugs are the large low profile headed bolts. One on bottom and thenfill should be halfway up on the drivers side of the tranny.
  4. Mar 10, 2016 at 3:56 AM
    NCJeyota
    NCJeyota Well-Known Member
    Raleigh,NC
    2002 Tacoma 3.4 v6 Prerunner
    Redline MT-90 is the one you want.
  5. Mar 10, 2016 at 5:40 AM
    fireman1073
    fireman1073 Well-Known Member
    stephen
    new bedford,mass
    06 4runner sport v6
    none yet
    i put in napa 80w90 gl-4 it shifted like crap so i dumped it and put in lucas 75w90 synthetic gl4-gl5 and now it shifts like butter 14.99 at the zone
  6. Mar 10, 2016 at 6:45 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    I am using Red Line MT-90 in my 2000 RAV-4.
    I originally put in some AMSOIL and was having huge issues because it was too slick. After 1 month of that bullshit I replaced it with the Red Line.
    I would recommend getting something designed for Brass Synchros.
