Redline MT-90!
Discussion in '1st Gen. Tacomas (1995-2004)' started by defleppardsg, Oct 24, 2012.
  1. Oct 24, 2012 at 11:40 AM
    defleppardsg
    defleppardsg [OP] Well-Known Member
    chris
    texas
    2.7L SR5 4x4
    OME 880's, Wheeler's Offroad 5-Leaf pack. Bilstein 5100's, 1" Daystar shackles, Deck Plate Mod.
    After reading all of the recomendations here, I put Redline MT-90 in my trans a couple of weeks ago. Wow- usually with small mods or expensive oil brands, etc, you can't really actually feel a difference, but with this stuff, I can. I wasn't having a problem shifting before, but now the shifts are as smooth cold as they are when the truck is up to temp. I can tell a difference too when the vehicle is just cruising on the highway, it just feels smoother.
    The next week I changed the transfer case, and rear dif. Intended on getting Mobil1 75-90 for both, but two stores didnt have enough, so I actually went with Valvoline synthetic 75-90. I trust its a quality oil. Now that I've got everything changed in the driveline, the truck feels very very smooth.
    Question: when i drained the transfer case and the dif, the oil smelled, but it wasn't brown or anything. I know they were in there for about 70K. Do gear oils get brown/black when they get worn out or not really?
  2. Oct 24, 2012 at 11:43 AM
    ffirg
    ffirg Well-Known Member
    mike
    Anchorage, Alaska
    2002 Tacoma SR5 TRD 4X4
    The gear oil in my diffs smelled awful. I'm pretty sure that's normal. Mine didn't look that burned up but I also have no idea when it was last changed.
  3. Oct 24, 2012 at 11:46 AM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Gear oil smell regardless of what brand, synthetic or not. I recently changed my trans and x-case 4 days ago and I can still smell the oil slightly. I used redline as well.
    If I recall, they turn to a cloudy dark grey color when dirty.
  4. Oct 24, 2012 at 12:33 PM
    scocar
    scocar hypotenoper
    Gear oil is made from dinosaur anus, so it smells like ass.
    97tacotruck, Rocan, Wulf and 6 others like this.
  5. Aug 23, 2018 at 6:11 PM
    eppy
    eppy Well-Known Member
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Homer M3 thin lip Satoshi, BAMF Light Bar, BAMF Batwing Tie Downs, Coupe Custom Battery Hold Down, Mattgecko Bed light kit, nj636 hub/wheel bearing set-up,Shorty Antenna, JL Audio & Boston set-up, 4x4 switch light MOD, Icon 2.5 coil overs and rear shocks, All Pro flip kit, Wheelers AAL, OcTaco SS brake lines, Light Racing UCA's and custom 6 speed Ellis Precision Shift knob. Coupe modified short shifter, AISN clutch pack, URD TOB kit, and Sachs flywheel. Mobtown's rocking tailgate skin!
    How many quarts is required top off the transmission?
  6. Aug 24, 2018 at 3:54 AM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Where do you buy this juice? I haven't seen it in the parts stores.
  7. Aug 24, 2018 at 4:21 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    LMAO, I'm stealing this!
  8. Aug 24, 2018 at 5:24 AM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Well said sir! :hattip:
  9. Aug 24, 2018 at 6:11 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    I have an 04 jetta. When the old fluid would warm up my trans would grind slightly into 2nd and 3rd. Switched to MT-90 and it doesn't do it any more. Shifts a lot better and just feels better. It's GL-4 so it's rated for yellow metals (brass). I am also going to put it into my R150 in my Tacoma. It's all brand new innerds so I think the Redline will work great as well.
  10. Aug 24, 2018 at 9:08 AM
    jphaxx
    jphaxx Active Member
    I think it was about 2.35 quarts for a manual trans. MT-90 GL-4 has eliminated all grinding in my transmission. The MT-90 GL5 is in all my other cases
  11. Aug 24, 2018 at 9:25 AM
    eppy
    Rob
    Maryland
    05 V6 TRD OFFROAD
    Thnx and order two bottles off Amazon!!!
