Redline MT-90
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoTim85, Jan 4, 2020.
  1. Jan 5, 2020 at 1:03 PM
    TacoTim85
    TacoTim85 [OP] Well-Known Member
    Vancouver, Washington
    2007 4Runner Sport Edition 4WD (Current)
    I'm mainly just hoping it will "loosen up" some when shifting it right after a cold start.
    I realize that it will always be tighter when "cold" before it's up to operating temp. Maybe with some more miles it will loosen up more. Only just now getting somewhat broken in with 2,000 miles.
    On a previous vehicle I saw improvements in shifting smoothness after changing the fluid type so I figured why not try it since multiple guys here said to try Redline MT90.
  2. Jan 5, 2020 at 1:10 PM
    Shadowhunter
    Shadowhunter Well-Known Member
    Nate
    Birdsview Washington
    13’ DCSB MT Sport
    Front and Rear Locked, 35’s, Chevy 63” swap, Fox Suspension and a bunch of other shit too long to list.
    Do not cheap out on the pump. I did and by the time I was done I had MT 90 in my arm pit and a broken cheap pump. I had to hose clamp the hose on to a normal 90wt jug cap and squeeze it in, not fun. I also drained it into my oil catch tub. It splattered everywhere draining it. I would recommend pulling the plug and running it into something deep like a coffee can or some sort of tub you can hold up there.
    shakerhood, TacoTim85[OP] and Skydvrr like this.
  3. Jan 5, 2020 at 1:30 PM
    TacoTim85
    Gonna try the sneaky Pete pump I linked above. I have a deep, round drain pan that should work well.
  4. Jan 5, 2020 at 3:01 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Little OT but have noticed Gear Oil is starting to come in bags instead of bottles, seems like a great idea for getting into tight areas.
    TacoTim85[OP] likes this.
  5. Jan 5, 2020 at 3:22 PM
    Metal Toy
    Metal Toy Well-Known Member
    2021 2.7L AC 4x4
    The MT's smooth out quite a bit as you get more miles on it. Mine is very smooth now at about 8500 miles. I also changed my trans oil about 1000 miles ago to Amsoil. Amsoil made the shifts even smoother/less clunky.
    TacoTim85[QUOTED][OP] likes this.
  6. Jan 5, 2020 at 3:36 PM
    TacoTim85
    I did notice my very first 1 to 2 shift of the morning (when everything is dead cold) has gotten less crunchy/notchy. It was a little cringy for a while. Now it's just notchy feeling, not really cringy. Lol.
    DTaco18 and Metal Toy[QUOTED] like this.
  7. Jan 5, 2020 at 5:52 PM
    DTaco18
    DTaco18 Well-Known Member
    2020 TRD SPORT DCSB 6AT MGM
    The first 1->2 shift is still crunchy for me two years later. I've gotten used to it so it can be avoided...
    Going to synthetic wasn't a significant improvement for the morning 1-2 crunchiness, but I did notice improvement in general.
  8. Jan 5, 2020 at 7:01 PM
    TacoTim85
    Did you switch to Redline MT90?
    Sounds like your trans has the same cold operation characteristics as mine. I suppose it's normal and nothing to worry about. I ain't mad about it getting a little smoother so far, though! Hopefully the new trans oil will help some. If not, no big deal.
  9. Jan 6, 2020 at 3:13 AM
    DTaco18
    Yes, tried MT-90 for about 1000mi and then Motorcraft XTM5QS. I think the Motorcraft is a bit smoother overall, but there's not a huge difference. The Motorcraft comes in standard quart bottles from rockauto for about $15ea...
  10. Jan 9, 2020 at 9:00 AM
    chaotic_taco
    chaotic_taco Well-Known Member
    ATX
    2017 DCSB TRD OR MT
    I got the slippery pete pump, two actually. One for the Redline MT-90 in a gallon bottle, the other for the 75w-90 quarts for diffs. The pump comes with a couple different threaded bits for different bottle mouth sizes.
    I also noticed a slight improvement with shifting, changed my fluids at 30k.
  11. Sep 6, 2021 at 4:56 AM
    Rocket350
    Rocket350 Member
    2019 TRD Sport MT
    I went with an Ace Hardware 2 gallon garden sprayer for under 20 bucks. Replace the plastic wand with a Chapin brass wand with a curved end for easier access to fill plugs. Give it around 40-50 pumps pull the trigger and it will transfer around 2 qts in less than 5 minutes.
    C41n likes this.
