Redline Oils: A+
Discussion in 'Technical Chat' started by tacama321, Jan 14, 2018.
  1. Jan 14, 2018 at 8:05 PM
    tacama321
    tacama321 [OP] Active Member
    Mondo
    Amarillo, TX
    1997 Toyota Ext.Tacoma 4x4 3.4L
    1997 Tacoma, 268,000 miles, manual. I got it two months ago. From TW readings I decided to change transmission, transfer, engine, power steering, and also use coolant additive. Very noticeable difference in transmission shift, engine ran smother and I think cooler, power steering was significantly better, and the smell of a hot engine was gone. Now 2 months later the power steering was getting a little stiff. I did not change the whole system, only using a turkey baster to change as much as possible. So I used the turkey baster again and the power steering fluid makes a significant difference. The cost is a little more, but the outcome is worth it. New Fan of Redline Oils.
    ninja89 likes this.
