Redline Tuning Hood Struts
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2017TACOPRO, Jan 13, 2017.
  1. Mar 30, 2018 at 11:00 AM
    #41
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Question for those that have them installed on the 3rs gen. Does the hood open up further. The prop rod seems too short.
  2. Mar 30, 2018 at 11:02 AM
    #42
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I've checked and I have seemed to have lost about an inch of hood lift compared to the factory prop rod. For me that really makes little difference since I like the convenience of just opening the hood and not having the rod in my way.
    Ruggybuggy[QUOTED] likes this.
  3. Mar 30, 2018 at 11:04 AM
    #43
    H3ATH3N2016
    H3ATH3N2016 Soul Stealer
    Bren
    Jones County, Ga
    2016 DCSB TRD SPORT 4x4
    9"+/- Lift, 20" Dropstars, 35x13.50x20 Toyo Open Country M/T, Predator Tube Rails, Ultimate LED signal lights, Much Much More
    Being lifted as much as I am and vertically challenged, im hoping this will help me. I need a step stool to get the hood high enough to use the prop rod :facepalm:I've got them in the truck haven't installed yet.
    Ruggybuggy likes this.
  4. Apr 6, 2018 at 6:41 PM
    #44
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    Well, the passenger side shock has decided to keep the pressure up and raise up again. So, my original issue is back. Not so happy with the shock at this point.
  5. Apr 7, 2018 at 3:24 AM
    #45
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    SCS F5, 5100, Kenwood-Kicker/Polk
    most definitely worth it
  6. Oct 8, 2018 at 1:29 PM
    #46
    esills
    esills Member
    2018 Tacoma TRD Sport
  7. Oct 17, 2018 at 3:37 AM
    #47
    House Forsaken
    House Forsaken Well-Known Member
    Paul
    2015 Tacoma TRD Off Road (Traded) 2017 TRD Off-Road (Traded) 2018 TRD Off-Road
    I know this thread is a bit old, but last I heard with these was they didn't fit with the TRD intake, can anyone confirm that these CAN be used WITH the TRD intake? TIA!!
  8. Oct 17, 2018 at 7:07 AM
    #48
    greg8765
    greg8765 Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    hoping they do a black friday sale :)
  9. Oct 17, 2018 at 4:27 PM
    #49
    Marbleyard
    Virginia
    2019 4Runner Pro
    I can tell you they don’t fit the K&N without modifying the enclosure at the intake. I know this doesn’t answer your question at all but maybe it will help someone else... and maybe give you a bump.
  10. Nov 6, 2018 at 10:15 AM
    #50
    Redline870
    Redline870 Well-Known Member
    2018 Cement Tacoma TRD Off-Road
    I am thinking about purchasing these but have a couple concerns:
    For one, I've read a couple concerning reviews saying that they cause some noticeable flex in the sheet metal where the mounts are located.
    Two, I'm worried about the rivets rusting and therefore rusting the sheet metal they are attached to.
    Third, I'm concerned with the rivets loosening up over time. Many, many times in the past, I've seen rivets loosen up and then start to egg out the material they're attached to.
    Has anyone had these installed for several years without issue? I almost wonder if using a structural epoxy in conjunction with the rivets would make for a more solid installation. If my concerns are not founded, I'll definitely purchase them, though I wish the elite kit wasn't polished stainless. I'd gladly pay $30 more if it WASN'T shiny stainless steel!
  11. Nov 6, 2018 at 10:17 AM
    #51
    Methadras
    Methadras Well-Known Member
    South DFW, TX
    2021 White TRD Sport 2WD
    Fox 2.0 Lift, JLA Uppers, Dual battery setup, ARB-Double Barrel compressor, CBI skidplates, CBI Covert bumper, Winch, various light setups.
    For me it did, but not much. Maybe a 1/2" or so. No big deal to be honest.
  12. Nov 6, 2018 at 10:18 AM
    #52
    Invid
    2016 Tacoma Limited
    I've had mine installed for almost three years now without any issues. There's no flex where the rivets attach to the hood or engine bay. I used a rust prohibitor on the drilled holes prior to popping the rivets so I'm not worried and to this day they work and look great.
  13. Nov 6, 2018 at 10:21 AM
    #53
    Methadras
    South DFW, TX
    Valid concerns, but will evaporate once you do it. I had the same, but it's one of the best upgrades I've ever done. There is very little flex in the hood or in the mount section because those are bolstered bent areas. You'll see it once you do it. The rivets will not rust and as a preventative, you can put down a little RTV under the bracket to help prevent any intrusion of water.
    When you pop those rivets in, they are tight. Super tight and if they do loosen, which I haven't experienced, you can drill them out and pop new ones in. Super simple.
    I will say this. Measure measure measure and measure again. You only get one shot it is, so follow the instructions carefully. Use blue tape to make marks and protect your paint. Use a center punch before you drill. Otherwise, enjoy the upgrade.
    p.s. one more thing I just remembered. When you drill to the hood side, if you have one, use a drill collar to set the drill depth. Don't use tape, get a drill collar. They are cheap and they work. Nothing will suck more when you are drilling on the underside of the hood and you overdrive that drill and hit the underside of the top of the hood and you ding it. There is a lot of gap there, but human nature being what it is, I'd do it as cheap insurance.
    doublethebass likes this.
  14. Nov 6, 2018 at 10:28 AM
    #54
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    2 years on my truck, no issues.
  15. Nov 6, 2018 at 11:18 AM
    #55
    1911tex
    1911tex Well-Known Member
    2018 Silver Metallic Limited
    I had prop rods on a previous vehicle. Worked great; however, there were several times I wanted to lift the hood much higher than the rods would allow in order to reach near the firewall, so had to de-rivit (not good). Also on previous vehicle I could raise hood without the prop rods to lean against the windshield with a pad (somewhat like a "jeep"), so I eventually removed the rods altogether. I don't know if the Tacoma hood will lay against the windshield if necessary without prop rods? Yes the Tacoma hood is heavy; but I like that it is made of steel and not aluminum.
  16. Nov 27, 2018 at 5:38 PM
    #56
    Markc1024
    Markc1024 Well-Known Member
    I just received a kit, but have not installed yet. The rods don't seem to compress as they come out of the tube. Is this normal? I'll presume they need some weight to compress, but I was trying to compress them against a table and they didn't budge.
  17. Nov 27, 2018 at 8:01 PM
    #57
    Markc1024
    Thanks.
  18. Nov 27, 2018 at 8:53 PM
    #58
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    I have the TRD intake and I installed the Elites earlier today.
    Plenty of clearance in there.
  19. Nov 27, 2018 at 10:12 PM
    #59
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    I have had mine for a year now without any problems. Very nice “upgrade”.
  20. Nov 28, 2018 at 3:37 AM
    #60
    House Forsaken
    Paul
    WOW! That's awesome!! Thank you for updating this!
