'Redneck" lower control arm - LCA Bushing Press
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoBow, Jan 19, 2011.
  1. Sep 20, 2012 at 6:48 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I still have a couple cut off wheel blades from your recommendation. Unfortunately, my grinder was too big to fit in there to cut through, even with all the safety guards removed :( Is yours a 6" wheel?
  2. Sep 20, 2012 at 7:07 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Nope. I had to rotate the LCA to get a full cut.
  3. Sep 20, 2012 at 7:43 AM
    nut
    nut she'll ride
    Patrick
    Arizona
    Totaled
    TRD SKEWP DCSB 4x4 Silver Mica | URD TCAI/MAF CAL | BHLM | GrillCraft | FF Sliders | LED's All Around | 12v Constant On | EGR In Channel | 15% Tint | Trimmed mud flaps | Fog Light Anytime Mod | Debadged | Tailgate Hoseclamp | DTRL Switch | Disabled Lock Beep/Seatbelt Chime | Husky Liners | HID's | BedRug | WO Seat Covers | ABS Kill Switch | Oil Catch Can | Viper 5704 | Custom Carbon Cabin Filter | Backup Camera Anytime | 400W Anytime | In Cab Outlet W/USB | Firestone Ride Rites | Ams Oil All Around | 32" LED In Lower Grill | BlackVue DR500GW-HD |
    Awesome write-up. I love shit like this!
  4. Sep 20, 2012 at 8:01 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Just read the first part smart idea and Subd for future reference
  5. Sep 20, 2012 at 8:09 AM
    Pugga
    Massachusetts
    Eh, oh well... by the time the truck needs a second set of bushings, it'll be someone else's problem (and they should press out next time cause I actually lubed them on the way in. Toyota, take note :mad:)
  6. Sep 20, 2012 at 10:10 AM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
  7. Feb 25, 2013 at 1:31 PM
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Thread revival.
    What are some of the things I should try before cutting the camber bolt? I took my truck into get an alignment and they said one of my camber bolts were seized....
  8. Feb 25, 2013 at 1:46 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    TRY N LOOSEN IT YOURSELF
    SPRAY IT WITH PB BLASTER
    TRY A LIL HEAT IF THAT DONT WORK
  9. Feb 25, 2013 at 2:42 PM
    Pugga
    Massachusetts
    ^this. Mark your tabs so you can crank on them and get them back to where they were.
  10. Feb 25, 2013 at 4:19 PM
    TacoBow
    TacoBow [OP] Intentionally cosmetically correct.
    Central PA
    2015 Tacoma TRD Sport 4x4 Quad LB
    Sadly, if it's a true "Nor-east coast" related seized bushing with its bolt rusted fast to the inner sleeve, (commonly induced by DOT road calcium), I'll bet you all a paycheck nothing but cutting will cure it. It doesn't hurt to try the other three, but it's not likely to yield favorable results.
    Be careful if you apply big heat... the risk of unrelated non suspension related damage is real. I've cut around more frames, gas tanks and the like over the years of issuing inspection certificates in the rusted out center of this state (PA) than a little bit. I'm no rookie and know full well what the accurate application of heat coupled with pneumatics can break loose. Tacoma LCA's and their mounts? No thanks, it's just too tight to do it proper with an O2 flame.
  11. Feb 25, 2013 at 7:16 PM
    Drunknsloth
    Retribution
    South West
    Thanks. I'll definitely try these.
    I'm guessing a heat gun won't get it nearly hot enough?
  12. Feb 26, 2013 at 5:28 AM
    Pugga
    Massachusetts
    I heat gun will not do anything. I also would not try a torch unless you are committed to replacing the bushings. Keep in mind you're applying heat to a rubber bushing. They take a LOT to melt (I burned mine out so believe me, they do not easily melt) but rubber can only take so much.
    Before I actually committed to replacing my bushings, I marked the LCA from the cabs to the frame and hit them with PB Blaster, a wrench and whacked the end of the bolt with a hammer to see if they would break loose. I did this every day for a week. Once I realized they weren't budging, I just replaced them.
  13. Feb 27, 2013 at 10:51 AM
    Drunknsloth
    Retribution
    South West
    I'll definitely give this a try when I have the time.
  14. Feb 28, 2013 at 3:10 PM
    XXXX
    sKiP
    05 Prius
    X2... I tried mine for over a week. Then said F this and cut them off.
  15. Mar 4, 2013 at 6:49 AM
    #35
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    I saw another TW member use a ball joint press to remove the bushings. Cheaper than buying a socket, if you don't have one already. You can rent them from Autozone.
    I'll be replacing my bushings soon. I'll let you know if it works.
  16. Mar 4, 2013 at 6:57 AM
    #36
    ntilehman
    ntilehman Well-Known Member
    Seth
    Charlotte, NC
    09 Prerunner Off Road
    Rock Sliders Front Light Bar +1.5" Front Arms with Ext. Kings
    Great thinking. Saving money by doing thinga yourself is the best. It allows you to buy much cooler things for your truck. Very detailed write up.
  17. Mar 4, 2013 at 10:31 AM
    #37
    Pugga
    Massachusetts
    That was XXXX, aka misc, formerly known as... :anonymous:
    The press may or may not work. The problem is the bushings rust solid to the LCA sleeve and won't budge. That leaves you with the option of cutting the bushings out, being careful not to gouge the LCA sleeve.
  18. Aug 12, 2013 at 5:50 PM
    #38
    Nic914AZ
    Nic914AZ Well-Known Member
    Nic
    Tempe, AZ
    02 White Prerunner
    None
    just did this... used this method. I think i had a 36mm socket and then another 32 on the other side and pushed just the rubber out after heating both sides with a butane torch. It left some rubber and i heated it, sprayed it with some brake cleaner and wire wheeled the sleeves clean so i could press in my new poly ones. The instructions said to leave the sleeves in, which worked out because i dont think i could have removed them anyway.
    That was my first experience installing poly bushings - WEAR GLOVES with that lube that comes with it. That's some sticky stuff! not fun. I just hope after all that they dont squeek.
    I only got to the driver's side upper today. lower has a seized rear alignment bolt. F.
    I will probably take it to someone who can throw on the bushings faster than I can and align it as well. might have a shop put the other side on... not sure yet. Maybe I'll just wait until it cools off here. 103 in the garage today around 2pm.
  19. Aug 13, 2013 at 4:28 AM
    #39
    skytower
    Dave
    virginia
    08 Tacoma 4x4
    I got mine done, shortly after my last post. I used the ball joint press to push out the rubber portion of the bushing, then used an air chisel to get the sleeve out. An exhaust ripper bit works well. I suppose you could do it by hand, but it would be a PITA!
    FYI: Never-seize the hell out of everything as you assemble. As you have already noticed, the factory phosphate coating doesn't last.
  20. Aug 13, 2013 at 5:38 AM
    #40
    Pugga
    Massachusetts
    Since this got bumped, don't bother using neverseize when you put things back together, it doesn't last. You need to use grease. One of my bolt seized again, about a year after they were replaced. I put so much freakin neverseize on there when I installed them it wasn't even funny and one of them still seized. I'll break it loose (hopefully) and grease the ever living shit out of it for next time.
    Crom likes this.
